scrambler fcr39 jetting with zard low cross - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 33 (permalink) Old 11-10-2012, 05:06 AM Thread Starter
Main Motorcycle: Scrambler
Originally Posted by ratbone View Post
Hello WhoIsHayley
i have the same exhaust and air filter on my scrambler and wonder what jetts you ended up with, I couldn't fined any post from you and your setting on the site you recommended.
So i would be glad if you could tell me.
Hey Ratbone, sorry for the delay on the reply - was programming and launching a motorbike zombie bike battle contest lol - so I didn't get to tinker at all the last little while.
The 150 mains where way too rich as mikeinva and others guess it would be.
I bumped it down to 145 mains - i don't have an a/f at home but the plugs were looking a tad hot after a lengthy ride. (either from jetting or timing issues or both...)
So I richened the jet needle up and its running great (so far). Starts great, pulls steady throughout the mid range. (havent been on highway yet)
60 pilot
145 main
Clip postion 4 (2 grooves showing from the bottom.)
Tomorrow I plan get the a/f gauge on it to dial it in using mikeinva's techniques but this seems good so far.
2008 Scrambler, BC-ARK, FCR39, Zard, TPUSA 813 cams, Works/Progressive suspension, other stuff
WhoIsHayley is offline
post #22 of 33 (permalink) Old 11-10-2012, 04:51 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
glad you got it going your way now .Dont put to much into reading plugs on these bikes with the fuel we have now.When you think the plugs look right about 8 out of 10 times you will be to rich.
mikeinva is offline
post #23 of 33 (permalink) Old 11-11-2012, 01:53 AM Thread Starter
Good to know The shop was closed for a holiday so again I didn't get a chance to test the a/f gauge
post #24 of 33 (permalink) Old 11-11-2012, 09:19 AM
mikeinva's Avatar
just get the cerdit card and order you own lol .It will only hurt for alittle while lol
mikeinva is offline
post #25 of 33 (permalink) Old 11-13-2012, 02:50 AM Thread Starter
What do you guys recommend? the LM2
http://www.innovatemotorsports.com/products/lm2.php
post #26 of 33 (permalink) Old 11-13-2012, 10:27 AM
mikeinva's Avatar
I like the lm2 myself its is very easy to get the tune just right with the play back that you can use on your home puter.Its easy to see whats going on and when its going on.I wish I was smart enough to post a play back movie with play back speed slowed down on here .It show the real deal and its easy to use.On the play back you see a a/f gauge and a tach .You can watch the a/f change as the tach goes up in rpms you can freeze the play back at any point in the run.I like that much better then the charts.
mikeinva is offline
post #27 of 33 (permalink) Old 11-13-2012, 10:35 AM
Forum Liaison
Main Motorcycle: 04 Thruxton
RumRunner's Avatar
Other Motorcycle: 05 Tiger
Mike,
How well does your LM2 work on picking up the engine RPM? On the dyno it always seems hit or miss on picking up the tach signal on our bikes.
Doug
RumRunner is offline
post #28 of 33 (permalink) Old 11-13-2012, 04:22 PM
mikeinva's Avatar
DOUG it works way better then the pick up on the dyno I wire mine to the tach wire coming out of the igniter (red wire) so it works as good as the tach on the bike.
I know what you mean though I catch hell getting rpms to read right on the dyno and cant figure why I been wanting to call dyno jet and see if they have any tips,some times it seams to work good other times I have gave up and told the guy to just use the mph chart and dont get a torque reading it sure sucks.BUT i will say that when the dyno works the lm2,the tach on the bike and the tach on the dyno all read pretty close to the same.
mikeinva is offline
post #29 of 33 (permalink) Old 11-13-2012, 04:27 PM
Forum Liaison
RumRunner's Avatar
Mike,
Thanks for the info. Still on the fence on a LM2 vs. a single gauge unit, having the ability to log would be really nice. I spoke to Dyno Jet, and they said it was a grounding issue which made sense to me since I've had that with certain engine dyno's in the past. So we hooked up extra external grounds and it did absolutely nothing.
Doug
post #30 of 33 (permalink) Old 11-13-2012, 07:26 PM
mikeinva's Avatar
lol I ran a wire from the neg battery post I was thinking the same thing and it didnt help a bit ether.I kinda wonder if its something that goes on at high rpms with it being a wasted spark system .I hooked up my timing light to the bike once it would work the light good untill about 3000 rpms then the light would just quit working.I tired changeing plug wires ,coils boxes nothing seams to help at all.Maybe there is something strange with how these thing fire at high rpms dang if i know does not make since.
mikeinva is offline
Zard Cross exhaust numbers VodkaAndPickles Air Cooled Twins Talk 37 10-18-2012 08:12 PM
zard cross - UK legal shutty Air Cooled Twins Talk 10 08-18-2012 05:46 AM
ZARD Cross... who has it, I need help installing shekmark Air Cooled Twins Technical Talk 2 11-25-2009 07:50 PM
need help installing Zard Cross 2-1 shekmark Air Cooled Twins Technical Talk 8 11-23-2009 09:47 AM
