20 minute auto-tune results - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 11-24-2012, 08:24 AM
Forced Adaption Procedure
According to the Triumph in-house Training Support Notes: Engine Management & Electrics manual a Keihin EFI equipped bike can be adapted without resetting the ECU/ECM. Here is the Triumph factory-approved method verbatim from the manual:
1. Ensure coolant is at ambient temperature
2. Start engine and allow to warm without touching the throttle until the fan comes on
3. Leave the engine to idle for a further 12 minutes.
Important Note: This procedure assumes the bike has a Lambda 02 Oxygen Sensor connected and is therefore a closed loop system
DeanRider is offline
post #12 of 17 (permalink) Old 11-24-2012, 07:14 PM
Main Motorcycle: 2010 Scrambler
ScramblerKidd's Avatar
My 2010 Scram has been running for over two years now....The cooling fan never came on.
ScramblerKidd is offline
post #13 of 17 (permalink) Old 11-24-2012, 07:47 PM
sprouty115's Avatar
Heh, heh...
- Stephen
sprouty115 is offline
post #14 of 17 (permalink) Old 11-24-2012, 11:31 PM
Main Motorcycle: Scrambler
Olhogrider's Avatar
Other Motorcycle: Sold
Extra Motorcycle: Gone
I have done the a/i and the o2 as well as the airbox baffle and a Breathe bellmouth. I used the TTP map. The bike runs perfectly! If Pieman says it, you can believe it.
Damned Dirty Biker!
Olhogrider is offline
post #15 of 17 (permalink) Old 11-25-2012, 12:29 PM
Main Motorcycle: 2012 Scrambler
warrewp's Avatar
Extra Motorcycle: 2015 Moto Guzzi V7 II
I've been dying to do this to my scram (the TTP maps) but I'm still waiting on my OBDII cable to get here! So anxious to see this happen. I guess I need to invest in the AI removal kit too.
warrewp is offline
post #16 of 17 (permalink) Old 11-25-2012, 12:40 PM
Main Motorcycle: 2011 Bonneville Elizabeth
dam1's Avatar
Other Motorcycle: wish i could !!!
no need to invest my friend, you have everthing available in your house apart from the 2 Nissan oil bolt you can buy in car shops everywhere.
dam1 is offline
post #17 of 17 (permalink) Old 11-25-2012, 12:42 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Originally Posted by jeiser View Post
At least now I know anyway. I don't have any intentions of removing the AI while I am still under warranty however I may do the old marble trick to temporarily disable it.
Better to use a plastic plug of the correct size than a marble. My Triumph specialist/mechanic removed the rubber hose from the air box on the left side of the bike, inserted a plug from his spares (maybe a packing cap from a part) and re-inserted the tube. Throttle snatch disappears, as does much of the bluing of your header pipes. So..., do it now. You'll like it.
lambroving is online now
12 minute tune ishmael The Rocket Science Forum 12 05-11-2016 12:50 AM
What is the 12 minute tune? lxtoploader Speed Triple Forum 5 07-09-2010 10:06 AM
12 minute ECM auto tune feature? Steve Block Air Cooled Twins Technical Talk 17 06-28-2010 11:46 PM
12-Minute Tune? pbbeck The Rocket Science Forum 8 07-12-2007 06:55 PM
12 minute tune Disco The Rocket Science Forum 7 08-04-2006 06:50 AM
