Bonnie issue's - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 25 (permalink) Old 12-04-2012, 06:42 PM
Main Motorcycle: 2010 Bonneville (mags)
psychodeathbot's Avatar
Other Motorcycle: BMW R1150R
Extra Motorcycle: Masi CX (man-powered)
Originally Posted by ozbon View Post
My interpretation of a, "not a cold weather bike" would point more towards a cheap @rsed battery. Unless you live in the Snowy Mountains you shouldn't have any problems.
I posted about this recently: http://www.triumphrat.net/twins-tech...or-output.html
From the sounds of things, there should be enough juice...?
psychodeathbot is offline
post #22 of 25 (permalink) Old 12-04-2012, 07:24 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
I have a mid-production 2001 with 55K on it. I have replaced the cam cover gasket once about 1,000 miles ago. I had reused this gasket at least three times without issue. Use an allen key on the cam bolts. Do not use a ratchet, over leverage will pull the thread.
I have had ZERO electrical system problems. The original Battery lasted 2 years...it got killed because I marshmellowed the battery by leaving the lights on all night. The second battery lasted 8 years. I am on my third. I have no cold weather problems...the bike spent the first 9 years of her life in NY without issues.
I have replaced spokes once, and relaced the wheel once. This is known issue with early bikes and newer bikes dont suffer from this nuisance.
The Bonneville is a well engineered durable machine with superior reliability.
DUCKMAN is offline
post #23 of 25 (permalink) Old 12-05-2012, 10:52 AM
Main Motorcycle: 2012 Rocket III Roadster
RickMcCl's Avatar
Other Motorcycle: N/A
Greetings, all!
I have an '08 T100 that I bought used, and am wondering if the spoke issue (rear wheel, I believe?) was still going on in'08?
Thanks,
Rick
RickMcCl is offline
post #24 of 25 (permalink) Old 12-05-2012, 01:34 PM
Driftless Moderator
Main Motorcycle: 2008 Bonneville Black
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
Do you have these hubs Rick? http://www.triumphrat.net/twins-tech...ml#post1124631
Seems like some think there was a design flaw that that hub design addressed. Some seem to think you just need to check your spokes pretty regularly and you'll be fine. I tend to tap all mine with a screwdriver whenever I have the rear wheel off the ground and listen for any duller sounding pings.
BonnieBlack is offline
post #25 of 25 (permalink) Old 12-05-2012, 05:08 PM
RickMcCl's Avatar
Thanks for the info!
Rick
RickMcCl is offline
No issue's :) tri955i Daytona Deliberations 5 04-22-2012 10:10 PM
CONFUSED !!! Wire issue's??? cj7jeepthing Air Cooled Twins Technical Talk 1 02-24-2011 04:20 AM
bonnie america front axle same as regular bonnie? smcquilling Air Cooled Twins Technical Talk 1 01-07-2010 01:01 PM
Hey fellow "Bonnie" owner i saw you yesterday on black "Bonnie" . Stealthrider Air Cooled Twins Talk 3 12-05-2005 02:35 PM
Put up pics of my standard bonnie/thrux/black bonnie mutation faffyface Air Cooled Twins Talk 12 08-09-2005 12:40 PM
