Looking for a 7 convex headlight reflector - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-04-2012, 05:16 PM Thread Starter
Main Motorcycle: BMW R1200RT
Other Motorcycle: 2002 T100 Centennial
Hello,
I have a 2002 T100 Centennial.
In an effort to make it look more retro I would like to change from a flat headlight lens/reflector to a convex one.
I drive on the right hand side of the road (Canada) and my current OEM headlight has a parking light in it.
Has anyone done a swap before and if so what did you use?
gregpinch is offline
post #2 of 12 (permalink) Old 11-04-2012, 06:36 PM
Main Motorcycle: None at this time
This want you might be looking for, found it on EBay.ca
http://www.ebay.ca/itm/7-H4-EURO-CON...-/250895412882
As for the fit I do not know.
biker222 is offline
post #3 of 12 (permalink) Old 11-04-2012, 08:52 PM
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Including freight that is just under $44. Very good price, I paid $100 for a Hella here in Australia. I wonder what quality they are, probably ok. Country of manufacture? Does not matter these days, as long as quality is ok.
Tasmaniablue is offline
post #4 of 12 (permalink) Old 11-04-2012, 09:40 PM
Main Motorcycle: Bonneville T-100
Other Motorcycle: HONDA 550 CBK 1977 mod
Just put on a Cibie from Daniel Stern, with an Osram bulb, (65/70 W). Better light in the dark. Maybe will try an even larger bulb next ? I also revired with 10 gauge wire and relays direct from battery for 1 volt more at hte headlight. See 'how to' by Ecosse at this forum. It is well worth it for about $50 for the wiring job.
Norse
norse is offline
post #5 of 12 (permalink) Old 11-05-2012, 07:51 AM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
I put in a Lucas repop from Emgo years ago. I recall having to get a new halogen bulb that converted over to the newer 3-prong connector (H4?). There was a parking lamp bulb too.
I discovered that a stock headlight rim (ring) from the America or Speedmaster will fit a standard/T100/Thruxton headlight shell (bucket). There are noticeable differences however. Externally, the rim tucks-in tighter to the lamp edge almost eliminating the air gap between the two. There is no external lamp alignment screw (or alignment mechanism) and maybe it's an optical illusion, but the cruiser rim seems to be slightly deeper with a less rounded profile.
Internally... and relevant to this thread... the lamp mounting system is completely different. Whereas the Std/T100/Thruxton rim has an inner lamp mounting plate with various alignment hardware, the cruiser rims use a single formed wire "clip" that snaps-in a groove and pinches the lamp to the rim. I think this latter rim style will make fitting a new non-OEM lamp much easier.
I suspect the lack of the horizontal alignment feature is because the cruiser headlights are bottom mounted negating the need for internal adjustment.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #6 of 12 (permalink) Old 11-05-2012, 07:54 AM Thread Starter
Ohhhhh, that's great information and really critical. Thanks so much for posting that.
post #7 of 12 (permalink) Old 11-05-2012, 05:17 PM
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
You might try looking around the Domi Racer site. They handle a bunch of the original NVT parts (including reproduction parts). I get all my footpeg rubbers and mufflers from there.
https://www.domiracer.com/homepage.html
Sheepdog is offline
post #8 of 12 (permalink) Old 11-05-2012, 05:33 PM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
Hella part number 1A6 002.395-071 is a direct replacement. Cost in Europe is about 40 Euros from most any car parts shop.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #9 of 12 (permalink) Old 11-05-2012, 05:41 PM Thread Starter
I think the Hella is a flat lens. I am looking for convex.
I found 2 places that have the Cibies. One wants $90. each and the other wants $45. for a pair. Just waiting to hear back from the $45. place to see if they are the right ones and have a parking light.
post #10 of 12 (permalink) Old 11-05-2012, 11:50 PM
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Other Motorcycle: '68 Benelli 350'
Extra Motorcycle: '60 Morini Tresette 175
I put one of these on my bike, perfect fit, low/high beam. no parking light.
link
http://www.ebay.com.au/itm/NRG-SB701...#ht_1996wt_906
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
ozbon is offline
New Headlight Reflector Rapidman123 Air Cooled Twins Technical Talk 19 02-10-2012 06:57 PM
Slim 7" headlight reflector wanted R0B Air Cooled Twins Technical Talk 3 12-19-2011 09:30 AM
how dumb is my makeshift headlight reflector padding? metasac Air Cooled Twins Technical Talk 4 05-21-2010 11:08 AM
Headlight reflector bigred900 Hinckley Classic Triples 7 06-27-2007 07:52 AM
