Workshop stand round up - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 29 (permalink) Old 11-25-2011, 04:14 AM Thread Starter
Forchetto's Avatar
Choosing an aftermarket exhaust such as the Arrow 2-into-2 condems you to giving up the option of a centre stand. Two reasons: one of the fixing holes for the stand is now taken up by the sidestand stop bracket supplied by Arrow, and the lever arm of the centre stand clashes with the left hand silencer.
This is a shame as I really like my Arrow system but miss a centre stand terribly. I have all manner of jacks and lifts in my garage but they're all a little bit of a pain to bring out and use just for things like checking and adjusting chain slack, or to wipe the wheels clean. Cleaning the bike would also be easier with it upright.
Jack Lilley markets a simple lever workshop stand, see:
http://www.jacklilley.com/buy/Triump...ONNIESTAND.htm
This would be great but, once again, it relies on the existing centre stand lugs on the frame and one of them is taken up by the Arrows.
There was a home-made example of that sort of lift talked about on this thread, see post number 9:
http://www.triumphrat.net/twins-talk...hat-works.html
I really like the simple home-made $20 lift as described here:
http://www.nightrider.com/biketech/bikelift.htm
Unfortunately I'm basically too lazy and also woodwork is not my cup of tea, so the link to on-bike.com in the UK given to us by member HeezaGeeza in his post number 14 of this thread: http://www.triumphrat.net/twins-talk...ear-wheel.html
showing a ready-made example using the same principle and marketed under the name "Eazy-Rizer Strong arm" was a God-send for me at least.
You can see it here with my SE on it:
http://www.on-bike.com/products_strongarm.htm
Costing a little less than the Jack Lilley example, £75 inc.tax, it's very well engineered and robustly made. It has a range of height adjustments and will lift any bike that has a chassis with twin downtubes under the engine such as our Bonnies and things like Harleys and most cruisers.
Depending of where you place it, it can lift the front or rear wheel quickly and with only a slight effort. Once up, the bike remains rock steady and perfectly upright.
The roller and uprights have several positions to adjust the thing for height. Choose the position where it lifts the bike the least. This makes it easier to operate. On my SE I've used the shortest setting and yet the rear wheel still stands about 1.5" off the ground, the effort to lift it there is minimal. The makers site shows a wholesome-looking broad (wearing just a shirt for some reason...) doing it to illustrate how easy it is.
Some other threads about lifts containing other ideas:
http://www.triumphrat.net/twins-talk...010-bonne.html
Forchetto is online now
post #2 of 29 (permalink) Old 11-25-2011, 07:18 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Very nice choice. I like that you can get either the front or rear wheel off the ground. More useful than the paddock stand that I use for oil changes/chain lubes...
Cheers,
--Rich
beemerrich is offline
post #3 of 29 (permalink) Old 11-25-2011, 08:02 AM
Main Motorcycle: 06 America
ETxCruiser's Avatar
Other Motorcycle: "Hog" Schwinn Missle FS
Forchetto, the StrongArm seems like a great stand. I can rationalize lifting my 06 America from its side stand, but what about lowering? Seems like that's when it would be unstable. Doesn't someone else have to help stablize the bike?
ETxCruiser is offline
post #4 of 29 (permalink) Old 11-25-2011, 09:14 AM Thread Starter
Forchetto's Avatar
I use it with the side stand deployed just in case. The side stand does interfere with the positioning of the Eazy-Ryser, you have to find a place where they don't touch, but it's not difficult.
When you roll the bike off it, it moves forward a little way and falls on the side stand.
post #5 of 29 (permalink) Old 11-25-2011, 09:19 AM
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2007 150cc Retro-scooter
Me and a buddy just went in on a lift from Harbor Freight; on sale for $59.99 instead of $119.99. It's still in the box, I'm waiting for my battery box to arrive for its first use.
Owenbrau is offline
post #6 of 29 (permalink) Old 11-25-2011, 09:20 AM
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Location: Toowoomba Queensland Australia (soggy bottom)
Other Motorcycle: '68 Benelli 350'
Extra Motorcycle: '60 Morini Tresette 175
Found this one on ebay
http://www.ebay.com.au/itm/Portable-...ht_1472wt_1185
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
ozbon is offline
post #7 of 29 (permalink) Old 06-04-2012, 10:08 PM
Main Motorcycle: '07 Bonneville
Extra Motorcycle: Honda CB750
Originally Posted by Forchetto View Post
....showing a ready-made example using the same principle and marketed under the name "Eazy-Rizer Strong arm" was a God-send for me at least.
I just purchased this same lift from here: http://www.lifts-and-stands.com/inde...trong-arm-lift
It works great! Robust construction. I can literally lift my Bonneville up with just the one arm while gently balancing/holding onto the bike with the other (hey, I'm just getting the hang of it).
It makes chain maintenance a breeze!
Dodwell is offline
post #8 of 29 (permalink) Old 06-05-2012, 12:43 PM
Main Motorcycle: All
Image 12 &13 on page 5 is my bike.
http://steelhorsefab.com/photosvideo...nds/?nggpage=5
WTBScrambler is offline
post #9 of 29 (permalink) Old 06-05-2012, 01:17 PM Thread Starter
Forchetto's Avatar
Originally Posted by WTBScrambler View Post
Good looking stand but the great advantage of the simpler "Strong arm" is that it can also lift the front wheel by altering its position.
post #10 of 29 (permalink) Old 06-05-2012, 03:48 PM
Main Motorcycle: 2012 Triumph Bonneville
I picked up one of these for $40 US. Works great and lifts the front or the rear as well.
http://www.ebay.com/itm/Motorcycle-C...f517ca&vxp=mtr
Jburl is online now
Another round uncle nort Biker Hang-Out 11 05-31-2011 12:24 PM
Chain Check - Sides stand v. rear wheel stand teachnsurf Air Cooled Twins Technical Talk 11 09-20-2010 01:54 AM
round the outside! cafestyle Air Cooled Twins Talk 6 09-25-2005 03:20 PM
Welcome to the 'Workshop' BigStripey Tiger Workshop (archive) 6 12-12-2004 04:20 PM
