Oil Leak help - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 14 (permalink) Old 11-12-2012, 12:01 AM
Forchetto's Avatar
It might be nothing more than loose bolts. Check them first, I seem to remember one or two posters finding them loose. You'll need an 8mm wrench.
The recommended torque is just 9 Nm (6.64 Ft/lbs), little more than hand tight, don't overtighten.
If you need to replace the gasket the cover is nothing more than a cover, there's nothing attached to it and it comes off easily for gasket replacement. A new gasket is part number T1260969.
Forchetto is offline
post #12 of 14 (permalink) Old 11-12-2012, 01:14 AM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
Originally Posted by mikeinva View Post
i bet its the seal behind the front sprocket .It will fool you .What you need to do is take sprocket cover off clean around Tthe shaft seal real good ,ride the bike get it good and hot.put bike on side stand let it idle and watch shaft seal.Cut it off and watch for oil allso.What hapens about 80% of the time the oil runs out of seal then runs down the shifter cover and you cant see that the seal is leaking.I found this out the hard way lol.
I reckon that's what it is too as have been chasing this annoying leak for ages and have finally nailed it down to this seal
the leak on my bike looks exactly like in your photos
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
I like a man who grins when he fights -
Winston Churchill
bonza is offline
post #13 of 14 (permalink) Old 11-12-2012, 07:59 AM Thread Starter
jeiser's Avatar
Other Motorcycle: 1977 CB550
Made sure all if the bolts were tight. It's hard to really find it because it isn't a pro dominant leak from the o ring but I suppose it weeps a little and eventually collects underneath the gearbox cover. I'll call the dealer today and I might even have them come and pick it up since it is inconvenient for me to get it to them. Since the bike doesn't even have 3k on the clock yet I don't think that is an unreasonable request.
_______________________
Jay
That's all the motorcycle is, a system of concepts worked out in steel. - Pirsig
jeiser is offline
post #14 of 14 (permalink) Old 05-16-2013, 10:21 AM
Main Motorcycle: Buell XB12Scg
misternikko's Avatar
Other Motorcycle: Triumph Thruxton
Your pics look just like mine. Did you ever get it fixed? What was it exactly?
Thanks.
misternikko is offline
Head gasket leak cause rocker box oil leak? ruger001 Classic, Vintage & Veteran 11 07-24-2012 03:39 PM
Oil Leak sam_vassallo Classic, Vintage & Veteran 9 04-14-2012 06:47 AM
Leak Baby Leak, More! More! timbo2 Air Cooled Twins Technical Talk 25 06-17-2009 11:05 PM
Oil leak?? AceT100 Air Cooled Twins Technical Talk 7 01-16-2008 11:34 PM
leak 1962gypsy Air Cooled Twins Talk 3 01-25-2006 05:11 AM
