Heated Geared on a bonneville - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-03-2012, 09:03 PM Thread Starter
Main Motorcycle: 2010 Bonneville Black
With winter coming I am looking at heated gear. I have been looking at some First gear jacket liners and heated gloves and trying to decided between 90 watts and 65 watts. My concern is will the bonneville battery be able to handle the extra juice needed to run the gear? Or how much would be to much in reguards to putting to much strain on the battery?
thomb25 is offline
post #2 of 14 (permalink) Old 11-03-2012, 09:38 PM
Forchetto's Avatar
No problem. Alternator has sufficient extra capacity for that. Ensure your idle speed is at at least 1000 rpm to ensure some charge at traffic stops.
Here's a couple of threads on the subject:
http://www.triumphrat.net/twins-tech...-capacity.html
http://www.triumphrat.net/twins-tech...ted-stuff.html
Forchetto is offline
post #3 of 14 (permalink) Old 11-04-2012, 04:38 AM
Yes no probs, I have been running heated gear for a long time with my T100.
Plasma.
plasma is offline
post #4 of 14 (permalink) Old 11-05-2012, 07:37 PM
Main Motorcycle: 2014 Tiger 800 XC SE
vistavette's Avatar
Other Motorcycle: 2009 Harley Ultra Classic
I have a hook up on my '06 T100 for my Gerbings stuff (jacket and gloves) and have never had an issue
2006 Triumph Bonneville T100 SOLD 3/14
2009 Harley Davidson Ultra Classic
2014 Triumph Tiger 800 XC SE
vistavette is offline
post #5 of 14 (permalink) Old 11-25-2012, 09:20 AM
Main Motorcycle: 2016 Thruxton R
marcsiry's Avatar
Other Motorcycle: Triumph Tiger 800 ABS
I've never had problems with my jacket and gloves, but I was able to run my battery below starting threshold yesterday by running 165w worth of accessories (gloves, vest, pants, socks) along with my running lights and headlight.
Luckily I had anticipated possible problems so I had a full-sized 25A battery charger in one of my Givis. 20 minutes of borrowed juice and I was back on the road.
Now I'm going to look at upgrades all around:
- LED lighting to reduce current draw
- R/R upgrade to maybe pass more juice
- I already had a Motobatt upgrade for the battery, but I will revisit that as well
- Update some of the Gerbing gear- I think I might have older models that need more juice for less heat vs. modern equivalents
- Since I typically have plenty of extra Givi room, I may even look into wiring in another battery in parallel for more reserve capacity, or switch it to have an emergency start backup... I'll have to see what that will do to the overall system.
Or I could move someplace where I am not compelled to ride in 25 degree weather.
Ninja -> Ninja -> CBR -> Moto Guzzi -> SV650 -> Nighthawk -> VFR800 -> Bonneville -> Moto Guzzi -> Thruxton R
marcsiry is online now
post #6 of 14 (permalink) Old 11-25-2012, 03:36 PM Thread Starter
Now where is the fun in that? Thanks for the help. My hope was riding my bike as much as I could over the winter weather permitting. I can deal with the cold just not the snow and ice. So I wanted to get some heated gear, however I work nights and even on cooler days over the summer/fall, (60-70's) I would get off work at 3-4am when the temp was much colder (30-40's)and while the bike started it sounded hesitant as if the battery was just barely enough power to start. I was worried that with addition of heated gear that would draw more power from the battery leading to the bike not starting at all.
thomb25 is offline
post #7 of 14 (permalink) Old 11-25-2012, 03:44 PM
Forchetto's Avatar
The alternator provides sufficient power, but these batteries are rather small, 12Ah, for such a relatively large twin-cylinder engine. Check out comparable displacement twin-engined bikes and see that they're fitted with much larger batteries, 17 or 24 Ah.
They store enough charge for a few attempts at starting but that's about it. No reserves for such things as pottering around cities at low revs with a high accessory load, or standing around with the headlight, etc ON before being started.
post #8 of 14 (permalink) Old 11-25-2012, 03:58 PM
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
Is there an upgrade that will fit?
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is offline
post #9 of 14 (permalink) Old 11-25-2012, 04:08 PM
Forchetto's Avatar
The chasis-engine-carb layout plus the need for an effective intake silencer in the shape of the airbox to comply with noise laws means there's no room for a larger lead-acid type of battery.
Good things are said about the latest Lithium-Iron-Phosphate (LiFePo) technology batteries that pack a lot of energy into a small space, but I have no experience of them. They're expensive though.
http://www.webbikeworld.com/motorcyc...le-battery.htm
post #10 of 14 (permalink) Old 11-26-2012, 12:45 AM
Main Motorcycle: 2001 Bonneville
I also have many kms with grips and jacket liner full blast, and no issues. But that is a bit less load, I thought around 100 IIRC.
I don't understand the point of a battery upgrade, if you are consistently exceeding the rated load of the alternator, there will be grief sooner or later, no?
schuitz is offline
Why a de-tuned engine vs a short-geared D675 engine? Lumberjack Street Triple Forum 11 08-06-2011 08:17 PM
Heated grips on a Bonneville? retrobikeguy Air Cooled Twins Technical Talk 4 05-01-2011 11:17 AM
Will Tiger heated grips fit Bonneville ? meloman Air Cooled Twins Talk 1 11-16-2010 04:54 PM
Stock Motored/Geared Thrux - Indicated Top Speed? greytop Club Cafe' 30 06-09-2008 06:31 PM
Tall geared sprockets questions 2112 Air Cooled Twins Technical Talk 60 08-22-2007 03:04 AM
