Stem broke on Odometer knob! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 04-03-2012, 07:48 PM Thread Starter
Other Motorcycle: Yamaha YZ250f
My stem broke off my odomerter knob and this is how I gauge my fuel tank. I keep the piece in my jacket and can shove it in after I fill my tank and reset to 000. Can I replace just the know or do I have to get a whole new speedo assy? Anyone else have this happen, its an 06 T100
Natehman is offline
post #2 of 8 (permalink) Old 04-03-2012, 07:50 PM
Main Motorcycle: European Bikes
tooblekain's Avatar
Other Motorcycle: 2006 Triumph Daytona 675
Extra Motorcycle: 2007 Triumph Bonneville
Send a message via AIM to tooblekain
Is the really tiny screw that holds it in place still there? If so you can probably use your broken off piece to hold it from rotating as you loosen it out.
tooblekain is offline
post #3 of 8 (permalink) Old 04-03-2012, 07:59 PM
Main Motorcycle: 2008 Bonnie Black
ruger's Avatar
Other Motorcycle: 2007 HD Total Loss
http://www.bikebandit.com/2006-trium...7636#sch568213
Hope this helps Natehman.
See 10 and 11 on the chart and diagram
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/D9 Dash/520 chain/Denalis/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is online now
post #4 of 8 (permalink) Old 04-03-2012, 08:00 PM
It's a number 0 Philips screw in there. If it's the knob that's broken, you can buy it separately.
Edit: I see that Ruger beat me to it. So there's your answer. If the stem itself is broken, I think that you're out of luck.
Marty
Baltobonneville is offline
post #5 of 8 (permalink) Old 04-03-2012, 08:04 PM
ruger's Avatar
If it works by sticking the piece in it seems it should be able to be replaced.
Guessing here.
Ruger
ruger is online now
post #6 of 8 (permalink) Old 04-04-2012, 05:12 AM
Main Motorcycle: Bonnie
Dave2001's Avatar
The screw may have just come out and your 'broken' knob could still be complete. Check this thread out and my comments at post #15
http://www.triumphrat.net/twins-tech...ell-off-2.html
Or go straight to the post where I describe my fix at post #8 http://www.triumphrat.net/twins-tech...eset-knob.html
Dave
Dave2001 is offline
post #7 of 8 (permalink) Old 11-19-2012, 03:26 PM
Main Motorcycle: Thruxton 900 "Crumpet"
asp125's Avatar
Other Motorcycle: Triumph Street Triple R
Extra Motorcycle: Can Am Spyder RS
Dammit the same thing happened to me this weekend. I fiddled with my speedo and the knob fell off! That'll teach me to play with my clock. Lucky I didn't go blind.
06 Thruxton 900 Crumpet \ 08 Can Am Spyder big bird \12 S'TripleR
SpeedShots Photography
asp125 is offline
post #8 of 8 (permalink) Old 11-20-2012, 05:12 AM
Main Motorcycle: Thruxton 04
Other Motorcycle: Ariel VHA Special
Extra Motorcycle: Honda Pan European ST1300
This is a common one usualy the screw comes out and you lose the knob.....Replace the knob and screw then push Plastocene or Bluetack right down the hole to stop the screw undoing....you can allways dig it out if you want to remove he knob.....
T.U.D.
tonupdave is offline
Speedo Odometer Reset Knob bonza Air Cooled Twins Technical Talk 9 02-14-2011 07:55 PM
Broken Trip Odometer Knob ajcdturner Air Cooled Twins Technical Talk 2 03-26-2009 11:15 AM
Help: Anyone have an odometer reset knob?? dave1068 Air Cooled Twins Technical Talk 11 03-16-2008 12:25 AM
Odometer select knob. rusty The Rocket Science Forum 1 10-01-2006 08:11 PM
Odometer reset knob kevco Air Cooled Twins Technical Talk 9 09-14-2006 10:24 PM
