Triumph Bar End Problem - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 11-04-2012, 07:39 PM Thread Starter
Main Motorcycle: T100 Bonnie
Other Motorcycle: 650 V-Strom
I have just bought a set of OEM Triumph bar end mirrors for my '12 T100. The dealer shipped them direct to me at home and I'm very impressed. I recommend them highly @ $120.00.
End commercial, on to problem. I am mechanically inclined and have (way back when) made my living turning wrenches. My problem is the very first step. To remove the bar end cap from the bonneville, I have to remove the decorative end cap. It is held in place with a screw that has a 8mm allen head in it. 8mm isn't very big, my wrench only has about 6 inches of "handle" to turn the screw. I can lean on the end of the wrench until I have over 1 inch of deflection on the shaft. (It bends, or flexes) The screw hasn't budged, and I'm afraid I might be deforming the allen head. I tried to spray a little WD-40 to loosen it up with no affect. Both sides are the same. Has anyone had this trouble? I've seen loctight hold pretty good, but nothing like this. It was a cool 40 degrees in the garage today, could the lack of heat be a factor?
Any hints will save me from just drilling these screws out. I hate to throw the towel but I'm getting close.
Thanks very much!
Wiz
"Ride safe, one of the idiots out there might be me!"
Wizard54 is offline
post #2 of 8 (permalink) Old 11-04-2012, 08:01 PM
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Try a ratchet with an appropriate hex bit. You can get plenty of oomph on it with no deflection. I had the same trouble, they are very tight as are other screws and bolts on the Bonneville. Once they are loosened and torqued to spec they seen to give no further trouble. Good luck
Tasmaniablue is offline
post #3 of 8 (permalink) Old 11-04-2012, 08:25 PM
Main Motorcycle: 2012 Blue/White Bonnie SE
GTO Bruin's Avatar
Other Motorcycle: 2013 Ninja 1000
Extra Motorcycle: 2012 Yamaha FZ8
Yes. It is very tight. I just muscled mine loose using a pair of pliers squeezing the bend in the allen wrench.
GTO Bruin is offline
post #4 of 8 (permalink) Old 11-05-2012, 10:52 AM
Main Motorcycle: 2012 T100 Cranberry/cream
Taxbiker's Avatar
Other Motorcycle: 2008 V-Strom 650
I bot the same mirrors for my 2012 T100. They are great and give plenty of rearward view. Plus, I love the look.
I tried to remove the allen head bolt holding the end cap, but stripped out the head from each side! I drilled off the head, removed the end cap, and had to use vice-grip pliers to remove what was left of the bolt. Each bolt appeared to have over 1" of thread.
Triumph must use gorilla lock tight on those things. Would anyone NOT notice if the bar end cap was loose?
The mirrors mounted easily after that ordeal. However, I couldn't get them really tight, so I went to the local Ace hardward and bot two rubbler o-rings from the plumbing department (I think they were 1 1/4") to place between the mirror and handlebard. This tightened up pretty good, but still allowed the mirrors to be tilted up/down for adjustment.
Got a really good deal on my from ebay.... brand new in the Triumph box $69.99 plus $12 shipping!
Enjoy your new mirrors.
Taxbiker is offline
post #5 of 8 (permalink) Old 11-05-2012, 11:37 PM Thread Starter
Thanks very much. Now that I know they are supposed to come out, I'll give it another go. I was thinking maybe they were left handed or something as tight as they seemed to be.
Ride Safe,
Wiz
Wizard54 is offline
post #6 of 8 (permalink) Old 11-06-2012, 12:42 PM
Main Motorcycle: 2012 Thruxton
mike1161's Avatar
Other Motorcycle: '96 Trident 900
I had exactly the same problem on mine. Finally got one loose, but the other totally stripped out the allen head socket, so had to drill it out. I can't believe the amount of thread locker they put in these at the factory!!! For this bolt, they really shouldn't have used any thread lock at all, just tighten it snug; not like its a safety-critical item...
2012 Thruxton, '96 Trident 900
mike1161 is offline
post #7 of 8 (permalink) Old 11-07-2012, 09:10 AM
Jihema's Avatar
Those bolts are locked with red loctite, you won't be able to force them out. Use a propane torch to heat the head but be careful not to melt the handlebar rubber grips! Using soap water (and a syringe to get it under the rubber) you can move the rubber grips away from the bar end for that purpose.
Jihema is offline
post #8 of 8 (permalink) Old 11-07-2012, 02:21 PM
Choprocker's Avatar
Other Motorcycle: 2004 Triumph America
8mm allen head, on mine it was a star type prob about 4/5 mm
try giving it as tap with a hammer and i mean a tap to try loosen it, also if you balls the allen bit up could try a flat head screw driver and try tapping it in the undo direction
Choprocker is offline
Problem with Triumph floorboards vito Cruisers - America, Speedmaster 2 08-23-2011 09:23 PM
Problem with TRIUMPH Fatpeople4sale Speed Triple Forum 22 07-20-2011 07:38 AM
Triumph Legend Problem need help. sydt160 Hinckley Classic Triples 3 10-25-2010 09:57 AM
New Triumph owner!! and problem!! xngpnk The Welcome Center 1 08-22-2010 07:20 PM
New Triumph, charging problem. cgriffin51 The Welcome Center 3 07-06-2010 12:40 PM
