Breathe, Baffle and Baffled! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 11-05-2012, 05:02 PM Thread Starter
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
Well you've got me stumped with the sock trick - don't really understand what you're trying to get at though.
The engine's running fine now, not hunting or rough running off-idle - warmed her up completely with no change - without the shims it got much worse as the engine heated up.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #12 of 17 (permalink) Old 11-05-2012, 05:46 PM
I had the same thing when I decided I couldn't leave well enough alone and took the single thin shim off each needle. What a difference a shim makes. I was surprised, I didn't expect it to change much.
Marty
Baltobonneville is offline
post #13 of 17 (permalink) Old 11-06-2012, 12:23 PM
He's trying to make you run a bit richer with the sock .
luckyduck is offline
post #14 of 17 (permalink) Old 11-07-2012, 05:26 AM
Main Motorcycle: Bonnie
Dave2001's Avatar
Originally Posted by LukiSevenAce View Post
It's possible there's more than 387% better "CFM" being delivered by the mod.
Try stuffing a sock in the throats, but use wool ones and not the synthetic type.
The wool sock will have a thread count on the package.
Look for a number between 250 & 350, but not higher than that; any higher thread count will cause the carbs to choke down more than you want.
You can turn the balled up sock (called 'indexing') 90° to adjust the idle too.
Turning it 45° will alter the tone of the exhaust note. (Look for a high C)
Good luck with it.
*I like the part where you know it's running 'just fine' without taking it out on the road.
Genius!
Dave2001 is offline
post #15 of 17 (permalink) Old 11-07-2012, 08:55 AM
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
As far as a good AP goes, try "GForce".
I think there's a free version and a 'pro' version ($$).
The AP is only as good as the device it is 'reading', of course.
Reliance on the on-board accelerometer (a thing that isn't as big as the fingernail on your pinkie), is subject to scrutiny.
Like GPS devices have error, so will the smart phone you're using.
Though, and I'll give you this, it's great that y'all are willing to actually test performance of the mods in actual, road going situations.
I applaud that (and shall refrain from my petulant peanut gallery contributions to these threads.)
GForce Pro charts too.
Just looked up another one - Dynolicious. Seems to be more robust (than GForce being a mere display of the accelerometer in your smart phone.
Another one - Dynomaster (Android only it appears.)
"Feel" is either a noun or adjective. Lots of uses and meanings.
Applying it to a sensory experience, like 'feeling the bike pull', is strictly subjective analysis - and, thereby, fraught with error.
Putting a meter on the bike for testing and charting, is a great suggestion.
*Just a point about GPS -vs- accelerometer; they both have 'built in' errors. Like the average GPS is only accurate up to three meters, and is subject to noise, bias and deficiency.
Accelerometers (generally) measure only 'proper acceleration' and not rate of change velocity. The miniscule device in our phones, as mentioned, can be prone to error.
However, using any AP to rate or chart MC performance before and after a mod is better than the subjective analysis.
Anxious to hear/see the results. (sock or not.)
Last edited by LukiSevenAce; 11-07-2012 at 09:15 AM. Reason: notation on GPS -vs- accelerometers
LukiSevenAce is offline
post #16 of 17 (permalink) Old 11-07-2012, 06:50 PM Thread Starter
Gary_spain's Avatar
On that note I think I'll definitely "put a sock in it" (I may even try rotating it 90º just to make sure the noise reduction is adequate!)
post #17 of 17 (permalink) Old 11-07-2012, 07:27 PM
Main Motorcycle: 08 Street Triple
Lasermax's Avatar
Other Motorcycle: 2007 Speedmaster
Good luck with it.
Way to sock it to em!
Lasermax is offline
Breathe airbox intake jimdunleavy Air Cooled Twins Technical Talk 46 12-09-2014 07:18 PM
Breathe in Speedmaster! :-) loggamatt Cruisers - America, Speedmaster 11 04-21-2012 04:05 PM
I cant breathe...80s jacket... TIE-Pilot23 Biker Hang-Out 56 11-21-2011 02:36 PM
Baffled by the baffle blackbird Air Cooled Twins Technical Talk 8 10-22-2007 08:55 AM
some people are not bright enough to breathe!! ctrhenry Speed Triple Forum 4 09-07-2006 10:24 PM
