Inlet help part help pls - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 10-20-2012, 02:27 PM Thread Starter
Main Motorcycle: T100
lewilewi's Avatar
Other Motorcycle: Fazer
http://www.worldoftriumph.com/triump...&block_03=3130
PFKL1207093 INLET RUNNER what is it ?
PFKL1207086 INLET RUBBER on my bike has formed a crack or two and needs replacing but I'm stumped on what the inlet runner is ..
Also just has my Flasher relay go on me Phff just glad its not raining
cheer lewi
lewilewi is offline
post #2 of 9 (permalink) Old 10-20-2012, 02:47 PM
Forchetto's Avatar
cheer lewi
It's some sort of typo, I think, although these rubber carb-cylinder head adaptors are sometimes referred to as "runners". There are two part numbers for item 3 because one is for VIN numbers up to 169812, the other for VIN numbers beyond that.
The number refers to the last 6 characters in your VIN number, like this SMTTJ9107G9403639
Forchetto is online now
post #3 of 9 (permalink) Old 10-20-2012, 03:47 PM Thread Starter
lewilewi's Avatar
Many thanks Forchetto and a virtual beer for you
lewilewi is offline
post #4 of 9 (permalink) Old 11-11-2012, 07:33 AM Thread Starter
lewilewi's Avatar
Just fitted these yesterday and what a pig of a job , really not much room to move things around .
Am I missing some thing here ,is there an easyer way to fit those rubber runners ?
I would push the runner in place and then pushed the carb in place towards the engine ,then back on to the rubber runners .
It did nt help that it was dark by the time I was at this stage
cheers lewi
lewilewi is offline
post #5 of 9 (permalink) Old 11-11-2012, 03:20 PM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
Its agood idea to unscrew the clamps on the rubbers to the airbox squirt some WD40 in there that will allow you to pull the carbs back more easily also removing the tank but knowing you you probably did that anyway..............T.U.D.
tonupdave is offline
post #6 of 9 (permalink) Old 11-11-2012, 05:42 PM Thread Starter
lewilewi's Avatar
Hi Dave and yes I did
The time it took me I could of painted the sistine chapel
O well ,glad its done now and not befor it gets any colder .
ta lewi
lewilewi is offline
post #7 of 9 (permalink) Old 11-12-2012, 03:09 PM
Got some oil paints here and brushes........willing to loan!!!!!!!!!!!
post #8 of 9 (permalink) Old 11-12-2012, 03:15 PM
Use WD-40 to easy removal and installation of the rubbers. Loosen up the 4 bolts on top of the airbox to give you room to pull the airbox back and pull the rubbers off.
luckyduck is offline
post #9 of 9 (permalink) Old 11-12-2012, 03:19 PM Thread Starter
lewilewi's Avatar
Ah I shell looking into this when I get the chance !
And Dave I've got my own brushs thx
lewilewi is offline
inlet manifolds bdog Classic, Vintage & Veteran 2 09-18-2012 11:25 PM
Raask off set inlet kit Eazy Air Cooled Twins Talk 1 02-16-2010 08:01 AM
Scrambler 790 Inlet cam…… Part 2 Ventura Air Cooled Twins Technical Talk 6 11-18-2008 07:03 PM
790 inlet cam in a Scrambler johnyC Air Cooled Twins Technical Talk 65 11-07-2008 09:10 PM
Inlet Rubbers Hinckley Classic Triples 6 04-14-2004 08:32 PM
