2001 Bonneville Getting oil Into Airbox - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 11-02-2012, 02:14 PM
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
I fitted crankcase no return valve ..works like champ
grzegorz is offline
post #12 of 17 (permalink) Old 11-02-2012, 11:37 PM
Main Motorcycle: '03 Triumph Bonneville
Originally Posted by PieMan View Post
If the seal is at the end of it's life, it doesn't matter where you put the hose, oil will spew out at higher revs and higher throttle opening. Changing the seal is the only option.
Also, replace the rotary breather disc (plastic disc with the metal tubing that the seal rides on) at the same time... I would bet dollars to donuts that there is a slight groove worn on the tubing where the seal contacts it...
There is a specific procedure for pre-stretching/sizing the seal using a factory plastic piece. After the clutch cover installation, you should wait 30 min to an hour before firing up the engine to let the seal seat on the tubing.
And yes, I've done the replacement... cured the problem...
SCbonneville is offline
post #13 of 17 (permalink) Old 11-03-2012, 03:14 AM
Main Motorcycle: 04 T100 Blue
Richybow's Avatar
This one had passed me by but now I've checked my engine number and its in the 180000's. How prevalent is this problem among affected engine numbers, and what's the reason some play up and some don't...the way it was built, a bad batch of o rings, long lay offs drying the seals?
Richybow is offline
post #14 of 17 (permalink) Old 11-03-2012, 05:20 AM
Forchetto's Avatar
Mileage I suppose. The seal has to stand up to a rotating action and it wears out with use.
Forchetto is offline
post #15 of 17 (permalink) Old 11-03-2012, 05:39 AM
triumphrat.net Vendor
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
yeah, mileage and heat build up. My personal 04 Bonnie has got through one every 5,000 miles for the last 15,000 miles, but it does go on the dyno quite often, which can build up heat in the engine.
Mike (UK)
PieMan is online now
post #16 of 17 (permalink) Old 11-03-2012, 09:38 AM
Richybow's Avatar
I'm guessing that there are plenty that don't have the problem at all, even after considerable miles...
Richybow is offline
post #17 of 17 (permalink) Old 11-03-2012, 05:39 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
Some last along time some dont its like any other seal or gasket it bites you when it wants to lol.SC is right any time you replace a seal insect where the seal rides if its worn replace it.If you dont the seal wont last as long.
mikeinva is online now
Bonneville EFI / Airbox removal? boarderdog Air Cooled Twins Technical Talk 3 01-28-2012 11:00 AM
