Strange starting issue - Page 11 - Triumph Forum: Triumph Rat Motorcycle Forums
 10Likes
post #101 of 392 (permalink) Old 12-10-2012, 04:03 PM
Newbie
Main Motorcycle: 2013 T100
Other Motorcycle: Harleys, lots of Harleys
Forchetto,
I am going to change seats on my T100 in the next day or so. I will look to see what battery the dealer installed and post back up here.
I really appreciate your insight. It's great to see your posts all throughout these forums.
I was surprised to see so many other with these same starting issues. Ugh...
jschenoweth is offline
post #102 of 392 (permalink) Old 12-10-2012, 04:17 PM
Forchetto's Avatar
Originally Posted by jschenoweth View Post
Forchetto,
It's only a guess and I hope the dealer has made an honest mistake. It's easily done, the batteries are usually stored on a separate shelf somewhere in the workshop and often they get a junior boy to do some of the pre-delivery work. The wrong battery can be easily fitted and often the commissioning procedure recommended by battery makers is ignored as well, making sure the battery will fail earlier and not deliver its full voltage throughout its life.
A further clue as to what battery should be fitted is the location of the cables. On the later, larger battery layouts, the cables come from the side of the battery (see previous photo), whereas on the earlier layout with the smaller one they come from the direction of the tank, as it were:
This is an earlier model:
Forchetto is online now
post #103 of 392 (permalink) Old 12-10-2012, 04:43 PM
so one needs the bigger battery, AIS removed, and the aftermarket headlite module.
cool!
strangely, my dealer told me NOT to ever use the choke. i have been lately.
HacksawsGarage
HacksawsGarage is offline
post #104 of 392 (permalink) Old 12-10-2012, 05:08 PM
Main Motorcycle: 2011 Bonneville T100
Extra Motorcycle: 1968 Honda CB350
Send a message via Skype™ to LWRider
Me, too! 2011 T100. Intermittent start failures exactly as described. On the other hand since March I have put on over 10,000 miles, in botjh freezing and hot temps and not once did my Bonnie fail to run after an initial start failure. I mentioned this to the tech at my dealer and suggested it might have to do with the motor being stopped at a point of high compression, requiring more oomph to spin it and that once it makes that first faltering attempt it is at another place in the cycle and spins up. He nodded in agreement, for what it's worth.
Cheers,
Mike
LWRider is offline
post #105 of 392 (permalink) Old 12-10-2012, 06:52 PM
Main Motorcycle: Bonnie T100
I had the same problem with my 2010 bonnie.
Then i read the hand book about using the choke at every start,Hasnt happend agian i did feel a bit silly not reading the manual first.Wont do that again.
markburton68 is offline
post #106 of 392 (permalink) Old 12-11-2012, 12:28 AM
Forchetto's Avatar
As you can read on HacksawsGarage post a little earlier, post 103, even dealers ignore the starting procedures as laid out in the handbook. A huge percentage of the starting problems people are having are due to this.
If you live in a temperate area where the temperatures don't drop much you can get away with it, but as temperatures drop it becomes progressively more important to stick to the recommendations.
post #107 of 392 (permalink) Old 12-12-2012, 12:44 PM
Main Motorcycle: 2012 Bonneville SE
Bob D.'s Avatar
Other Motorcycle: Honda GB500 TT
Extra Motorcycle: Honda Nighthawk 250--sold
Originally Posted by Turnertwin View Post
Well, sure.
Mr. Broad is quite right. The Triumph is a very nice bike; I'm quite fond of my '11 T100. Do I consider it completely reliable? As I consider my Harley or V-Strom reliable? No, of course not. I don't want to be far, far from a Triumph dealer - which in the US is most places - and have it fail to start. It is, perhaps, a little too retro.
Lovely to look at, nice to ride, probably wouldn't buy it again.
Jeff
FWIW, I don't feel that way at all. I love my bike and at this point consider this "strange starting issue" more a minor curiosity than a problem. I posted previously in this thread because I had an instance of this issue and I wanted to know more about what might be causing it. However, I have only had the issue appear once more since that post, and I've probably started the bike 30 times since then. (And BTW, thanks to a tip in this thread, I merely kept the starter button depressed after its initial 2-second crank, and it immediately cranked again and fired. To me, that is not even at the level of inconvenience.)
Lastly, I think all the best evidence points to this being a minor voltage drop/ECU program issue that has nothing to do with choke position. I have never used the choke when starting my bike (sorry, I know all the RTFM devotees are right now mentally lining me up for the firing squad) and it always starts quickly and runs smoothly. Personally I don't see the value in forcing my stone-cold engine to idle at higher RPMs when it starts just fine without the "choke" aka fast-idle control.
Just my $.02, but I think for most or even all of those about whom I've read, this is more a minor puzzle than a debilitating issue. My personal take is to check the battery size and condition per the excellent info earlier in this thread, keep the starter button depressed during those occasional instances when the bike doesn't fire after the initial 2-second crank, swing a leg over and enjoy!
Happy to Be Here, in every sense of the phrase
Bob D. is offline
post #108 of 392 (permalink) Old 12-12-2012, 03:52 PM
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Other Motorcycle: 2002 Tiger 955i
Extra Motorcycle: Mrs. Jayell's '13 CB500F
Originally Posted by Forchetto View Post
This is what your underseat layout should look like, this is on a Thruxton but I think the larger battery is now fitted to all Bonnies, note the battery model:
Hey, nice bike! I think it's mine.
BTW, I too experience this occasionally, and simply ignore it. When mentioned to my dealer, they said "Gee, we've never heard of that before." Who'd a thunk it?
Jayell is offline
post #109 of 392 (permalink) Old 12-13-2012, 10:39 AM
Main Motorcycle: "Thai" Triumph T100
Other Motorcycle: Previous: 1970 Bonny
Extra Motorcycle: Learned on Sports Cub
Perhaps leaving the kickstart in place would have been a great backup solution - getting too old to run and bump start like I used to when I was in a hurry!
wyomingpat is offline
post #110 of 392 (permalink) Old 12-13-2012, 01:35 PM
Main Motorcycle: 2011 Thruxton SE
I have had this issue on my bike since it was new. The battery can be fully charged or not, choke in or out, engine hot or cold... It still acts up about every tenth time I start (but never twice in a row). My dealer has been over the bike, taken apart the wiring, swapped starter relay and battery to no avail. Finally they contacted Triumph, and they allegedly claimed that this is "normal behaviour", that a reset of the start procedure will be triggered if the crank position can't be determined fast enough. That could be true, but I also think that the explanation that high resistance if you start in a compression phase could cause this sounds plausible.
Although nobody would accept this on a new car, I agree that the problem is minor. I will absolutely try the suggestion to hit the starter quicker, and mot wait for the instrument self-test to complete. But wouldn't it be great if Triumph could get a fix out, or at least issue some statement about this.
kerfuffle is offline
Strange starting issue Sparti Speed Triple Forum 8 10-23-2008 11:33 AM
Strange Starting Issue TBSstunta Hinckley Classic Triples 6 06-10-2008 01:16 PM
Strange LCD display issue voodoo_chile Speed Triple Forum 6 10-31-2007 06:03 PM
strange starting problem twinrider Tiger Workshop (archive) 4 09-13-2006 10:01 AM
Strange exhaust issue.... markfly Hinckley Classic Triples 7 10-13-2004 01:45 PM
