Crankcase breather outer diameter - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 11-02-2012, 02:49 AM Thread Starter
What outer diameter crankcase breather do I need for the stock crankcase breather hose?
I read through 11 pages of Forchetto's "free horsepower" thread and couldn't find this info.
Thanks!
luckyduck is offline
post #2 of 10 (permalink) Old 11-02-2012, 01:48 PM Thread Starter
Any help on this one?
post #3 of 10 (permalink) Old 11-02-2012, 02:13 PM
12 - 13 mm
denbow is offline
post #4 of 10 (permalink) Old 11-02-2012, 02:59 PM
Forchetto's Avatar
Bonnies up to 2005 or 2006 had 6 mm (around 1/4") outlet breathers, from then on they have 13mm (1/2").
Forchetto is offline
post #5 of 10 (permalink) Old 11-02-2012, 03:23 PM Thread Starter
Wow that's a large difference in the I/D of the housing. I wonder if it's worth it to upgrade the hose on my '01 from 6mm to 12mm. I'd imagine that I'd need to use some sort of reducer on the outlet from the crankcase.
post #6 of 10 (permalink) Old 11-02-2012, 03:38 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
1/2" at the end of the stock breather hose.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #7 of 10 (permalink) Old 11-02-2012, 03:42 PM
Forchetto's Avatar
Bob Farnham tuning in the UK removes the clutch to re-drill the crankcase to accept the newer 13mm (1/2") outlet.
The increase in outlet diameter might not seem much but you have to consider the area, not just the diameter. Doubling the Diameter increases area by four times.
6mm diameter breather pipe area = 28.27mm2
13mm breather area = 132.73mm2
Earlier bikes, up to VIN number 221608, had their breather hose outlet spigot attached to the inner pipe/seal assembly, like this:
Later ones don't have that pipe and the spigot is just a push-in fitting I believe. Not sure how it's held in the crankcase.
post #8 of 10 (permalink) Old 11-03-2012, 12:24 PM
Driftless Moderator
Main Motorcycle: 2008 Bonneville Black
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I use a UNI UP-123 on my 2008 Bonnie, using the original breather hose. It's a 1/2"
Bike Bandit lists the same breather hose for the 2001 as for the 2008. I'm a bit confused the the picture above and the reference to 1/4", so I hope I'm not answering the wrong question.
BonnieBlack is offline
post #9 of 10 (permalink) Old 11-03-2012, 02:51 PM
Forchetto's Avatar
There are two different breather hoses listed in World of Triumph:
Up to VIN 221608 plus numbers 229407 to 230164 the breather outlet hose is part number T2201705
Newer engines use hose T2200189
Source:
http://www.worldoftriumph.com/triump...&block_03=3130
post #10 of 10 (permalink) Old 11-09-2012, 06:01 PM Thread Starter
Ok so I measure my breather hose inner diameter with a pair of calipers and its .05 inches or about 12mm. So I guess I have a newer breather system on my 2001 bonnie?
Crankcase Breather Mod Scorch Triumph SuperSports 7 10-03-2011 02:19 PM
Crankcase breather (I think) rubado Air Cooled Twins Technical Talk 3 07-28-2011 03:14 PM
Crankcase breather mod... Flaco Air Cooled Twins Technical Talk 9 04-21-2009 07:46 AM
UNI Crankcase Breather Gwiaz Air Cooled Twins Technical Talk 6 08-18-2007 12:09 AM
Crankcase breather ??? danbike Air Cooled Twins Talk 5 04-15-2006 04:36 PM
