Stuck oil filter! - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
post #31 of 41 (permalink) Old 12-02-2012, 01:11 PM
Main Motorcycle: 2011 Thruxton
Nick Goodwin's Avatar
Other Motorcycle: not yet, soon.
I avoid that problem by installing my filters with a dishwashing glove on for grip and get it as tight as I can by hand.
Nick Goodwin is online now
post #32 of 41 (permalink) Old 12-03-2012, 06:29 AM
+1, that all I do, never had a prob.
Plasma.
plasma is offline
post #33 of 41 (permalink) Old 12-03-2012, 12:02 PM
Main Motorcycle: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I kept: '69 Trident
Try a thin coat of Dow Corning DC-4 silicone grease on the filter gasket before installation. I've been using the same tube of DC-4 on bikes, planes and boats for more than 30 years and it's still half full.
http://www.aircraftspruce.com/catalog/cspages/dc4.php
Also FAA approved
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; Hagons, PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline
post #34 of 41 (permalink) Old 12-03-2012, 02:51 PM
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
I'm going to try the Silicon grease after all if it doesn't dry out after thirty years, it isn't going to, is it?
Thanks for the tip!
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is offline
post #35 of 41 (permalink) Old 12-03-2012, 03:05 PM
Forchetto's Avatar
Thanks for the tip!
I still have a tube of Dow Corning DC4 silicone grease that I nicked from work nearly 30 years ago and it's still as fresh as the first day.
It can be used for insulating, lubricating, heat transfer, dielectric compound, etc, etc.
Whenever you remove things like car water coolant hoses, vacuum pipes, etc smear a bit on the connection. Years later they come off without effort.
If you really hate someone, smear it over his windscreen, it's impossible to remove completely...
http://cpc.farnell.com/1/1/42871-sil...w-corning.html
Forchetto is online now
post #36 of 41 (permalink) Old 12-03-2012, 03:29 PM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
I know that I am going to get flak for this; but, while it does no harm, putting a smear of oil on the gasket is not needed. That advice is just to make sure that the average person changing the oil filter makes a last check to make sure that there is a rubber gasket present.
Stuck filters are primarily due to over tightening and/or turning the wrong way.
I don't put oil on the gaskets of my oil filters and I only tighten them hand tight. Never had a problem in many years with many cars, trucks, motorcycles, tractors, and other small engines.
norton74 is offline
post #37 of 41 (permalink) Old 12-03-2012, 04:32 PM
Mmmmm, well I've seen O rings torn when applied dry. So for me I will always use a lubricant to apply an O ring. But I have no doubt that it can be done dry, but for me its not worth the risk.
post #38 of 41 (permalink) Old 12-03-2012, 04:37 PM
norton74's Avatar
The torn O rings that you saw, were they the result of hand tightening or tightening with a wrench?
Like I said, smearing a little oil or other lube won't hurt. It if feels better, do it.
norton74 is offline
post #39 of 41 (permalink) Old 12-03-2012, 05:19 PM
dkreidel's Avatar
Yep, it's good stuff! Don't get DC5 or DC12; one's runny and the other's snotty.
dkreidel is offline
post #40 of 41 (permalink) Old 12-04-2012, 04:26 AM
+1, thats strange,but I did the same thing,nicked a tin from work,had same tin 20 years, and its still good to go.
Plasma.
plasma is offline
Removing $#%!!!@#$ Stuck Oil Filter mecscc Air Cooled Twins Technical Talk 40 05-08-2017 09:13 PM
Stuck Oil filter morvegil Sprint Forum 34 12-24-2010 02:31 PM
Oil Filter stuck crambuster Air Cooled Twins Technical Talk 17 11-17-2008 10:36 PM
oil filter stuck fif955 Tiger Chat 5 01-06-2008 05:40 AM
stuck oil filter luiz Daytona Deliberations 18 08-22-2007 10:12 PM
