20 minute auto-tune results - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 06-01-2012, 09:36 PM Thread Starter
jeiser's Avatar
Other Motorcycle: 1977 CB550
Performed the auto tune this evening on my 2012 T100.
Mileage: 475
Bone Stock, AI still in place.
I had a hand held leaf blower handy to keep the engine nice and cool.
After the 20 minutes I let the bike cool down for about 15 minutes then took it for a spin around the neighborhood.
Prognosis: Throttle is still snatchy and don't notice anything different about the ride.
At least now I know anyway. I don't have any intentions of removing the AI while I am still under warranty however I may do the old marble trick to temporarily disable it.
I guess it is just hit or miss whether the 20 minute tune makes any measurable difference. Or perhaps my bike is already mapped as good as it can get for my altitude conditions.
jeiser is offline
post #2 of 17 (permalink) Old 06-01-2012, 09:56 PM
Main Motorcycle: 2012 Bonneville named Mae
The bike will not "auto-tune". It will do an adaptation. The map is the tuning part, and yes your AI removal will help with throttle snatchiness
2012 Gold Bonneville: Predators, ARK, K&N, AI and o2 gone, and a really sweet tune. :)
"Why didn't you get the Harley?" ...."Because I test drove them both ;) "
jps0917 is offline
post #3 of 17 (permalink) Old 06-01-2012, 10:26 PM
Main Motorcycle: T100
Dan McGrath's Avatar
You may want to break in this machine before messing with it. 475 miles?
Dan McGrath is offline
post #4 of 17 (permalink) Old 06-02-2012, 12:06 AM
sprouty115's Avatar
Temporary disabling the AI will have no adverse effects on the engine, broken in or not. Think about it - How could getting rid of the light-switch throttle response and lowering the temps in the muffler be bad?
I found a 9/16" ball bearing, added a little coating of grease and slid it into the tube. Put a zip-tie on each side and then shoved the tube back in the box. I never even took off the seat. The whole process took 3 minutes. An absolutely noticeable difference.
Btw, my bike has 400 miles on it.
sprouty115 is offline
post #5 of 17 (permalink) Old 06-02-2012, 12:16 AM Thread Starter
jeiser's Avatar
Thanks....I believe this is the method I intend on doing since I don't really want to rip everything off the bike that has to do with the AI. If I can just disable it then I am fine with that. My pipes are already starting to yellow/blue all the way to the first bend in the pipe coming out of the engine cylinders....I'm mostly fine with it, but if I can keep it from getting worse and perhaps help with the throttle snatchiness I think it is a win.
jeiser is offline
post #6 of 17 (permalink) Old 11-23-2012, 05:26 PM
Main Motorcycle: Triumph Bonnie 2012
exlimeydedbt's Avatar
???????? Were do I find ........the old marble trick on here
exlimeydedbt is offline
post #7 of 17 (permalink) Old 11-23-2012, 09:54 PM
sprouty115's Avatar
post #8 of 17 (permalink) Old 11-24-2012, 12:26 AM
Main Motorcycle: 2011 Bonneville Elizabeth
dam1's Avatar
Other Motorcycle: wish i could !!!
Be aware with marble trick you get water in the tube where the marble is , then if it's a bearing it will rust.
best is take everything off, some dealers are saying you keep waranty even so.
dam1 is offline
post #9 of 17 (permalink) Old 11-24-2012, 05:59 AM
triumphrat.net Vendor
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
Other Motorcycle: 2008 Bonnie Black
Without carrying out the reset adaption electronically within your ECM, the 20 minute idle will achieve nothing. You've missed out the first part of the process.
Mike (UK)
PieMan is offline
post #10 of 17 (permalink) Old 11-24-2012, 09:02 AM
sprouty115's Avatar
I checked mine twice over the summer and didn't see any evidence of water, but I still agree with your comment and in fact just ordered the AI kit to get rid of it completely.
- Stephen
12 minute tune ishmael The Rocket Science Forum 12 05-11-2016 01:50 AM
What is the 12 minute tune? lxtoploader Speed Triple Forum 5 07-09-2010 11:06 AM
12 minute ECM auto tune feature? Steve Block Air Cooled Twins Technical Talk 17 06-29-2010 12:46 AM
12-Minute Tune? pbbeck The Rocket Science Forum 8 07-12-2007 07:55 PM
12 minute tune Disco The Rocket Science Forum 7 08-04-2006 07:50 AM
