Tunning CRS carbs with Innovate MTX-L - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 11-11-2012, 01:55 PM Thread Starter
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
ok let it start ....wanted to start new thread about it as need some help and opinion from people with more knowledge about tunning than me
My bike Triumph Bonneville America
- 904 Wiseco kit
- 813 TPUSA cams
- ignitor remapped by Pieman (best money ever spent)
- gutted airbox(no snorkels ,restrictor plate removed)
- "breath" air intake
- Keihin CR-S carbs
- Epco exhaust
Bike going strong no problem there but recently been on dyno and not really happy with result was too rich in a first place ....
after reading a lot on this forum about tunning and how helpful Air/Fuel ratio gauges are ,decided to buy one ..Innovate MTX-L and welded bung into crossover pipe.
Today was my first day riding with gauge on the bike and here we got results; 118 main jet ,needle 3rd clip position
Idle............ 13..........1100 rev
1/4..............11.8.......3200 rev
1/2..............12..........5000 rev
had no chance to open throttle to WOT not enough road and with half throttle was doing 90 mph (shown on speedo)and going up to ton
because i done those markings using masking tape in throttle and housing first time ever noticed that I'm normally using trottle opening from 1/4 to 1/2
Any advice?
grzegorz is offline
post #2 of 11 (permalink) Old 11-11-2012, 07:26 PM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
You need to get the main jet squared out before you start playing with the needle position. Take the bike out where you can pull full throttle for a good 20 seconds & see where you are at on the main jet. The partial throttle conditions are good and rich right now, so no worries about hurting anything. With a 118 main, my guess is you are quite lean on the main jet...
BTW, make sure you order some needle shims if you end up getting bigger mains - or get the appropriate size SS washers from the hardware store (they work) since you're going to need to fine tune the needle at some point.
Regards,
--Rich
beemerrich is offline
post #3 of 11 (permalink) Old 11-11-2012, 09:12 PM
Main Motorcycle: Yes
B02S4's Avatar
^ What he said...
B02S4 is offline
post #4 of 11 (permalink) Old 11-25-2012, 03:24 PM Thread Starter
grzegorz's Avatar
-ok 120 main(AB jet) read somewhere that it should be the same as Keihin
-needle 2nd clip from top
Idle around 14
from 0 to half throttle about 13,6
WOT down to about 12 (but this is not confirmed as run was to short)
weather wasn't great..very strong wind and wet surface
grzegorz is offline
post #5 of 11 (permalink) Old 11-25-2012, 04:33 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
You need to know what the a/f is at redline before you will know what main jet you need.
you dont have to use 5th gear to do this 3rd or 4th will give you a good idea.dont even worry with the needle untill you get a/f wot at redline.Changes to the main jet will change what the needle does.
mikeinva is online now
post #6 of 11 (permalink) Old 11-25-2012, 05:19 PM Thread Starter
grzegorz's Avatar
grzegorz is offline
post #7 of 11 (permalink) Old 11-25-2012, 05:40 PM
What Mike said. My bike likes high 12s at full throttle for max. power. I'm cheating currently with about 13.5 a/f on a full throttle pull to keep my 3/4 throttle from going pig rich.
The needle selection for the CR carbs is limited and in order to get the correct initial diameter for my setup, I had to go one size bigger in initial diameter (i.e. leaner on the keihin chart) than typically supplied with these carbs. In doing so, the needle length (L1) is shorter/taper happens quicker, thus making 1/2 to 3/4 throttle go quite rich. What is needed for my setup is a leaner needle with a longer L1...unfortunately, there in no such animal short of having one made one-off...
Your current setup sounds promising. But do dial in that main before going further.
Regards,
--Rich
post #8 of 11 (permalink) Old 11-25-2012, 10:13 PM
mikeinva's Avatar
they seam to run there best at 12.5 to 13.0 wot at red line.If you are running stright gas closer to the 13.0 if you are running 10%eth closer to the 12.5
post #9 of 11 (permalink) Old 11-26-2012, 04:38 PM Thread Starter
grzegorz's Avatar
gas..........the grade is different here than USA or Canada we got 95 in usa its 91
grzegorz is offline
post #10 of 11 (permalink) Old 11-26-2012, 04:51 PM
A 13:0 to 1 A/F ratio is probably optimal based on what you're saying. What mike was trying to say is that if your gas has ethanol in it, run it a bit richer than that...like mid to high 12s...
Good luck,
--Rich
innovate lm2 jed Air Cooled Twins Technical Talk 25 08-01-2010 01:40 PM
T120 Tunning Help Again sjw867 Classic, Vintage & Veteran 6 03-17-2010 12:07 AM
Interesting article about dyno tunning a SP3 from a local shop. zapata Speed Triple Forum 1 10-01-2007 09:08 PM
Help Please - Tunning problems with Thrux900 airbox removal, predator exhaust, air inject elim.... binary9 Club Cafe' 9 06-11-2007 12:22 PM
Dyno Tunning Chicagoland Area 3xdope The Rocket Science Forum 2 08-04-2006 11:31 AM
