Pics of (EFI) airbox baffle ? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 51 (permalink) Old 12-06-2012, 09:46 AM
Main Motorcycle: 06 Bonneville 790 Carb
AlexBB's Avatar
Other Motorcycle: HD Crossbones
Extra Motorcycle: Sold Daytona 1200 SE #136
Hi Pieman,
Thanks for the heads up on the jet sizing..
I have had a look today to get some others ordered for when I book the Dyno run and also seem to get some some shims. (the Jenks guide didn't list I needed these for the 06, so I never ordered any to start with)
I managed to sort out the proper Keihin part numbers for the jets;
Mains being 99101-393-size
and pilots being N424-25B-size
But I am having issues on the forums and internet finding a proper Keihin part number for the shims !! the company I have ordered stuff off are OK as long as I can give them the Keihin part numbers as they don't list the CVK36 carb... Can anyone help?
I have read elsewhere on the forum that it is best to use genuine Keihin as they are ground and not punched..is that right?
The Jenks guide also says the 06 needle (code NFCD) is different to the earlier stock ones (code NAGB) and does not need changing to the Thruxton one (code NBTZ)... Can anyone help on this? Has anyone else had any experience with an 06?
I don't want to bother paying out 17 for new needles if I don't need to..
AlexBB is offline
post #22 of 51 (permalink) Old 12-07-2012, 01:21 AM
Askari's Avatar
sealant
Originally Posted by Junipero View Post
STW; I just cleaned the old sealer off and bolted it back up. I have been wondering about that though. I probably should have put new sealer back on there. It was so tricky to access that I guessed it would be a messy job to seal it on is side like that.
I don't know whether it's leaking a bit of air or not. But I'm sure the idea in my head that it's not sealed will nag me enough that I'll pull the whole box out and neatly reseal the gasket.
When i did mine i used the same sealant as triumph use. I am sure that a silicone sealant will do just as well. I cleaned the oem gasket up and scrpped of the original sealant first. Screws come out easier the 2nd time!. For the tricky suckers some thin vice grips work well if a bit tedious. The screws when removed can be shortened and filled square on the heads then you can replace with a small spanner
Askari is offline
post #23 of 51 (permalink) Old 12-12-2012, 08:25 AM
AlexBB's Avatar
Hi
I would be very grateful if someone could point me in the right direction with my questions above?
I have searched but cant seem to find the right level of info..
I apologise in advance if this is the wrong place to post this... If I would be better starting a new thread let me know.
Thanks
Alex
AlexBB is offline
post #24 of 51 (permalink) Old 12-15-2012, 07:33 PM
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Other Motorcycle: 2002 Tiger 955i
Extra Motorcycle: Mrs. Jayell's '13 CB500F
As you guys are talking about re-jetting after removing the air box baffle, I assume a re-map would be necessary for EFI bikes?
My bike is stock at the moment (except for AI removed), but will be installing TORS and would like to remove the air box baffle next spring. What map would be suitable for a 2011 Thruxton?
Thanks!
Jayell is offline
post #25 of 51 (permalink) Old 12-15-2012, 11:54 PM
Forchetto's Avatar
Thanks!
TTP EFI performance tune 2 probably, although if you're going to remove the baffle you might as well get rid of the intake snorkel to get the full benefit.
http://www.triumphtwinpower.com/thru...nce-tune-2.php
Forchetto is offline
post #26 of 51 (permalink) Old 12-16-2012, 04:38 AM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
Alex, try www.allensperformance.co.uk for you shims and jets.
Mike (UK)
PieMan is online now
post #27 of 51 (permalink) Old 12-17-2012, 04:28 PM
Jayell's Avatar
Right, many thanks Forchetto, though I'm not sure I want to go to the extent of removing the O sensors.
Jayell is offline
post #28 of 51 (permalink) Old 12-18-2012, 02:37 AM
Main Motorcycle: '06 Tiger 955i
Hi Jayell,what is your concern about O sensor removal? They are only operative for 0 to 6% of the throttle, plus the fact that in the new tune the fuelling is optimised so doesn't need the correction factor of these sensors.
PS Just noticed that TTP have put up their tune prices a fair bit since I got mine.
2006 Tiger 955i ally wheels
thebiglad is offline
post #29 of 51 (permalink) Old 12-18-2012, 11:29 AM
Main Motorcycle: 2009 Triumph Bonneville
Cruzin1a's Avatar
I have the right side cover removed and the baffle removed. I cleaned up the sealer on that right side cover but I have to admit I didn't find a gasket. I'll check the service manual when I get back home.
Cruzin1a is offline
post #30 of 51 (permalink) Old 12-18-2012, 08:08 PM
Cruzin1a's Avatar
Wow the Haynes manual barely mentions the air box. No mention of a gasket on the right side at all.
Cruzin1a is offline
My diabolical plan- Airbox, AI, and baffle removal MikeandLisa Air Cooled Twins Technical Talk 5 05-25-2012 08:38 PM
airbox removal - jack bike way up to get airbox out? Thruxo Air Cooled Twins Technical Talk 2 04-07-2012 05:12 PM
Airbox Elimination Pics Please marc hanna Cruisers - America, Speedmaster 18 07-07-2010 01:42 PM
Removed the airbox baffle plate from Scrambler - tip BrianM Air Cooled Twins Technical Talk 0 10-18-2007 03:21 PM
Remus sp3 2005 exhuast - Removeable Baffle - pics VB-SP3-2005 Speed Triple Forum 0 12-11-2005 08:51 PM
