Ignition problem......Yes more of the same! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 15 (permalink) Old 10-31-2012, 06:49 PM
GDM
Main Motorcycle: Bonneville Modified 2005
Other Motorcycle: Bonneville T100 2006
Extra Motorcycle: Honda CB750 1972
I'm in Launceston and have a spare igniter and coils you can borrow and see if that is the problem.
GDM is offline
post #12 of 15 (permalink) Old 10-31-2012, 07:21 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
sounds like your igniter to me I have one that does the same thing gets hot and stops working.many coils have been changed that where not bad do to this.In most cases the pick up coil ether works or it doesnt.
mikeinva is online now
post #13 of 15 (permalink) Old 10-31-2012, 09:21 PM Thread Starter
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
I am leaning towards the igniter too. Oh well I have a spare coil coming. I wish we had some input output specs for the igniters but I guess the manufacturers do not want to tell us. Maybe someone versed in electronics could work out the circuit and come up with a testing protocol. GDM.......thank you I will be in touch.
Tasmaniablue is offline
post #14 of 15 (permalink) Old 11-25-2012, 05:22 AM Thread Starter
I think I have got to the bottom of it
Hello
Since my last post I have fitted a new coil and ridden quite a bit with no problems. Went to a vintage/classic bike rally today.....great day. Started the bike to leave and it immediately cut out and would not fire up again. Note that bike has had a new pick up coil and new ignition coil. So.....off with the seat, check igniter plug. I moved it while cranking and she fires up! While she is running I was able to move the plug and she stops. Some evidence of the seat pan touching the plug, probably when hitting bumps in the road. So I ride home with no incident. Next step is to thoroughly check out the plug and grease it with dielectric grease. As has been said 50% of "coil problems" are something else. I feel really stupid....sometimes it is so easy to overlook the obvious. I will make it a rule.......if I think the problem is electrical, check connections first. Interesting to note that the problem manifested when ambient temperature had risen to 25C or so. I guess that a poor connection gets worse as temperature rises........resistance increases in proportion to temperature? Expensive lesson but at least I have a spare pick up coil and ignition coil to carry with me.
post #15 of 15 (permalink) Old 11-25-2012, 08:02 AM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Nah, not stupid at all. And those are good spares to have. Electric problems are among the most hated (at least by me) of vehicle problems. Glad you got it sorted out!
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
59 5TA Ignition Problem snatchpiece Classic, Vintage & Veteran 40 02-22-2016 01:22 AM
ignition problem miketango The Rocket Science Forum 5 06-08-2011 12:12 PM
ignition problem Paul C. Air Cooled Twins Technical Talk 3 09-27-2008 06:34 PM
Ignition Problem? webonnielad Air Cooled Twins Technical Talk 1 08-25-2007 07:50 AM
Ignition Problem JSimpson Maintenance & Workshop Talk 8 03-17-2004 12:31 PM
