Strange starting issue - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #41 of 391 (permalink) Old 10-10-2012, 07:33 PM
Main Motorcycle: Bonneville se
captainwoot's Avatar
Cool
My 12 se does this as well, no ryme or reason hot / cold etc....I though i had read somewhere on here that someone had traced the problem back to the starter relay...not sure if it was the relay itself or a connection issue. I havn't narrowed mine down yet not really a concern as it always starts.
"Evil Triumphs When Good Men Do Nothing"
captainwoot is offline
post #42 of 391 (permalink) Old 10-10-2012, 07:49 PM Thread Starter
Main Motorcycle: Thruxton
Any idea if it was the starter relay or starter solenoid? The starter solenoid has a couple single wire spade connectors packed with dielectric grease that are very easy to pop off. I have wondered if that connection was whats being flaky.
jesseoff is offline
post #43 of 391 (permalink) Old 10-11-2012, 12:04 AM
I am not sure, i thought it was with the relay itself, however if the solenoid connections do come off easily...maybe a good idea to try and crimp/tighten those connections
post #44 of 391 (permalink) Old 10-11-2012, 12:16 AM
I found this......
Originally Posted by Pauljp
I had a similar problem with starting my 2012 Bonnie.
It wouldn't crank on the first attempt, but always fired up on the second.
Forchetto wrote a great post about the starter relay.
I unplugged mine and plugged it back in (some people say to bend the relay pins a bit to make better contact).
Since I've done this I have not had a problem, it could be coincidence but so far so good.
Try it, it's free and takes a few minutes
post #45 of 391 (permalink) Old 10-13-2012, 10:45 AM
Main Motorcycle: 2012 Bonneville SE
sparky57's Avatar
2012 SE here and same problem. Thought it was me and didn't pay much attention to it. Will check the starter relay connections.
Sent from my DROIDX using Motorcycle.com Free App
sparky57 is offline
post #46 of 391 (permalink) Old 10-13-2012, 03:47 PM
Main Motorcycle: 2011 Bonneville SE
My '11 SE has had the same intermittent starting problem since new (10,500 mi, now). The dealer has replaced the solenoid and starter motor. I replaced the battery - which checkout fine - with a Shorai lithium-ion battery: Problem still exists, every 5 to 10 starts, hot-or-cold. 'Very frustrating.
Dexxter is offline
post #47 of 391 (permalink) Old 10-19-2012, 11:59 AM
Main Motorcycle: 2007 daytona
Mgiossi's Avatar
same problem here on my 2012 thruxton. brought it to the dealer. they couldnt find anything. just hope it doesnt leave me stranded one of these days
Mgiossi is offline
post #48 of 391 (permalink) Old 11-25-2012, 12:10 AM
Other Motorcycle: 2015 BMW R1200RT
Another data point --
I have a 2012 Bonne SE, purchased new in April, 2012. Have had this problem off/on since new, with no pattern that I have discerned. 1st time, attributed to low battery. Most recent time --
Friday, November 23, 2012. Battery fully charged. Temperature in garage where bike lives, about 55 degF. Bike started on first touch of starter button. Rode 3.5 miles @ 40-50 miles to Freeway, then 16 miles @ 70-75mph on Freeway to work. Parked bike. Worked a couple of hours, then went out to start bike to go to lunch. Hit starter button, bike clicked and nothing. Hit starter button a second time, bike fired right up. Rode about 6 miles to lunch. Ate (parked 30 minutes), bike fired right up @ first touch. Drove it two blocks, ducked into a store to run an errand, came back out. Bike fired right up @ first touch. Rode back to work. 3 hours later, came out, bike fired right up @ first touch. I have no idea why.
Jack
Birmingham, AL
Trophy4 is online now
post #49 of 391 (permalink) Old 11-25-2012, 12:37 AM
jeiser's Avatar
Other Motorcycle: 1977 CB550
My 2012 T100 does the same thing and has ever since I bought it. It's currently at the dealers now having an oil leak being fixed and I'm not even going to mention it to them because I have no faith in them finding a solution. I've just been living with it and if I just hold the starter button in it will fire up after it fails first.
_______________________
Jay
That's all the motorcycle is, a system of concepts worked out in steel. - Pirsig
jeiser is offline
post #50 of 391 (permalink) Old 11-25-2012, 01:38 AM
Main Motorcycle: 2012 EFI Thruxton 900
Hotboppincat's Avatar
Other Motorcycle: Honda CBF 125 2011
My Thruxton did this a couple of times....in my case there seemed to be a relationship between turning the ignition on before sitting on the bike and then putting the side stand up, then trying to start.
Mine kept turning half a turn and then stopping. I recycled the ignition by turning it off and on again and it was OK. I wonder if the ignition system gets a little confused sometimes?
I come from an era where we never had kick start or clutch lever sensors.
In my opinion, although they are safer (I can vividly remember nearly going through a shop window as a 17 year old on my RD125LC because I had forgotten to put my side stand up....), they are a bloomin' nuisance when they interfere with the start up of your vehicle, or go faulty.
And how on earth are you supposed to bump start your bike if the battery goes flat and you have a clutch sensor?????
My Wifes Honda CBF125 has a gear sensor, that cuts the engine if the stand is down when you drop it into first. Thats a much better idea!
Hotboppincat is offline
Strange starting issue Sparti Speed Triple Forum 8 10-23-2008 12:33 PM
Strange Starting Issue TBSstunta Hinckley Classic Triples 6 06-10-2008 02:16 PM
Strange LCD display issue voodoo_chile Speed Triple Forum 6 10-31-2007 07:03 PM
strange starting problem twinrider Tiger Workshop (archive) 4 09-13-2006 11:01 AM
Strange exhaust issue.... markfly Hinckley Classic Triples 7 10-13-2004 02:45 PM
