790 carb bonneville starting problem - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 11-02-2012, 05:01 PM Thread Starter
Main Motorcycle: 2010 Tiger 1050 SE
heimdal's Avatar
Extra Motorcycle: Wife's 250 Honda Rebel
Full charge in battery, kickstand up or down,transmission in neutral, clutch lever pulled in to grip; turn on the key and the lights all come on, hit the starter button and nothing happens. No clicking, no cranking, no grinding, nothing at all - as if the starter button is not connected to anything. I opened the headlight shell and visually checked all wire connections, and visually checked the wire connections to the starter realy, solenoid, and every other connector that I could find. The fuses are all OK. I know I'm missing something relatively simple here but I have reached the outer limits of my pitiful diagnostic abilities.
If you have any suggestions please type slowly and use small words so that I can understand.
heimdal is offline
post #2 of 6 (permalink) Old 11-02-2012, 05:38 PM
Kill switch?
If you're using the original battery, replace it.
Check the starter button. If it's not making proper contact or the wiring to it is compromised, there's your problem.
Does the headlight turn off when you press the starter button? If not, try replacing the starter relay.
Check continuity in the clutch switch and especially the side stand switch. Is the neutral light on?
Marty
Baltobonneville is offline
post #3 of 6 (permalink) Old 11-02-2012, 06:24 PM
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
check fuse again it might look ok but could be faulty ...had similar situation recently fuse looked ok but it wasn't...
grzegorz is offline
post #4 of 6 (permalink) Old 11-03-2012, 01:00 PM Thread Starter
heimdal's Avatar
Originally Posted by Baltobonneville View Post
Kill switch?
Battery is brand new and fully charged.
All wiring to the starter button appears firmly connected and undamaged.
Headlight stays on and does not dim at all when starter button is pressed.
Neutral light is on. Not sure how to check continuity but all wiring to and from the clutch and the side stand switch appear firmly connected and undamaged.
heimdal is offline
post #5 of 6 (permalink) Old 11-03-2012, 04:33 PM
Main Motorcycle: 203 T100
Other Motorcycle: 1968 Truimph Daytona
Extra Motorcycle: 2006 Ducati Multistrada
Sometimes the contacts in the starter button get dirty. Spray a little wd40 in the and see if that helps. Also, you can use car jumper cables. Hook to your car battery. Black goes to frame, red to starter side of solenoid. Good luck.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline
post #6 of 6 (permalink) Old 11-03-2012, 05:06 PM
Forchetto's Avatar
Does it have a clutch safety switch?. Check that:
http://www.triumphrat.net/twins-tech...ty-switch.html
Forchetto is online now
Mystery starting problem with new 110th anniversary Bonneville is hopefully solved Scrambler900 Air Cooled Twins Technical Talk 24 03-20-2014 03:05 AM
Bonneville Starting Problem wheat state Air Cooled Twins Technical Talk 6 03-16-2011 06:45 PM
Not starting after carb cleaning.. toibs Trophy 11 08-24-2009 05:33 AM
1970 Bonneville Carb Problem LGSpiker Classic, Vintage & Veteran 6 12-22-2008 09:57 PM
New Bonneville - starting problem Steveky4 Air Cooled Twins Talk 6 09-25-2005 12:20 AM
