Bar end mirrors/Handlebar Question - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 06-12-2012, 12:33 PM Thread Starter
Main Motorcycle: 2008 Bonneville Black
I just recently bought a pair of the OEM Thruxton Napoleon bar end mirrors. I currently have hollow bars on my bike so I need to purchase new bars so I can use them. I dont have any plans on putting rearsets on anytime soon so I'm looking for a bar that will be a good medium between stock and clip ons. I will need a bar that has the threaded plugs and I'm thinking my only option is the M Bar from Norman Hyde. Are the M bars too extreme to use without rearsets? I was looking at the superbars but it doesnt seem like you can purchase those with a threaded plug.
Any suggestions would be greatly appreciated.
Bonne08 is offline
post #2 of 14 (permalink) Old 06-12-2012, 01:34 PM
Main Motorcycle: '07 Black
Easy13's Avatar
OEM Thruxton bars will work and obviously are threaded for your mirrors. You can mount them upside down for a little bit of rise. They're pretty comfortable, like a narrower version of NH M-bars. Here's a lousy cellphone pic to give you some idea of the handgrip position. The bars are inverted, with a set of home-made 1/2" risers.
Those bars (painted satin black) and the risers aren't in use anymore and I'd be willing to sell em off. PM me if interested.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #3 of 14 (permalink) Old 06-12-2012, 01:39 PM Thread Starter
Sweet. PMed. Thanks
Bonne08 is offline
post #4 of 14 (permalink) Old 06-12-2012, 01:51 PM
richm's Avatar
You CAN install them on your hollow bars! I recently asked the same question and here's the tip I got from prior.....
Originally Posted by prior View Post
Easily solved. You need something called a star fangled washer, sometimes called a star fangled claw also. They use them in the mountain biking world and they are fitted into the fork head tube and allows the headset cap to be screwed into the forks. basically exactly the same set up as the mirrors on our bars.
Ebay should have loads of 1" washers for sale cheap and theres some quite helpful guides on youtube for fitting them.
I bought a pair of 1" star nuts from my local bicycle shop for a couple of bucks each - they even have the same thread as the stock mirror bolts. I installed them in my new tracker style bars (1" bars) - they take a bit of banging in, just take it steady and make sure to keep them straight and not in too far. I then made a sleeve for each end using a piece of copper pipe so that the mirrors push in nice and snug, just like on the OEM bars. All bolted up, the mirrors are very secure.
richm is offline
post #5 of 14 (permalink) Old 06-12-2012, 02:10 PM
Forchetto's Avatar
Thanks Richm. I've been in this business for years and this is the first time I've heard of such a device. Great things:
Forchetto is offline
post #6 of 14 (permalink) Old 06-12-2012, 03:29 PM
richm's Avatar
I can't take credit for it - it was a tip from prior. Works very well and cheap too (for once).
richm is offline
post #7 of 14 (permalink) Old 11-05-2012, 12:14 AM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Just the info I needed. I love this site. Thanks guys
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is online now
post #8 of 14 (permalink) Old 03-19-2013, 11:07 AM
Main Motorcycle: '02 Triumph Bonneville
I'm bringing back this great thread because my recently purchased Napoleons just don't hold well in place using the supplied expansion bolt arrangement.
I found the 'star nuts' at a local bike shop and they whacked in well and seem firm in place, using a 6mm x 1.0 x 2.5" bolt with a lock washer and some blue Loctite. But the bike mechanic said 'not too much pressure on these', maybe less than 5ft. lbs.
Which makes me wonder if maybe a carefully placed 'dam' of JB Weld in front of the star washer wouldn't help hold it in place for some better tightening? Has anyone tried this?
Thanks
LapinAgile is online now
post #9 of 14 (permalink) Old 03-19-2013, 12:53 PM
Main Motorcycle: GasGas TXT Pro Trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Extra Motorcycle: Kawasaki KX250 2T
Nice to see you, Lapin! Haven't heard from you in a while. Would you happen to have a pic of these nuts? I've never heard of them. Thanks for resurrecting the thread.
I live my mirrors, but being universal (7/8" or 1") in my 1" bars, if I just bump them, they move and get loose. They'll stand up to the ton, but can't handle just a bump. I'd live to get them secured a little better.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #10 of 14 (permalink) Old 03-19-2013, 01:20 PM
Hey Bron - Yes, been busy and riding heavily but still read the good stuff here. Those star nuts are the bees knees. I picked up two 1" ones yesterday at a bike shop for 2 bucks each. They offer several sizes, but these knocked in firmly into my 1" stock bars. I used a long thin screwdriver as an install tool; place it squarely against the end of the bar giving a few sharp raps with the hammer inserting it perhaps 1/4" into the handlebar - Job done.
As I posted, I was leery of putting too much pressure on the bolt while tightening, not being used to these, so I went ahead and put a band of JB Weld on it to capture it firmly in place. Maybe unnecessary, but it made my OCD happy. Tomorrow I'll crank down hard with the blue Loctitie and lock washer; should be a permanent fix for those sagging beauties.
Here's a pic from Ebay: http://www.ebay.com/itm/Lot-of-5-Sta...item1c30984a05
I'm eager to see if this also will cure some vibration/distortion I was getting while using the supplied expansion bolts. It wasn't terrible but I'd like some improvement. Don't think you'll regret the effort here, it's gotta be better than as-sold.
P.S. My youth would have been complete had I spent a summer there at Bron-Yr-Aur...Can you imagine the quality of those 'refreshments'?...
Handlebar Inner Adapter for Weights / Mirrors imaginager Speed Triple Forum 15 08-04-2012 09:09 AM
Bar End Mirrors for 09 Thruxton Handlebar? FastFish Air Cooled Twins Technical Talk 1 02-19-2009 09:55 AM
Pics of S3 with new handlebar, grips, mirrors...etc. Dragon Speed Triple Forum 6 05-16-2007 05:08 PM
Bad vibrations - bar end handlebar mirrors Scrambler900 Air Cooled Twins Technical Talk 3 12-24-2006 09:26 PM
