Idle Speed /Choke Question - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 2 (permalink) Old 11-11-2012, 12:07 PM Thread Starter
Main Motorcycle: 2007 Bonneville T-100
Other Motorcycle: 79 Bonneville "GONE"
Extra Motorcycle: 1972 DeTomaso Pantera
I have a question/concern with my 07 T-100 carb Bonneville. I purchased it this summer when morning temps were usually 70 or higher.
Full choke at cold start-up was around 1800-2000 RPM. Idle after choke release 1000- 1100 RPM.
Now morning temps are in the 40s. Engaging full choke has no effect on engine RPM. idle is about 1000 RPM. With full choke I adjusted the idle speed to 2000 RPM. After a few seconds the engine idle speed shoots up to 3000RPM.
I have re adjusted the idle speed with the engine hot back down to 1000 RPM. The bike runs great as it has all summer. But this reoccurring cold idle/choke issue is sort of a PIA when first starting.
Any of you carb owners experiencing similar cold start issues? Fixes?
Barnstorm is offline
post #2 of 2 (permalink) Old 11-11-2012, 12:31 PM
You could try checking the carb heaters in case a wire's become disconnected.
denbow is offline
Choke vs Idle espresso addict Air Cooled Twins Technical Talk 3 10-20-2011 09:34 PM
choke and idle question blackspring Air Cooled Twins Technical Talk 30 09-19-2011 09:16 PM
AI removal causes slow idle speed with choke engmex Air Cooled Twins Technical Talk 0 11-23-2008 06:14 PM
Starting idle with choke? Springbok Club Cafe' 2 11-18-2005 06:38 AM
Choke/Idle Ruthwell Air Cooled Twins Talk 4 09-22-2005 04:45 PM
