Joker Ignition Relocation help... - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 23 (permalink) Old 04-26-2012, 07:01 AM Thread Starter
Main Motorcycle: 2010 Triumph Bonneville
fullspeed's Avatar
Question Joker Ignition Relocation help...
Quick question. Got the Joker machine ignition relocation bracket. Is there any wiring involved or do I just relocate the original wires. There's no mention of any wiring or soldering on the BC or the JM website.
fullspeed is offline
post #2 of 23 (permalink) Old 04-26-2012, 07:17 AM
Main Motorcycle: '07 Black
Easy13's Avatar
I had to do no wiring on mine; the switch isn't relocating that far away. The whole job took maybe 30 minutes.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #3 of 23 (permalink) Old 04-26-2012, 07:24 AM Thread Starter
fullspeed's Avatar
Thanks Easy13!
post #4 of 23 (permalink) Old 06-07-2012, 03:35 PM
Main Motorcycle: 2016 Tiger 800 XRx
RSDA's Avatar
The Joker component uses the stock frame screws, right? Do you know how hard those need to be torqued back down?
Thanks.
RSDA is offline
post #5 of 23 (permalink) Old 06-07-2012, 05:21 PM
Main Motorcycle: 2012 Tiger 800
TX1911fan's Avatar
No, the Joker one comes with new screws. I just tightened them tight, didn't torque them. I probably should have.
TX1911fan is offline
post #6 of 23 (permalink) Old 06-07-2012, 11:07 PM
Main Motorcycle: 2014 R1200GS LC
Texascat's Avatar
Other Motorcycle: 2012 Speed Triple R
I just installed a kit similar to the joker and the cable was not long enough out of the headlight. I had to pull out the connector to get more slack. I tucked in the connector behind the headlight, behind the ear.
Odd enough a friend of mine has a similar set up on his 06, but no issue with the wiring. My is an 07. I guess mine must have had a shorter wire.
I believe the screws will need to be torqued to 45 nm.
Sent from my iPhone using MO Free
2014 BMW GS 1200W
2012 Triumph Speed Triple R
Texascat is offline
post #7 of 23 (permalink) Old 06-07-2012, 11:20 PM
Main Motorcycle: Thruxton
parko's Avatar
For my EFI 2009 Thruxton i had to do a bit of re-jigging inside the headlight to get enough cable out. The other thing i found is that the frame bolts supplied had a different thread to the OEM nuts so had to get some new nuts to get it all hooked up...
parko is offline
post #8 of 23 (permalink) Old 06-13-2012, 12:32 PM
Main Motorcycle: Hat Creek Build#1
AULT's Avatar
flip the ignition backwards to get the most slack
AULT is offline
post #9 of 23 (permalink) Old 06-25-2012, 09:30 PM
Other Motorcycle: Vespa ET4
Ignitition relocation bracket
Hi,
Do you have a picture you can post of this? I am having the same problem, wires not long enough out of the headlight. I have a 2011 t100.
Thanks!
Sean
seanst100 is offline
post #10 of 23 (permalink) Old 06-25-2012, 11:06 PM
TX1911fan's Avatar
I did the right hand side mount and had to mount the ignition upside down to fit. No big deal.
Sent from my iPad using MO Free
Joker Ignition Relocation Problems gpat Air Cooled Twins Technical Talk 6 12-01-2011 06:01 PM
ignition relocation Scardi The Rocket Science Forum 0 04-20-2007 02:08 PM
ignition relocation.... kidkazi Air Cooled Twins Technical Talk 3 03-31-2007 10:01 AM
Relocation of Ignition switch? Yogi The Rocket Science Forum 6 10-17-2005 11:38 PM
