Ignition problem......Yes more of the same! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 15 (permalink) Old 10-31-2012, 01:45 AM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
I have made a couple of posts on Forchetto's pick up thread but think my issue deserves a thread of its own. I have just returned from a trip to the big island to the north ((of Tasmania). I have an 06 Bonneville......pods, pipes, 145 mains, 40 pilots 2.75 turns out......goes well. So the symptoms appear. Engine just dies, no warning. Wait 5 minutes, bike fires up and goes fine for 100km. Same thing happens at varying intervals on the trip. But at lower ambient temperatures say under 20deg c no problem. Clue; temperature related problem. I went right through fuel system, no problem (which I kind of knew but wanted to eliminate fuel as a problem). Next suspect was pick up coil. Adjusted the gap (it was 1.2mm), checked resistance.......605ohm cold, 750ohm hot. Put a new one in anyway. Next day was 30deg c, hottest day of the trip. Rode 10km and she stops. I have to wait 30mins before she starts again. I ride 5km (to the ferry) and wait over 2hrs by which time bike has cooled down, but it is still 30deg. Bike starts up and I ride 300metres to the ferry check in. Then fire up again and she stops after 50metres. Will not start again even after a further 90 min wait. I have to push the bike aboard the ferry (how close was that!). Next morning early the bike starts and I ride 45km to home with no incident, it is quite cool. Today I tore into the bike, next suspect is the coil. It tests ok on the high tension side but reads 2.5 ohms on the low tension side....should be 0.5ohm. Over the next few hours I re checked this reading and got between 0.3 and 1.5 ohm, quite a range. I wonder if something is going on inside the coil? (eg dry joint) I decide to try a reading at a higher temperature .........immerse coil in water at approx 40deg, Reads ok, go figure!
So what is suggested? Change coil? Note Tasmania is cooler than the mainland so problem may not appear. Purchase igniter and keep it as a spare, just in case? I note OEM coil is over $200AUD and igniter is close to $1000! I can get after market items (Nology and Pro Com I think) for around $500 total.......still painful!
I would be interested to hear your comments, btw can coils be tested "under load"?
Tasmaniablue is offline
post #2 of 15 (permalink) Old 10-31-2012, 02:01 AM
Forchetto's Avatar
If you need an aftermarket coil don't go for branded ones like Nology, etc. Those coils are made in Germany by PVL with the part number 356 1 00 They're used on some BMW bikes and others. Just do a search for other sellers like these on ebay:
This one is just 80USD:
http://www.ebay.com/itm/PVL-Coil-356...-/290617875551
http://www.ebay.com/itm/New-PVL-igni..._Parts&vxp=mtr
http://www.ebay.com/itm/PVL-Dual-Dig...-/170474109164
Forchetto is online now
post #3 of 15 (permalink) Old 10-31-2012, 02:59 AM Thread Starter
Hello
Forchetto you are a gentleman! Thank you for that information. I have placed an order for a coil (from New Zealand.......$110AUD including shipping, half the price of OEM item). BTW what are your thoughts re the likelyhood that the coil is the problem considering the symptoms? I have felt that the throttle response is a little off and the bike seems to have a little more low frequency vibration than before, but this is very subjective I know. If I have to purchase an igniter ((lets hope not) have you any suggestions re source? Thank you once again for your help.......kind regards.
post #4 of 15 (permalink) Old 10-31-2012, 08:16 AM
Forchetto's Avatar
The symptoms seem to point to temperature failures and coils often go that way. Let us know if it works.
If it did turn out to be the igniter Triumph Twin Power in the UK often have used but tested and serviceable igniters in stock at a much lower cost than a new one. Mike (aka "pieman") is your contact there or through a private message here, he's an active member of this forum.
http://www.triumphtwinpower.com/
post #5 of 15 (permalink) Old 10-31-2012, 08:34 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
There's also a lot of good press from members here on the forum (including myself) who love their Procom programmable igniter. I got mine new in package from fleabay for $230US+shipping. Worth the money, especially considering the OEM alternative. IMO it would be worth it even if you didn't need an igniter. Having that type of tuning capability usually comes at a much higher price.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #6 of 15 (permalink) Old 10-31-2012, 08:57 AM
my 06 did the same thing, hard strting followed by quitting on the road. followed by wouldnt start at all. I ordered a new coil, no help, checked the pickup coil, adjusted the pickup coil, and finally put on a procom igniter. no problems now. the only damage visible on the ignitor was a shiney spot where the seat had rubbed on the case. I also modified the seat pan with a heat gun for more clearance.
several months and no problems at all, easy starting, and better preformance.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline
post #7 of 15 (permalink) Old 10-31-2012, 10:16 AM
cliff
My experience almost identically, except the rubbing part. Just for good measure, I stacked 2 washers under each bumper on my seat, as the Procom looks a little bigger installed on the bike. I honestly can't even make a guess on the OP's problem, but it does sound eerily similar to mine and yours. I thought mine was heat related until it died on me and wouldn't start again.
Bron-Yr-Aur Garage
post #8 of 15 (permalink) Old 10-31-2012, 10:21 AM Thread Starter
Hello
Thank you all for those very useful and informative replies. As previously posted I have ordered a new coil. I can source a new Procom igniter in Australia for $299AUD plus $20AUD shipping. Out of interest I will look into motorcycle wreckers as a source for a used one. I will also keep my eye on e bay. I will try the new coil first and move on to the igniter if required, The igniter seems to be treated as a black box but since it has inputs and outputs I would have thought that testing should be possible if the designed inputs and outputs are known. I wonder how the units are tested during manufacture to maintain quality control. In my case the symptons seem to indicate failure (albeit temporarily) due to internal heat build up. Intermittent faults are so frustrating..........to reproduce my symptoms appears to depend on ambient temperature and in Tasmania it rarely exceeds 30deg c which seems to be the temperature at which failure occurs within say a half an hour of riding. My problem could have been dormant for quite some time.I will probably spring for a new igniter eventually but I would really like to know what is failing (and why). As an aside and to illustrate how deep my knowledge of electrickery is, I was always under the impression the electrics work on smoke and when the smoke escapes things stop working! For intermittent faults the escaping smoke must be invisible........a bit like dark matter.
PS No rubbing on the igniter from the seat pan........I am 72kg and always ride solo.
post #9 of 15 (permalink) Old 10-31-2012, 10:32 AM Thread Starter
Hello.....again
Just to add a little more info. I have had a couple of stoppages at lower ambient temperatures (say 12deg or so) but the bike restarted almost immediately. Also the problem has seemed to be getting worse so I think the coil or the igniter ( I wish I knew which) is heading for complete failure. Are the after market items more durable? I have not seen any reports of failures.
post #10 of 15 (permalink) Old 10-31-2012, 05:00 PM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
2 Thruxtons and 2 replaced igniters (Procom) and 2 different problems.
1) My Thruxton would start fine and then ride well, then it would die unexpectedly and not be able to restart it. 10 minutes later it would vroom into life with no issues for the next 100 kms.
I jiggled the igniter and it would stutter and fluff about. I bought an igniter from Procom and the problem is fixed.
2) My wife's Thruxton's tacho would work intermittently. Jumping around, stopping, starting. Very annoying.
I bought another igniter from Procom and the problem is fixed.
Hmmm! a pattern here!! I found out by running the bike with the seat off and I pushed my thumb down on the casing of the igniter. With my bike it would stutter and skip with the pressure on so I assuming that it is when there is a little weight on it or it is bouncing around that it cuts out.
Just my words of wisdom.
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline
59 5TA Ignition Problem snatchpiece Classic, Vintage & Veteran 40 02-22-2016 01:22 AM
ignition problem miketango The Rocket Science Forum 5 06-08-2011 12:12 PM
ignition problem Paul C. Air Cooled Twins Technical Talk 3 09-27-2008 06:34 PM
Ignition Problem? webonnielad Air Cooled Twins Technical Talk 1 08-25-2007 07:50 AM
Ignition Problem JSimpson Maintenance & Workshop Talk 8 03-17-2004 12:31 PM
