Broke down. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 19 (permalink) Old 10-19-2012, 11:11 PM Thread Starter
Main Motorcycle: 2015 Street Triple
Broke down.
Riding home from work today and my 2007 Bonnie Black cut out on me. I'm sitting here waiting for the flatbed to tow her into the shop (thank god they are still around).
Now I'm sitting here wondering what happened.
The battery seems fine and she has a full tank, but I've done a couple things recently and think one of them may have something to do with it.
1. I replaced the air filter.
2. Recently replaced the silencers with those off a thruxton.
Any one have any thoughts?
Sent from my iPhone using Motorcycle
mrbassett is offline
post #2 of 19 (permalink) Old 10-19-2012, 11:25 PM
Main Motorcycle: 07 bonnie black
kartooo's Avatar
need more info.
fuel,spark ??
could be something simple like kick stand switch,kill switch,fuse,ground wire,pick up coil.....
in dog yrs i'm already dead
kartooo is offline
post #3 of 19 (permalink) Old 10-19-2012, 11:29 PM Thread Starter
Thanks for the response
I have a full tank of gas. It started up and ran fine for a few miles so I ruled out the side stand kill switch and any battery/spark issues.
I'm stumped.
post #4 of 19 (permalink) Old 10-19-2012, 11:40 PM
kartooo's Avatar
it turns over but does not start ?
did you check to see if you have spark at the plugs ??
do you have a spark checker ?
if not take an old plug put your plug wire on it, ground it against the head or any part of the bike that is grounded and turn over the bike while looking at the plug for a spark. if there is NO spark it will not run and you need to narrow it down from there. the pick up coil is a common problem just like the crank sensor on a car. on their last legs they just plain quit when warm. let em cool off and they work again. your igniter under the seat could have a bad connection too. 1st check for spark !!
kartooo is offline
post #5 of 19 (permalink) Old 10-19-2012, 11:53 PM Thread Starter
Thanks great suggestion.
Would you say that may fail around 10,000 miles?
post #6 of 19 (permalink) Old 10-20-2012, 12:01 AM
kartooo's Avatar
the little booger is like rolling dice, you never now. some people on here get 40k outta them, some less. i road tested a caravan got 5 miles from the garage and it quit like i turned the key off. got towed back to the shop and it started right up. crank sensor, just like pick up coil on our bikes. do a search here, there are tests you can do to check em out. some people have put them in a pan of hot water and watcehd them fail. check for spark !! i have one of these; http://www.harborfreight.com/inline-...ker-69014.html very useful tool.
link to pick up coil testing.
http://www.triumphrat.net/twins-tech...nd-boring.html
try the easy stuff 1st after you check for spark.....
kartooo is offline
post #7 of 19 (permalink) Old 10-20-2012, 07:14 AM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
wiggle the igniter
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline
post #8 of 19 (permalink) Old 10-20-2012, 04:57 PM Thread Starter
I ended up dropping it of at the shop, I was able to bribe him to stay late with a 12 pack of beer.
When I got there the bike had cooled off a bit and it started right up. He said: "do you want to ride it home now?"
Lol.
We kept it running for about 7 minutes and then it cut out again. At least I wasn't crazy.
We can pretty much rule out something with the fuel system and look at electrical issues.
I will let you all know what we find.
Thanks again for the suggestions.
post #9 of 19 (permalink) Old 10-20-2012, 05:25 PM
Main Motorcycle: Triumph Daytona 675
Other Motorcycle: Ducati Multistrada 1200S
Extra Motorcycle: Honda NC700X
I would suggest checking for good grounding..sounds very similar to a problem I had with my Buell
klutke is offline
post #10 of 19 (permalink) Old 10-21-2012, 01:47 PM
Main Motorcycle: Bonnie, what else?
Other Motorcycle: B25
Extra Motorcycle: T140
Classic symptoms of a faulty pick-up coil
2003 Black Bonnie: snorkel, A/B baffle & AI removed, 650 Bonnie straight through Campbell silencers, IKON shocks, CBR600 F3 forks, FJ1200 swan-neck clipons (winter) GSX flat clipons (summer), Procon igniter, Tiger alloy rim+150/70/70 rear tyre
Dayve is offline
Broke down already help roxiedog13 Cruisers - America, Speedmaster 3 07-06-2011 10:49 PM
HELP - broke off bar end markstaylor72 Speed Triple Forum 3 02-02-2009 10:41 PM
If it ain't broke, don't fix it. mglemans86 Biker Hang-Out 5 03-20-2008 11:12 PM
If it ain't broke...--? DaleE Hinckley Classic Triples 13 12-15-2007 10:24 PM
Anyone broke one of these? (pic) RCR001 Sprint Forum 11 07-27-2006 06:29 AM
