Bonneville SE spark plugs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-07-2012, 12:45 PM Thread Starter
Newbie
Main Motorcycle: 2012 Bonneville SE
Can anyone tell me how to remove the plugs from the Bonneville SE and what sort of plug spanner is required?
The riders manual is no help!
Oldessexbiker is offline
post #2 of 6 (permalink) Old 11-07-2012, 12:51 PM
Main Motorcycle: Aprilia Caponord
Other Motorcycle: 2006 Scrambler (sold)
Extra Motorcycle: 1995 Daytona 900 (sold)
There's no voodoo involved, but you will need a thin wall socket and popping the tank off helps!
http://www.triumphrat.net/twins-tech...park-plug.html
bobbo is offline
post #3 of 6 (permalink) Old 11-07-2012, 02:04 PM
Forchetto's Avatar
No need to remove the tank. Clean out the space around the plug as dirt tends to collect in there and could fall inside the cylinder. Compressed air is best, but a paint brush and small vacuum cleaner nozzle helps.
Obtain an 18 mm thin wall (very important) tube or box wrench. This will seem too long but there's room under the tank just above the plugs to insert the wrench upwards and then lower it above the plug.
Use a bar or screwdriver as a tommy bar to undo plug.
On replacement apply a couple of drops of clean engine oil or even better, some anti-seize compound or copper grease to the threads to ease removal next time and prevent seizure.
Halfords do a 20g tube for £3.49: http://www.halfords.com/webapp/wcs/s...egoryId_165705
Although the plug manufacturer (NGK) gives a torque setting they realise that in a lot of vehicles you can't get a torque wrench in there.
They advise that in the case of our 12mm-thread plugs, that you bottom them by hand and then turn the wrench a further 1/12th of a turn (about 30 degrees of rotation).
That's in the case of used plugs. For new ones with uncrushed sealing washer they advise rotation by 1/2 turn (180 degrees).
Forchetto is offline
post #4 of 6 (permalink) Old 11-08-2012, 04:46 AM
True, you don't need to pull the tank, but let's face it, it only takes a couple of minutes and will make the job so much easier.
bobbo is offline
post #5 of 6 (permalink) Old 11-08-2012, 08:58 AM
Main Motorcycle: 05 T100
If you remove the tank, you can use a torque wrench... But I can imagine that removing the tank on an EFI bike is a little more involved than for a carbed bike?
Paul.
Herts. UK
PAAS is offline
post #6 of 6 (permalink) Old 11-08-2012, 12:48 PM
richm's Avatar
Actually, after removing my EFI tank a couple of times, I'd say it's just as easy as a carb'd bike - un-clip fuel line (has a quick-connect fitting), pull off vent tube and un-plug fuel pump - easy! There are a couple of threads with pictures in the Sticky section.
And yes, I'd remove the fuel tank too for changing plugs as it's easier to see that the area around the plugs is clean and that nothing drops in.
richm is offline
New Spark Plugs Outsource Speed Triple Forum 5 10-11-2011 02:40 PM
Dropped Bonneville, Spark Plugs Fouled and Wet with Oil WhiteLetter Air Cooled Twins Technical Talk 3 09-24-2011 11:52 AM
what spark plugs and gap for 66' bonneville? razman Classic, Vintage & Veteran 4 03-19-2011 12:06 AM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Air Cooled Twins Talk 15 10-27-2009 04:25 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
