Why doesn't this work? Trouble with lights. - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 11-09-2012, 03:38 PM Thread Starter
Main Motorcycle: 2010 T100 Black / White
would something like this work then?
http://www.ebay.com/itm/Brand-New-Po...item4d02b64f52
fernandos1 is offline
post #12 of 17 (permalink) Old 11-09-2012, 03:58 PM
Forchetto's Avatar
No, it won't be able to provide the huge peak currents necessary for engine starting (60-80 amps), just look at the size of its output cables.
Are you confusing Lithium-Ion with the Lithium-Iron-phosphate batteries?
Forchetto is online now
post #13 of 17 (permalink) Old 11-09-2012, 04:10 PM
DEcosse's Avatar
Originally Posted by Forchetto View Post
Not really into HID mods ...
Decosse is probably our man.
HIDs not my thing either - I prefer to optimize the incandescents with
a) Improved wiring with relays to avoid voltage drop to the lamp
b) more efficient bulb of standard wattage
c) improved lens/reflector.
Back to the original problem - battery simply not sufficiently charged adequately to provide the 5A required for the light bulb, even if only for a few minutes.
The LED draws minimal current which is why that test is irrelevant
Originally Posted by Ripper
Your battery only provides 4.8 Amps for one hour. However this would not prevent the bulb from lighting up since the battery should be able to provide 9.6 Amps for 30 minutes but because this is outside the battery's recommended rating there is a risk of damage to the battery.
A reasonable generality for the illustration at hand - however 4.8Ah rating does not really mean the battery will supply 4.8A for one hour - nor will it supply 9.6A for 30 mins.
The way Ah rating is calculated is from the maximum current the battery is capable of constantly supplying over a period of 20 hrs before it depletes to 80% depth of discharge; for a 4.8Ah battery that means it would sustain 240mA for 20 hrs.
The math however is not linear and there is a significant difference from supplying 5A vs 240mA - so although it sounds like a simple ratio, in the real World, you would never get anywhere close to one hour at 5A load.
That being said however, a 5A load should easily be able to be sustained by a 4.8Ah battery for at least a reasonable period of time: if it does not even light, then the battery is sagging excessively suggesting it has insufficient charge state.
DEcosse is online now
post #14 of 17 (permalink) Old 11-10-2012, 10:23 AM Thread Starter
thanks for the great lesson. I get it now. It looks like those bulbs need a lot more power. Oh well, it was a nice idea. Now I have to figure out what to do with all of these extra bulbs and HID kits that I found in the garage!
post #15 of 17 (permalink) Old 11-10-2012, 01:39 PM
Ripper's Avatar
+1, especially with the improved lens/reflector
Which is - 240mA x 20hrs = 4800mA or 4.8A or, to put it another way, 4.8A for 1 hour. I agree that these ratings have no real bearing on a battery's performance in the real world though. But for the sake of simplicity I guess, the ratings are calculated on a linear scale, ie. double the current being drawn and you halve the time over which it can be drawn.
Ripper is offline
post #16 of 17 (permalink) Old 11-10-2012, 01:45 PM
Ripper's Avatar
If you really want to build a super torch, look at using Cree LEDs rather than a headlamp bulb. In terms of the light emitted a single Cree LED with a good reflector arrangement would easily compete with the low beam of an H4 bulb and you could afford to run quite a few Cree LEDs from your 4.8Ah battery.
Ripper is offline
post #17 of 17 (permalink) Old 11-10-2012, 02:03 PM
DEcosse's Avatar
That was exactly my point that they are NOT 'calculated' on linear scale but calculated specifically at the 20 hr rate and are absolutely not linear when larger currents are loaded
So you really can't simply double the current half the time, especially when you go to even larger multiples, in this case 20 times the 20 hr current rating
The Ah number is a relative guide that can be used as comparison between batteries, not to be used as an absolute given life at any other load
The LEDs are indeed excellent choice for long battery life with low current to light output ratio
Thruxton 2009 EFI lights won't work and bike won't start parko Air Cooled Twins Technical Talk 17 02-14-2015 04:54 AM
Bike lights and horn dont work DrDarko Sprint Forum 13 09-15-2011 01:43 PM
Tail lights out - Brake lights work crescen7 Daytona Deliberations 7 09-02-2008 10:00 AM
Brake Lights & Turns signals don't work cricket1 Sprint Forum 3 03-30-2006 03:31 PM
Making aux brake lights work RiderRocketman The Rocket Science Forum 4 08-13-2005 06:24 PM
