Alternative gearchange, gearshift levers - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #31 of 62 (permalink) Old 08-11-2012, 09:00 PM
Main Motorcycle: Bonnie
DaniFly's Avatar
Other Motorcycle: Many Scooters
Extra Motorcycle: Kymco P250
I did need to hammer it on with the back of my screw driver.... Took a few minutes but now it's golden
DaniFly is offline
post #32 of 62 (permalink) Old 08-24-2012, 02:53 AM
Main Motorcycle: Triumph Thruxton
Sweet...ive been looking for one for my thrux.
ElChopper! is offline
post #33 of 62 (permalink) Old 10-22-2012, 07:24 AM
Main Motorcycle: BMW R1200RT
Other Motorcycle: 2002 T100 Centennial
I have a size 7 foot and when my foot is on the peg my toes do not even touch the shifter.
I went and checked my BMW and the Triumph T100 shifter is a full 1 inch longer !
I don't want to change my shifter to an aftermarket one or re-drill it.
Does Triumph make a shorter shifter for my T100 or is there another Triumph model that would fit?
gregpinch is offline
post #34 of 62 (permalink) Old 10-31-2012, 09:02 PM
Main Motorcycle: Scrambler
Olhogrider's Avatar
Other Motorcycle: Sold
Extra Motorcycle: Gone
Thanks! I ordered pegs and a shifter.
Damned Dirty Biker!
Olhogrider is offline
post #35 of 62 (permalink) Old 11-24-2012, 11:23 AM
Main Motorcycle: 955i
repsolracer22's Avatar
good thread. i have a scram and need a shifter...
i just ordered a BBR aluminum folding shifter for 03-up honda crf150f/230f +.5"
i will report back with how it worked. if anyone needs one of these, i can get em for $35
repsolracer22 is offline
post #36 of 62 (permalink) Old 11-24-2012, 11:09 PM
Olhogrider's Avatar
I got the cheap eBay shifter. It is a bit longer but I have no trouble with my size 9 (US) boot. I like the folding tip and the black matches other blacked out parts of my bike. The splines are a bit tight but not a problem.
Damned Dirty Biker!
post #37 of 62 (permalink) Old 01-28-2013, 02:09 PM
Newbie
Main Motorcycle: 1996 Adventurer
Alternative Shift lever for 1996 Adventurer?
Hey everyone. New owner of a 1996 Triumph Adventurer and have a problem I need to address.
My buddy jumped on my bike and tried to kick start it using the shift lever = Thanks dude.
This is what resulted.
He broke the tip of the spindle off.
The bike still shifts just fine so I don't want to have to replace the whole shaft if possible.
Shifts fine with one caveat. The problem I am having is there is not enough bite for the old, and somewhat worn out lever to stay attached.
The question I have is are there other levers that have a more narrow "bite Down" area that would fit my 1996 Adventurer and stay attached when placed closer to the transmission housing.
Didn't pay a whole lot for the bike so I don't want to drop a whole lot of cash, just a fix that will have me riding in the spring. and apologies to all the purists out there I don't care about aesthetics, just functionality (for now.)
Are there other fixes for this problem? I would think welding the piece would be problematic due to heating up the other components. Perhaps bore a hole to reattach the piece?
Thanks everyone.
Pdallman is offline
post #38 of 62 (permalink) Old 01-29-2013, 08:42 AM
Main Motorcycle: Bonneville
If you scroll back to Dani's post, that's the shifter I used. It was pretty tight (a bit smaller than stock), and I would need a spreader to get it off. It may work for you, I'm not familiar with Adventurers. But it was also only $12. May be worth the experiment. If it were me, I might try some loctite or JB Weld or something before I bored a hole. Although either of those options would require a new shaft if they didn't work.
Bigeauz is offline
post #39 of 62 (permalink) Old 01-29-2013, 09:46 AM
Newbie
Thanks for the response.
I have actually tried JB weld but when I try to put the lever back on it breaks the tip off again. Going to try a couple more times with the JB weld though.. Would love that to work.
I am going to do some more research, I think a new lever with new grooves will work for me though. There is about an inch or so of exposed spindle with good grooves and clearance from the housing shouldn't be a problem with a just a little outward bend in the lever.
Pdallman is offline
post #40 of 62 (permalink) Old 01-29-2013, 10:52 AM
Main Motorcycle: 2012 Bonneville Mag Wheel
I'm glad this post has been revisited as I would also like to find a nice shift and brake lever without having to replace the entire rearsets. I like the stock position of my pegs on my '12 Bonneville mag wheel.
There is a new option albeit a costly one:
http://www.satoracing.com/shortshift...bonneville.htm
Having used Sato components in the past, I can assure you, you get what you pay for. This shift lever provides a few options not found in lower cost levers such as peg distance and lever angle. I've contacted Sato to see if they plan on making a similar brake lever available to match.
MostChillin is offline
Alternative brake/clutch levers? djr Tiger Chat 25 09-27-2015 03:42 PM
need a picture of the gearchange lever... tgleaton Club Cafe' 7 11-02-2011 04:50 PM
Clunky gearchange Brit in DC Daytona Deliberations 4 10-14-2009 07:37 PM
Gearchange pedal...how to replace? chief_rocker Air Cooled Twins Technical Talk 9 01-21-2007 04:48 PM
How to Fix a sloppy gearchange lever on a 97? Speed Triple Forum 1 04-15-2004 06:53 AM
