Carbon fiber gas tank? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 26 (permalink) Old 11-09-2012, 08:06 AM
Main Motorcycle: 05 Thrux (in development)
GySchmit's Avatar
Other Motorcycle: 2011 Suzuki DRZ-400S
Send a message via AIM to GySchmit
Another option is to have your Tank (and related Tins/Plastic) Hydro Dipped with a Carbon Fiber Film. Looks Great, Less Time & $.
" SDthruxton " he did this to his Thrux and it looks FANTASTIC!
Here is his thread on it.... http://www.triumphrat.net/club-cafe/...n-project.html
Schmit
GySgt, USMC(Ret)
“Notoriety is Fleeting - Anonymity is FOREVER!”
GySchmit is offline
post #12 of 26 (permalink) Old 11-09-2012, 12:51 PM Thread Starter
Main Motorcycle: '09 Triumph Thruxton
Burgandy25's Avatar
Other Motorcycle: 1963 Suzuki TS250 Savage
Your kidding me? Thats not real carbon fiber on his bike? That would fool me!
Sent from my SCH-I510 using Motorcycle.com Free App
Burgandy25 is offline
post #13 of 26 (permalink) Old 11-09-2012, 09:45 PM
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
I can get the contact info on the Atlanta company doing the aluminum tanks (and other parts too.)
Will post it here in this thread? Or, make another?
I've known the family for a number of years now, we're all members of GABMA (the group which puts on the British in the Blue Ridge events (near unto 30 years now.)
It's not a 'company' per se, but two brothers, and other family members who do the work.
Looks like nice work, and the prices were quite good.
I'd like one, with maybe a gallon or two extra room in it.
Keep an eye out for their contact info (tomorrow.)
LukiSevenAce is offline
post #14 of 26 (permalink) Old 11-09-2012, 11:46 PM
Askari's Avatar
Carbon fibre!
Some interesting advice. Like the idea of the lookalike film.
I used to work in the prosthetics industry and used a lot of CF for sockets. If you are going to make a tank and using CF you are obviously after weight saving you are going to need a vacuum pump.
As for a mould why use the standard tank, let the imagination go.All you need is some from work card, timber. thin steel to form the hollow for the spine and to get the locking lugs and bolt holes aligned. Then use plaster of paris to form the shape you want. To save using tons of plaster just use a block of anything that is samaller than the tank and build on it. Surforms, flywire, wet and dry, spoons etc can all be used to shape. If you f--- up just add more pop. Even if you went the conventional shape and moulded the tunnel tight to the frame top tube you would get a big increase in fuel capacity.
By using eva socks under and over the cf you vacuum the resin in and this way get a very smooth finish, long as your layup is good.
If you are going to hand lay then you will need to make a female mould, lot more involved.
As for fuel and its effect just add a liner that comes in liquid form, like you can get for rusted tanks.
Carbon fibre is actually a lot cheaper than most realise, it is the old supply and demand scenario, lot more of it about these days.
Askari is offline
post #15 of 26 (permalink) Old 11-10-2012, 08:38 AM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Originally Posted by Retro-Racer View Post
.... There is a shop in Japan (CarbonDry) which makes a CF shell that fits over the stock tank. I've always thought that was a cool solution for those who want a high tech looking tank, but don't have very deep pockets. And you have no leak worries.
/M
I've always thought the beauty of CFC is the weight saving, I've never seen the point of using it to add weight. I guess if you're not interested in weight then you may as well go down the CFC looky-likey cling film stuff.
GDCobra is offline
post #16 of 26 (permalink) Old 11-10-2012, 10:02 AM
Main Motorcycle: Scrambler!
reflectedstatic's Avatar
Other Motorcycle: Waterford F-22 (acoustic)
It's been done.
A pretty solid write-up: http://www.bayarearidersforum.com/fo...hreadid=145975
You can also build a plug from foam, laminate on top of it, and then dissolve out the foam. That won't leave a super-slick surface if that's what you're after.
reflectedstatic is offline
post #17 of 26 (permalink) Old 11-10-2012, 11:43 AM Thread Starter
Burgandy25's Avatar
I would do it to save weight and increase fuel capacity, I would be worried about the heat resistance of the CF being right above the engine, with fuel in it.
post #18 of 26 (permalink) Old 11-11-2012, 08:29 PM
As promised, here's that info on the custom made aluminum tanks out of ATL:
Classic Custom & Cafe Motorcycle Parts
Motorcycle Alloy Parts and Alloy Tanks
Johnn - 404.550.6114 or Dass - 404.550.4460
Mind you, I've not purchased anything from they (yet.)
As well, I have no connection to them other than our mutual membership in Greater Atlanta British Motorcycle Association.
I've seen the many things they fabricate and have been impressed with the quality and finish. They do good work and are quite proud of it too.
As long time members of GABMA (the club which puts on the "British in the Blueridge" event every June), they're well known and respected by everyone in it.
Nice folks.
Johnn has one a number of prizes in the Show at BritBur over the years.
In fact, it's a family affair- their children win too!
[I don't know if there's some rule about passing this on here - in the least, maybe they could become advertisers. Apologies in advance for bending the envelope.]
post #19 of 26 (permalink) Old 11-11-2012, 09:01 PM
Main Motorcycle: 2007 Scrambler
Checkers's Avatar
There is a gent named Evan Wilcox who makes beautiful aluminum tanks in Nor. Cal.
http://www.wilcoxmetal.com/
That said I don't think the stock steel tank is that heavy. A new aluminum tank is going to run you a around a grand and save 3-4 lbs. Lot more fragile than steel as well. You could keep the steel tank and lose a 3-4 lbs by running a lipo battery like a Shorai. Cost would be $160. That leaves you $840 for more farkles. Just a thought.
Checkers is offline
post #20 of 26 (permalink) Old 11-12-2012, 12:53 AM
Question: Why would you want to do this?
I can see two reasons:
1. The tank would be lighter weight.
2. You appreciate the aesthetics of CF
My answers:
1. The tank is not all the heavy to begin with. I can lift off the tank, filled to capacity with fuel and its not heavy at all.
2. CF looks ugly on a Bonnie (IMO).
My recommendation: If you want to increase fuel capacity just have a custom tank made out of steel. This time, have it made without the ugly seam in it.
luckyduck is offline
Triumph Carbon Fiber Tank Pad sincity337 Sprint Forum 20 01-14-2013 11:45 AM
3/4 length carbon fiber tank cover!!!! dphex T3 Sport / Touring Forum 11 01-28-2009 03:52 AM
carbon fiber half tank cover Justice Strike Triumph SuperSports 9 12-15-2008 08:02 PM
Carbon Fiber Gas Tank MattTriumphs Air Cooled Twins Technical Talk 30 05-28-2008 11:40 PM
Triumph Carbon Fiber Tank Protector motomyth Sprint Forum 6 07-15-2006 02:55 AM
