How to Determine Pilot Jet Size? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 11-10-2012, 04:19 PM Thread Starter
Main Motorcycle: '02 Triumph Bonneville
I dropped out the pilot jets today just to look at their size, thinking that since the PO had changed the MJ's to 128's he might also have increased the pilots at some time.
They came out easily and look clean, but I can't find anywhere, even under a glass, where they're size stamped.
I must be the first to run into this, because there wasn't any previous posts on this question.
Maybe there's a difference in 'size' that I should be looking for?
Thanks
LapinAgile is online now
post #2 of 5 (permalink) Old 11-10-2012, 05:13 PM
gbc
Main Motorcycle: Rocket 3
gbc's Avatar
Other Motorcycle: Rocket III
Extra Motorcycle: 1999 Moto Guzzi Bassa
Check the side of the jet closely, not the top. I have seen some that are very faint when stamped on the side.....
gbc is offline
post #3 of 5 (permalink) Old 11-10-2012, 06:31 PM Thread Starter
That's where I'd expect to see it, but the spring action likely rubbed it off by now. I'd have liked to know what they are, but it runs/idles well so guess I can forget about it.
Thanks
post #4 of 5 (permalink) Old 11-10-2012, 06:43 PM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
Spring action? My pilots aren't held in with springs. My air mixture screws are, but not my pilot jets. Are you sure you're looking at the pilot jets?
Your pilot jet should look like this:
Chris / RudeBoy BIR #309
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is online now
post #5 of 5 (permalink) Old 11-10-2012, 07:56 PM Thread Starter
Wow.........Was I screwed up.....I think I even knew that but wasn't thinking when the screwdriver suddenly appeared in my hand.
Sunday suddenly seems like a good day to check my pilot jets.
Thanks much Chris -
I'm thinking I should jump up a pilot jet size marc hanna Air Cooled Twins Technical Talk 8 07-29-2009 09:00 PM
Is this water in the carb? Pilot Jet size? PdxT100 Air Cooled Twins Technical Talk 2 05-13-2009 02:19 PM
what is the stock pilot jet size on an '05 bonnie? eviltwin415 Air Cooled Twins Technical Talk 3 02-06-2009 11:19 PM
08 America STOCK pilot jet size? pepper Air Cooled Twins Technical Talk 3 09-12-2008 10:55 AM
Jets - How do I determine which size? gritkisser Air Cooled Twins Technical Talk 5 06-02-2008 05:41 PM
