Scrambler sidecar gearing - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 11-08-2012, 09:13 AM Thread Starter
R0B
Main Motorcycle: FJ1200
Other Motorcycle: building a custom bonnie
Extra Motorcycle: Bonnie with a sidecar
I recently collected my scrambler sidecar outfit from Watsonian. On my way home the bike happily cruised at 75/80 MPH on the motorway. I'd like to be able to keep this as a comfortable top end speed, but find the gearing too high in the lower gears. The Scrambler is on standard gearing. What sprocket changes would reduce my tall gearing without ruining the ability to cruise comfortably at motorway speeds?. I'd like to try and get it right first time as money is tight at the moment.
Thanks
Rob
R0B is offline
post #2 of 11 (permalink) Old 11-08-2012, 09:48 AM
Main Motorcycle: 2013 Speed Triple
Cburt's Avatar
Go down a tooth on front. That shouldn't hurt your cruising speed and will cost next to nothing.
Other than that, anything you do is going to be a compromise one degree or another.
Cburt is online now
post #3 of 11 (permalink) Old 11-09-2012, 09:20 AM
Main Motorcycle: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
if you go down 1 tooth on the front your rpm should rise about 600 at 70 mph
toys for big boys
wildchild is offline
post #4 of 11 (permalink) Old 11-09-2012, 09:32 AM
Main Motorcycle: T100 Bonnie
timpee77's Avatar
Other Motorcycle: custom postie CT110
Extra Motorcycle: 70cc nifty fifty rat bike
Send a message via Skype™ to timpee77
You can't have your cake and cruise at low rev's too. Any gain it bottom end will be felt as a loss (more rpm at a given speed) at the top.
Just remember that a single tooth change on the smaller, front sprocket will make a bigger difference than a single tooth on the rear. Front sprockets are considerably cheaper to swap out and don't require removing the rear wheel entirely. You can muck around with ratios for $20 a sprocket.
I personally run one tooth smaller on the front and stock rear because I mostly ride around the city and like the more punchy feel off the lights. (and sometimes like to light up the back wheel when it's wet) but do find she sings a little sharp on the highway at 110kmph. Interestingly it hasn't significantly increased my fuel consumption even on long h'way runs.
timpee77 is offline
post #5 of 11 (permalink) Old 11-09-2012, 09:44 AM
Cburt's Avatar
Interesing you haven't noticed a drop in economy?
I've been debating dropping mine one tooth, even have the sprocket ready to go.
I was running a LeoVince and felt a rise on RPM on the hwy made it even more ear splitting.
Last week I went back to stock exhaust, maybe now is the time to swich out the sprocket.
Cburt is online now
post #6 of 11 (permalink) Old 11-10-2012, 01:33 AM
timpee77's Avatar
i was quite surprised but probably shouldn't have been because i had a similar experience when i added an extra tooth to my old XTZ660 before i set off around Oz. i was doing it with the express intent to reduce my fuel consumption and was interested to see if it would up the top speed of the bike too. if it made a difference to fuel use, it wasn't one i could pick from the normal variation you get depending on what type of riding you do and more interestingly, it didn't alter the bike's top speed of 165* either. she just sat at slightly lower rev's at the same top speed. perhaps wind resistance is more important at higher speeds?
*all high-speed tests were performed under controlled conditions on suitable private roads.
timpee77 is offline
post #7 of 11 (permalink) Old 11-12-2012, 05:02 PM
Main Motorcycle: Bonneville T-100
Other Motorcycle: 2011 Ural T
I have nothing to add but would love to see some pics of your rig! A scrambler with a sidecar sounds awesome!
Living the dream of the 90's
jml3837 is offline
post #8 of 11 (permalink) Old 11-12-2012, 07:21 PM Thread Starter
R0B
scram with sidecar...........
R0B is offline
post #9 of 11 (permalink) Old 11-12-2012, 09:07 PM
Those Watsonians are beautiful I went for a 16 tooth front on my Bonnie/Dmc rig.I don't ride fast so I've not noticed a loss of top end speed. The extra tooth makes it easier on the clutch when starting on a hill. The chain adjusters took up the extra slack so going back is easy.I'd say do it.
Cathouse Willy is offline
post #10 of 11 (permalink) Old 11-13-2012, 12:48 AM
Main Motorcycle: 08 Scrambler
Steering?
Hi -
It doesn't appear as if you have made any modifications to your forks or triple tree. True? If so, is it not difficult to steer? Have you considered doing so? Thanks.
Joe Carpenter is offline
Alaska by sea and by three (Scrambler sidecar) Skier Ride / Trip Reports 14 10-01-2011 11:50 PM
Scrambler with a sidecar Skier Air Cooled Twins Talk 24 09-23-2010 01:56 PM
sidecar - scrambler boinger Air Cooled Twins Technical Talk 6 05-10-2010 09:46 PM
Adding a sidecar to a Scrambler mm1ut1 Air Cooled Twins Talk 15 01-08-2010 08:45 PM
Scrambler gearing johnyC Air Cooled Twins Talk 0 04-14-2006 12:48 PM
