Carb hose: Vent to air or cap? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 11-12-2012, 12:50 AM Thread Starter
Main Motorcycle: 08 Scramblinator 9000
ItsForrest's Avatar
Other Motorcycle: Kawasaki Darth Versys
I just got done with a few mods on my carbie Scrambler. One of the things I did was strip off the smog bits. I wasn't sure what to do with one hose, should it vent to air or should I cap it?
Here's the hose, with a very crude red arrow pointing to it. The hose attaches to a hard pipe between the carbs at the upper part of the carb body towards the engine.
Get off my lawn!
ItsForrest is offline
post #2 of 5 (permalink) Old 11-12-2012, 12:51 AM
Read Gary's Evaporative Loss system removal instructions. He has you buy a longer hose and route it down and vent it alongside the tank breather hose.
In sum, it must be vented.
luckyduck is offline
post #3 of 5 (permalink) Old 11-12-2012, 01:06 AM Thread Starter
ItsForrest's Avatar
Wow! I guessed right!
It is currently vented down to where the carbon canisters used to reside.
Get off my lawn!
post #4 of 5 (permalink) Old 11-12-2012, 01:08 AM
Good call. That evap system seriously made the bike a pain to work on in certain areas with all those ribbed hoses.
post #5 of 5 (permalink) Old 11-12-2012, 09:32 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
I have read in the past where some have found the "long hose vent" can be a problem in strong cross winds. My '03 has no hose at all--the vent is open to the air right at the carbs with a T connection. This has never caused me any problems in very strong winds. My conclusion is that Mr. T corrected a problem that did not exist in later years by adding the hose. Of course the CA models had the hose to go to the canister.
FYI, if the carb bowls are not vented, the carbs will flood BIG time.
Larry
RedBird is online now
Carb Vent Hose Routing phpbiker T3 Sport / Touring Forum 4 01-24-2015 12:15 PM
Air vent hose Garioch43 Classic, Vintage & Veteran 10 11-25-2010 05:24 AM
Tiger Vent Hose Johnnybabylon Tiger Chat 2 11-10-2009 06:07 AM
Vent Hose? roccotacco21 Air Cooled Twins Technical Talk 4 07-18-2009 07:20 PM
Where does this vent hose go??? Knave of Clubs Air Cooled Twins Technical Talk 6 04-28-2009 09:25 PM
