Help - My Thruxton is dead! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 45 (permalink) Old 11-09-2012, 04:44 AM Thread Starter
Other Motorcycle: Vespa 125 Primavera ET3
Unhappy Help - My Thruxton is dead!
I have a 2004 Thruxton. (with carbs, therefore)
I was riding it yesterday and it just died on me.
Plenty of fuel, and no spluttering or coughing the way it would if I dan out of fuel/had a blockage, so I think we can eliminate that.
It just went from BRRRMRMRMRMRM to ........................
Lights stayed on, and the starter cranked the engine over fine, until the battery no longer had enough to keep turning it, but the engine would not fire up again.
I don't know where to start looking, except in the classifieds for something reliable. What do I do?
Londonbabe is offline
post #2 of 45 (permalink) Old 11-09-2012, 05:01 AM
Main Motorcycle: 2005 Triumph Bonneville
cgn152's Avatar
My two cents. Check the ignition coil. Under the front of the gas tank. My 05 Bonnie had a very similar issue. I went through everything before finally listening to people here on the forum. I ordered one around $80. Wham bam! But that's just my experience! Best if luck
"As Always...Do Good Things!"
cgn152 is offline
post #3 of 45 (permalink) Old 11-09-2012, 07:10 AM
Unless you've accidentally hit the kill switch (it happens) I suspect it's either the ignition coil or the pick up coil.
Apart from a few minor niggles, these bikes are normally very reliable and easily fixed if something goes wrong.
denbow is offline
post #4 of 45 (permalink) Old 11-09-2012, 08:28 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Other, more experienced, guys will chime in, hopefully. But assuming you've checked all the safety stuff, i.e. kill switch, side stand switch (doesn't sound like those, since the bike turns over) and the fuses, the 3 components that usually cause that symptom are the coil, the pickup coil, and the CDI (igniter). There are a lot of threads on how to check the first 2. The igniter, however, has no way to be tested.
The coil is easy to test, but might not be easy to diagnose if it's the problem. The pickup coil, also easy, but the stator/alt cover on the right side of the bike might need to come off to remove it and check it properly. Does the bike start this morning? If it does, I'd probably check this right away.
Seems like lately on here, members with a similar problem (including myself) ended up needing to replace the igniter, the most expensive part.
There are TONS of threads on how to test the first 2. Maybe Forchetto or DEcosse will chime in. They (and some others here) seem to be wizards with multimeters and soldering guns
Bron-Yr-Aur Garage
Last edited by Bron-Yr-Aur; 11-09-2012 at 08:35 AM. Reason: Don't konw hwo to tpye
Bron-Yr-Aur is offline
post #5 of 45 (permalink) Old 11-09-2012, 08:57 AM Thread Starter
It wasn't the kill switch or side stand switch either because the starter motor did turn.
I'll go over it with the multimeter tomorrow.
Bloody modern bikes.
cheers.
post #6 of 45 (permalink) Old 11-09-2012, 08:58 AM
Main Motorcycle: 05 Thrux (in development)
GySchmit's Avatar
Other Motorcycle: 2011 Suzuki DRZ-400S
Send a message via AIM to GySchmit
IF you know someone with a Carbed Thrux or Bonnie the Igniter & Coil are easily checked using the following steps...
1 - Purchase numerous Peeps Beverage of Choice.
2 - Ring up Peep, invite him over for Beverage and have him ride his bike over.
3 - Swap out Igniters (mark yours so you don't get them mixed up (See #1)).
4 - Try and start both bikes.... if his doesn't start (and yours does) you know the problem.
5 - If it does start swap back then follow steps 3 & 4 for Coil.
6 - If his doesn't start (and yours does) you know the problem.
7 - If it does start swap back and try starting your bike with original Ignitor & Coil.
8 - If your bike still doesn't start continue drinking (remaining or replacement) beverages and report finding to this thread for more ideas on what next to check.
Schmit
GySgt, USMC(Ret)
“Notoriety is Fleeting - Anonymity is FOREVER!”
GySchmit is offline
post #7 of 45 (permalink) Old 11-09-2012, 09:44 AM
Main Motorcycle: T100 Bonnie
timpee77's Avatar
Other Motorcycle: custom postie CT110
Extra Motorcycle: 70cc nifty fifty rat bike
Send a message via Skype™ to timpee77
Guy's advice is spot on.
Check you don't have a spark by pulling both the plugs, grounding one of them and turning it over. If you don't have spark then do as stated above. If you don't have a mate with a similar bike you'll need to start testing and replacing bits but its really likely it'll be pickup coil, located under the clutch side cover or the coil which is tucked up under the front of your tank. In the case that its your CDI then you're better off getting an aftermarket one from ProCom than paying the crazy prices that triumph want for new genuine one.
I had a similar prob with my ’05 T100 and it ended up being the pickup coil.
timpee77 is offline
post #8 of 45 (permalink) Old 11-09-2012, 09:46 AM
timpee77's Avatar
*Gy's not Guy's, sorry mate.
timpee77 is offline
post #9 of 45 (permalink) Old 11-09-2012, 09:46 AM
Main Motorcycle: 2012 bonneville T100
Choprocker's Avatar
do you keep bike outside, just wondered if some wa*ker has turned fuel off.
how long did your battery last trying to turn it over? just wondering if that is up the wall.
Choprocker is offline
post #10 of 45 (permalink) Old 11-09-2012, 11:02 AM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
Hi Londonbabe,
I had a similar problem. Here's how I got it handled. Solution is on post #8.
+1 on Gy's advice. But if that fails there's still hope.
On mine it was the pickup coil and not the ignition coil. Don't let anyone sell you a new ignitor or Ignition Control Module (expensive) before trying this less-expensive fix.
Good luck.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/Turd Arrestor/D9 Dash/520/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline
need some help with dead thruxton RacerX113 Air Cooled Twins Technical Talk 19 11-25-2010 09:58 AM
Issue with dead Thruxton Treehugger Club Cafe' 21 05-16-2010 12:41 AM
Thruxton Turn Signals Dead :( Neil Walters Air Cooled Twins Technical Talk 11 01-08-2009 10:15 PM
Thruxton Dead kaligrown Maintenance & Workshop Talk 3 10-31-2008 11:33 AM
Dead Thruxton bryancald Club Cafe' 10 01-06-2006 08:29 AM
