Subframe LED indicator mod - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 08-27-2012, 12:09 AM Thread Starter
Main Motorcycle: '07 Bonneville
francypants's Avatar
First off, I don't think this is a particular popular mod (only seen one other bike on youtube do it) as it requires you to drill a couple wire exit holes into your subframe and have a seat (custom or Thruxton) that exposes the ends of the subframe.
But, if you're like me and constantly looking for ways to bob and slenderize your bike, I think this makes for nicely hidden, but functioning indicators in the rear. I used the same 3/4" LED clusters for front indicators, making a bracket that neatly tucks them in right underneath my smaller bottom mount headlight. Got the inspiration to do this from a Chop Cult Metal Shop article. All pretty simple to do. Video link below.
http://www.youtube.com/watch?v=gPGUk...ature=youtu.be
francypants is offline
post #2 of 17 (permalink) Old 08-27-2012, 02:04 AM
Main Motorcycle: 2011 Thruxton
Nick Goodwin's Avatar
Other Motorcycle: not yet, soon.
Thats Really clean man ! Are you running a shock or axle mount lic. ?
Nick Goodwin is online now
post #3 of 17 (permalink) Old 08-27-2012, 11:13 AM Thread Starter
Thanks! I made a side mount license and rear light bracket and attached it to the lower shock bolt. I know lots of people hate the side mount thing, but I just love having a clean profile to the bike.
post #4 of 17 (permalink) Old 08-29-2012, 08:35 AM
Main Motorcycle: thruxton 900
looks nice
sbaugz is offline
post #5 of 17 (permalink) Old 08-29-2012, 09:08 AM
Main Motorcycle: 2012 Triumph Scrambler
Easy10pins's Avatar
Pics of the whole bike?
Everyone is fast in a straight line.
Easy10pins is offline
post #6 of 17 (permalink) Old 08-30-2012, 01:18 PM
Main Motorcycle: 2012 Bonneville base
I'm going to do the same thing for my rear turn signals. I have a couple questions for you though.
Do you have a link to the LED clusters you used? I still need to measure but I was thinking of using either of these two.
http://www.harrisonspecialties.com/m..._Code=SandRail
http://www.harrisonspecialties.com/m..._Code=RearWire
Also did you have to use a LED-compatible Flasher Relay?
gurbik is offline
post #7 of 17 (permalink) Old 08-30-2012, 06:07 PM Thread Starter
The ones that fit almost perfectly are called Maxxima 3/4" mini lenses. You can get them in clear or amber color on ebay. They come with rubber grommets which you won't need for the subframe mod. Use the stock rubber ends that are already on your subframe. Just cut or drill a hole into the rubber cap that's slightly smaller than the led so they fit snugly. Then it's up to you where you want to drill the exit holes for the led wires (near the battery box or closer to the rear). And I did buy an LED flasehr relay which was a simple plug-in mod.
post #8 of 17 (permalink) Old 08-30-2012, 07:48 PM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
off topic question: what tyres are those?
great looking indicators!
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #9 of 17 (permalink) Old 08-30-2012, 08:25 PM
sjw
Main Motorcycle: None
That's a nice look. Are they bright enough in daylight?
sjw is offline
post #10 of 17 (permalink) Old 08-30-2012, 11:26 PM Thread Starter
Tires are Dunlop TR91 dual sports. As far as indicator visibility, they seem to be fine during daylight. Although, I've only really seen them in close proximity to my bike.
Cracked subframe fix ralphus Sprint Forum 30 05-22-2013 03:43 AM
Red subframe on red '11+ S3? GotBoost2JZ Speed Triple Forum 10 03-06-2012 11:35 PM
Rear Subframe gettin2dizzy Speed Triple Forum 0 09-29-2009 11:27 AM
Need a new subframe... FrankD Hinckley Classic Triples 10 10-11-2008 08:21 PM
S3 subframe compatibility zeus_r6 Speed Triple Forum 5 04-13-2007 10:58 PM
