2005 Bonnie speedo - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 11-07-2012, 05:05 AM Thread Starter
Newbie
Main Motorcycle: Triumph Bonneville 2005
Other Motorcycle: ninja 250,CBR 600
Extra Motorcycle: suzuki fxr 150 racer
2005 Bonnie speedo
The speedo on my 05 Bonnie is very erratic when doing a steady speed it will fluctuate wildly + and - 20kmh.
Odometer seems to be registering accurately though....Does anyone have any experience of this or have any possible solutions?
bigreddog is offline
post #2 of 7 (permalink) Old 11-07-2012, 05:31 AM
Main Motorcycle: 2010 Bonneville
I had a similar issue on my previous Honda - was caused by loose battery connectors - coming loose and braking connection - lossen them off then tighten with a bit of vasaline on them
Mr*Beaver is offline
post #3 of 7 (permalink) Old 11-07-2012, 06:07 AM
Check the speedo cable nut hasn't come loose loose behind the speedo. If not it's likely to be a damaged or dry cable.
denbow is offline
post #4 of 7 (permalink) Old 11-07-2012, 03:33 PM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
As denbow says most likely a dry cable. Undo bottom fixing and withdraw inner cable clean by pulling through some clean rag the oil lightly with 40 grade oil just enough to give it a film then re-assemble turning the inner so that the square locats into the speedo then fit the bottom end making sure the tongue fits the slot in the speedo drive and re-fit the cross head screw ( Do not overtighten as you can break the plastic also do not over oil the cable as the oil will work its way into the speedo)
T.U.D.
tonupdave is offline
post #5 of 7 (permalink) Old 11-09-2012, 03:48 AM Thread Starter
Newbie
Thanks Guys...cable is secure and located correctly,Have removed and lubed with CRC (WD40) and is still erratic.
I will remove again and do as tonupdave says and lube with 40w oil.
Will post results back.
post #6 of 7 (permalink) Old 11-09-2012, 06:38 AM
These speedos work by a magnet spinning inside an aluminium disc attached to the needle and sprung against the stop by a coiled hairspring......If the cable turns intermitantly you get a jerky reading... The only other cause is the needle sticking or dry of lubricant..One way to test is to remove speedo (A pain!!) and twist it sharply and the needle should swing freely if it don't thats your prob. More of a pain because it needs to be stripped by a specialist ( The rim is rolled on not like old speedos which screw on)
Hopefully the cable oil will do it...Make sure the cable runs in a nice sweep up to the speedo with no sharp bends..I know it sounds obvious.....Good luck..
T.U.D.
post #7 of 7 (permalink) Old 11-09-2012, 09:53 AM
Main Motorcycle: T100 Bonnie
timpee77's Avatar
Other Motorcycle: custom postie CT110
Extra Motorcycle: 70cc nifty fifty rat bike
Send a message via Skype™ to timpee77
For what it's worth, somebody was selling a used speedo in the classifieds a short while ago...
timpee77 is offline
Help!.. I need a Bonnie speedo Hogtied Air Cooled Twins Technical Talk 11 09-09-2009 04:41 PM
SpeedMaster Speedo on Bonnie jammers Air Cooled Twins Technical Talk 8 02-18-2009 01:59 AM
HELP!! speedo not working - Early Model 2005 Sprint ST reay21 Sprint Forum 1 02-10-2009 05:09 PM
What would you pay for a 2005 Bonnie??? xX05bonnieXx Air Cooled Twins Technical Talk 4 04-05-2007 10:00 AM
