2011 t100 vibration on front- help please - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 12-04-2011, 07:02 PM Thread Starter
Main Motorcycle: '11 T100 EFI
Other Motorcycle: 7 ply maple skateboard
Extra Motorcycle: '76 Honda cb200t
Yep. Bought a brand new t100 black a few months ago. I noticed some vibration coming from the front at around 40-55 mph. It's not terrible, just a little annoying. I immediately called the dealer. They said they'd have to check it out. I took the bike in after clocking just under 1000 miles. The dealer told me "it's the nature of the beast". I've got about 2200 miles now and changed the handle bars and there's been no change. Anyone else had a similar problem?
welfarebanks is offline
post #2 of 16 (permalink) Old 12-04-2011, 07:16 PM
Askari's Avatar
Nature of the beast!
Sounds like your dealer is related to a bull! Did the vibs happen all of a sudden? If so check for the tyre balance weight on the wheel, doubt that it has fallen off.
Did the dealer check all the triple clamps for tightness, head bearings adjustment, fork alignment,spokes(is it spoked), tyre pressure and wheel true.
If you are a bit savvy or have a manual check all these yourself. Otherwise the forum will guide you.
Askari is offline
post #3 of 16 (permalink) Old 12-05-2011, 06:13 AM Thread Starter
It happened on the ride home from the dealer. The first thing I thought was wheel balance because there looks like theres more wheel weights on the front wheel than I've ever seen. When I took the bike in for the first service I told them about the vibration. I know they trued the wheel, but honestly not sure what else they looked at. It always vibrates between 40-55mph on acceleration and deceleration and cruising. It's not violent cause if it was I'd be more aggressive on fixing it. Outside of tire pressure I'm not sure if I could check the other things.
post #4 of 16 (permalink) Old 12-05-2011, 10:50 AM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
What kind of tires are on the front ? Have they worn funny or have a flat spot in the middle ? Most important is check your tire pressure. Also just for the heck of it, check your bar end weights, who knows they could be loose and acting a little weird.
BTW weird is a very technical term .........
Ride safe,
Quentin
wenzel850 is offline
post #5 of 16 (permalink) Old 12-05-2011, 12:08 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
Your dealer is an !@#$. A vibration at the speed is an out of balance wheel front wheel or a bead not seated correctly.
DUCKMAN is offline
post #6 of 16 (permalink) Old 12-05-2011, 05:22 PM
Main Motorcycle: 2010 Speedmaster
Hyates's Avatar
Might be a bad tire
I had a bad front Metzeler on my 2010 Speedmaster. Caused all kinds of vibration issues at various speeds. Balance, forks, front end, wheel alignment was checked, and the tire was actually faulty. Replaced by my dealer and no issues since.
H.
2010 Speedmaster Black w/ New England White. AI Removed. TTP Breathe, TTP O2 Sensor Kit, TTP Tune 2, DNA Air Filter, Trident Exhaust (toned down w/ Acousta-fil and custom unvented earplugs).
Hyates is offline
post #7 of 16 (permalink) Old 12-06-2011, 06:02 AM Thread Starter
About the bar end weights-like I said I changed my bars to new Bonneville drags and the vibration didn't change at all. The dealer said they took the bike for a test ride and said they couldnt replicate the vibration which is bologna cause it never doesn't happen. I'm pretty good with staying on top of my tire pressure. Anyone know if having another shop look at it will affect the warranty?
post #8 of 16 (permalink) Old 12-06-2011, 10:20 AM
I'd ask for a new front tire if they can't get rid of the vibration.
Which dealer is it?
If you want a good mechanic to look at it, go to Deer Park Cycle in Eldersburg, MD.
Marty
Baltobonneville is offline
post #9 of 16 (permalink) Old 12-06-2011, 02:09 PM Thread Starter
Pete's. I live in southern Maryland so its a hassle to get up to Baltimore. And I won't give Clinton cycles a dollar. They are the most crooked operation I've ever seen.
post #10 of 16 (permalink) Old 06-14-2012, 08:53 PM
jeiser's Avatar
Other Motorcycle: 1977 CB550
"Welfarebanks" did you ever get this resolved? I too suffer from the same problem on my 2012 T100 and is currently being investigated. I've even got my own thread on this:
http://www.triumphrat.net/twins-talk...012-t100s.html
I've already had the front tire replaced and it actually seems slightly worse, but definitely not better. This is getting really frustrating, and a PITA to deal with.
jeiser is offline
2011 T100 Front Wheel Removal Turnertwin Air Cooled Twins Technical Talk 12 11-07-2011 01:33 AM
Engine vibration 2011 America Darrelwalters Air Cooled Twins Technical Talk 13 10-31-2011 10:43 PM
Engine Vibration 2011 America Darrelwalters Air Cooled Twins Talk 0 06-13-2011 11:48 AM
scrambler 2011 and bonni T100 2011 hubs martin.kryjom Air Cooled Twins Technical Talk 2 04-26-2011 01:06 PM
Handlebar vibration on new T100 HiVel Air Cooled Twins Talk 16 06-16-2005 03:47 PM
