Broken Crankcase 2002 Bonneville - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 94 (permalink) Old 03-06-2012, 11:31 PM
Main Motorcycle: 2010 Scrambler
ScramblerKidd's Avatar
By the time you buy a new cover and have the case repaired...I'd find an 865 and swap out. In the process you gain a little cubes.
ScramblerKidd is offline
post #22 of 94 (permalink) Old 03-07-2012, 03:35 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
I really wouldn't mess with welding the crankcase.
sweatmachine is offline
post #23 of 94 (permalink) Old 03-07-2012, 04:48 PM
Main Motorcycle: '03 Triumph Bonneville
And swap the 790 cams into it... then you have the best of both (OEM) worlds!
I know it seems like a lot of expense... but overall, buying a clean, low mileage used engine from Pinwall is the best option... the freight can be a bit of a bugger... but you get an easy swap out fix and can "buy back" years and miles by buying a newer, lower mileage engine than is in there now...
SCbonneville is offline
post #24 of 94 (permalink) Old 05-11-2012, 04:59 PM Thread Starter
Main Motorcycle: Bonneville
Other Motorcycle: Adventurer
Extra Motorcycle: Sportster
Problem resolved
Today I fixed the problem with a pin through the shaft that fits the starter gear. I got a used clutch cover from Pinwall for $60. I still drilled the cover 1/4 inch. The drilled hole in the crankcase is about 3/8 inch. I've started the bike a dozen times and it sounds strong.
Thanks, very much, everyone for the help.
Regards,
Bonavent
Bonavent is offline
post #25 of 94 (permalink) Old 05-11-2012, 10:38 PM Thread Starter
Thanks Max
Thanks Max. Your PM file is full.
Bonavent is offline
post #26 of 94 (permalink) Old 05-12-2012, 11:13 AM
Main Motorcycle: My brickwall Bonnie
MohawkBri's Avatar
Kudos for getting it fixed
MohawkBri is offline
post #27 of 94 (permalink) Old 05-12-2012, 06:15 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
Good deal hope it last for you man.
mikeinva is offline
post #28 of 94 (permalink) Old 11-09-2012, 05:18 PM
Slinky's Avatar
Extra Motorcycle: I wish
Mine has broken too... it's the only thing that made me reluctant to buy a twin in the first place (apart from the coils, and igniter, which have all had to be replaced).
I'm planning to attempt to fix it with the drill bit mod tomorrow.
Slinky is offline
post #29 of 94 (permalink) Old 06-16-2015, 09:53 PM
Main Motorcycle: 2010 Triumph Thunderbird
Red face
Hey, I have a cracked piece in same place as the gentleman in this string. Fell on right side but starter gearshaft area on left is what's cracked. Looking at replacement engines on eBay for my 2005 Speedmaster for around 1500-1700. One is from Pinwheel. If you're saying you've not had problems with them, that's very heartening. I'm going to give them a try. Thanks!
Attaching pictures that were just taken from my 2005 Speedy with 39,000 miles. Actually laid it over (not going very fast) on RIGHT side, but then when I tried to start, it seemed like a starter issue, and lo and behold the same type of break as the other pics on here. I'm interested in getting a Pinwheel replacement engine, but then again -- wonder if the same thing could happen??
Name:	Speedmaster case crack.jpg
ID:	271386   Click image for larger version
Name:	Speedmaster cracked piece.jpg
05 Speedy is lost to the universe. Just had a reunion with its big brother the 2010 T-Bird, so decided to make it mine. Much thanks to Team Triumph of Janesville.
Mettlehed76 is offline
post #30 of 94 (permalink) Old 06-16-2015, 11:17 PM
Forchetto's Avatar
It could unless you install this preventive item, TTP's "safe start" reinforcing piece:
http://www.triumphtwinpower.com/ttp-safe-start.php
Forchetto is offline
2002 Bonneville 02bonnieryder The Welcome Center 1 07-13-2010 06:04 PM
79 Bonneville crankcase venting Snakepit Classic, Vintage & Veteran 3 01-31-2009 12:41 PM
help any one with a broken speedo (bonneville) adolfo73 Air Cooled Twins Technical Talk 6 02-26-2008 11:37 AM
Bonneville Changes since 2002 OPCal Air Cooled Twins Talk 11 01-30-2006 07:20 PM
