Carbon fiber gas tank? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 26 (permalink) Old 11-08-2012, 02:08 PM Thread Starter
Main Motorcycle: '09 Triumph Thruxton
Burgandy25's Avatar
Other Motorcycle: 1963 Suzuki TS250 Savage
Hypothetically speaking making a.carbon fiber tank would be quite hard right? Taking it off to make a mold wouldn't be to hard, a 2 piece mold top and bottom. But the hard part would be the gas cap screw in threads and the bottom gas pump/filter/mechanism thingy on the bottom with screws to take it on and off.
So say hypothetically I wanted to try to make a carbon fiber tank this winter, would it be nearly impossible without sinking a huge budget into this? Would this be even possible? Also lining the inner tank would be hard to. Anythis im missing?
Sent from my SCH-I510 using Motorcycle.com Free App
Burgandy25 is offline
post #2 of 26 (permalink) Old 11-08-2012, 02:16 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
Its been done. Conderderate Motorcycle had them as option years ago. They were a nightmare. Ethanol fuel caused delamination and bubbling. Unless its a fake tank...I woulndtdo it
DUCKMAN is offline
post #3 of 26 (permalink) Old 11-08-2012, 02:40 PM
Main Motorcycle: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a CR&S Vun
Or you could just get one from Italy. There is a small firm, named de Caesar, that make very cool parts for the Bonnie/ Thrux. There is also a US distributor.
Here you can see their (unpainted) karbon/kevlar tank:
http://www.decaesar.it/DCS015.htm
I have their triple clamps, and they are really great!
'04 T100 used to be B&W, now is Aluminium
904, 813, port&polish, Pieman igniter, rebuilt front (valves, springs, etc), Öhlins shocks, tubeless alu rims, JMC alu swingarm, DeCaesar alu triple trees, MASSmoto pipes, Ti nuts and bolts
- Ringer
TB-T100 is offline
post #4 of 26 (permalink) Old 11-08-2012, 02:49 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
You can get weld-in gas cap bungs that can be molded into the CF tank. There is a shop in Japan (CarbonDry) which makes a CF shell that fits over the stock tank. I've always thought that was a cool solution for those who want a high tech looking tank, but don't have very deep pockets. And you have no leak worries.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #5 of 26 (permalink) Old 11-08-2012, 03:01 PM
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
There's a small family shop in the Atlanta area which hand hammers gas tanks out of aluminum.
The goal in changing the tank is to reduce weight.
Carbon Fiber doesn't take well to holding caustic materials.
You could, however, make a CF 'container' for a bladder system - possibly.
CF is all about stronger and lighter than metal alternatives.
But not as a container for fluid (not to say it hasn't been done.)
LukiSevenAce is offline
post #6 of 26 (permalink) Old 11-08-2012, 03:07 PM
JLN
Main Motorcycle: '07 Scrambler
JLN's Avatar
Other Motorcycle: '12 Yamaha Super Tenere
Extra Motorcycle: '07 Ducati GT 1000
I made a composite tank for one of my Ducatis. It can certainly be done. Sealing the inside of the tank to prevent against ethanol exposure is easy and reliable, just use Caswell epoxy.
The thing is, if you take on this project, it should because you enjoy doing this kind of thing. It's a ton of work, and you will spend a significant amount of money for materials. Forgot about the cost of cf cloth. You'll be amazed how much you'd spend on basic materials like sandpaper.
Just going out and buying one may be the better way to go if you just want a CF tank and don't want a huge project.
If you want specifics on how I did mine and dealt with things like gas caps and fuel pump mounts send me a pm.
JLN is offline
post #7 of 26 (permalink) Old 11-08-2012, 03:16 PM
A guy from 'Lanta called me some time ago to gauge my interest in having tanks made. Of course I was excited to see what he could do.
Never heard back from him.
/M
post #8 of 26 (permalink) Old 11-08-2012, 06:29 PM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
/M
This is the one major thing modern Bonnie owners are lacking...
killian101 is online now
post #9 of 26 (permalink) Old 11-08-2012, 10:19 PM
Main Motorcycle: 08' Bonnie
08Bonnie's Avatar
After some doubts as to whether it would work or not, I'm pleased with the way mine came out. I bought it in from DeCaesar along with some alu swingarms. The before link is here and the after is here. It is technically not Carbon Fiber as one would image it. It is Kevlar layered with a carbon shell. I've only put ethanol free fuel in it so dont know about how the ethanol would affect it. I do also add a cap full of fuel stabilizer along with each fill-up. The weight is 5.5 lbs less than stock and does make the bike much more flickable.
Various stuff...
08Bonnie is offline
post #10 of 26 (permalink) Old 11-09-2012, 12:16 AM
Main Motorcycle: -
Be careful with carbon fiber reinforced plastic (CFRP) bits. The majority are just glossy vinyl prints on something cheaper. Others are a single layer of CFRP over a cheaper material. Often the resins used will turn yellow in sunlight. Buying actual CFRP parts will cost a fortune, mostly in labor at the factory.
Making your own CFRP is possible, but expensive and time consuming. You might want to use a very thin metal tank as an internal structure. As the tank itself would not be load bearing, you could make your own out of the thinnest sheet you can find.
Stanislao is offline
Triumph Carbon Fiber Tank Pad sincity337 Sprint Forum 20 01-14-2013 12:45 PM
3/4 length carbon fiber tank cover!!!! dphex T3 Sport / Touring Forum 11 01-28-2009 04:52 AM
carbon fiber half tank cover Justice Strike Triumph SuperSports 9 12-15-2008 09:02 PM
Carbon Fiber Gas Tank MattTriumphs Air Cooled Twins Technical Talk 30 05-29-2008 12:40 AM
Triumph Carbon Fiber Tank Protector motomyth Sprint Forum 6 07-15-2006 03:55 AM
