How Do I stop The Exhaust Popping - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 06-08-2011, 04:04 PM Thread Starter
Main Motorcycle: Bonneville 2006 Red & Blk
I have read many many post about the popping in the exhausts when decelerating.
I have richened the idle mixture up with the D tool, even to unscrewing the mixture screws eventually to 6.5 turns just on a try to see what happens basis....but still it pops probably as bad as before.
I have removed the AI. That did stop the popping when blipping the throttle when stationary but didn't stop in on road use.
I have fitted TOR's and the 120 main jet that came with them and standard idle jets.
Is it a characteristic of my Bonnie T100 or can it be stopped because its driving me mad ?
Last edited by turbo; 06-09-2011 at 09:33 AM. Reason: Edited main jet size from 125 to 120
turbo is offline
post #2 of 14 (permalink) Old 06-08-2011, 04:12 PM
Forchetto's Avatar
It can usually be traced to a weak idle mix, but seeing that you've tried all that, the only thing left is to locate any air leaks within the exhaust system.
Check the tightness of the pipe flanges at the head, and look out for tell-tale signs of soot indicating the gaskets are not sealing well.
Go on to the pipe-silencer joint. Is it distorted, clamp loose or not sealed with some silicone sealer?. It should be. Once again look out for soot traces or even run your hand close to the joint to feel for gas blowing out.
Also, did you use sealing washers on the AI blanking plugs?. Are they tight?.
Forchetto is offline
post #3 of 14 (permalink) Old 06-08-2011, 04:28 PM
Main Motorcycle: Trident 750
Black Dog's Avatar
Other Motorcycle: Yamaha XT660R
Extra Motorcycle: Yamaha XT600E
Mine pops all the time on deceleration. It's a feature.
1994 Trident 750 (the rolling project)
2006 Yamaha XT660R (the daily ride)
1995 Yamaha XT600E (the resto project)
2002 Sprint ST 955i, 2005 Bonneville (now sold)
www.goingfastgettingnowhere.blogspot.com
Black Dog is offline
post #4 of 14 (permalink) Old 06-08-2011, 04:30 PM Thread Starter
Thanks for your comments Forchetto
I have done so many thing to stop the popping I have forgotten some I have done, sorry, need to add these.
I have removed the TOR's recently and resealed the pipe to silencer, fully tightened the clamps and have no distortion, I have checked the head flange's and all are air tight, I have just checked the tightness of the AI plugs and they are nice and tight with new copper washers 3 weeks ago.
I have run the engine at about 1500 rpm and placed both hands over the silencer end, no hint of any leaks and the engine eventually stalled leaving quite a high back pressure until I removed my hands.
turbo is offline
post #5 of 14 (permalink) Old 06-08-2011, 04:38 PM
Forchetto's Avatar
Errr...It's a feature! as Black Dog says...
Can't think of anything else. It's a long shot but check the spark plugs are tight. I've checked mine a few weeks ago and was a little shocked to find them almost finger tight. I did install them to the makers instructions on torque but they came loose.
I don't know if that can cause it, but you never know.
post #6 of 14 (permalink) Old 06-08-2011, 06:50 PM
Forum Liaison
Main Motorcycle: 04 Thruxton
RumRunner's Avatar
Other Motorcycle: 05 Tiger
I think it's an electrical problem if you wear your iPod, and turn up the volume I bet the problem goes away
RumRunner is offline
post #7 of 14 (permalink) Old 06-08-2011, 06:56 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
It's gonna pop.
sweatmachine is offline
post #8 of 14 (permalink) Old 06-08-2011, 11:46 PM
Main Motorcycle: Harley Ultra '11
Other Motorcycle: BMW R1150RT '04
Extra Motorcycle: Kawi Ninja 650R '09
Funny, I moved recently from a T100 to a Sprint ST, and one of the endearing features of the 1050 triple is the burbling/popping of the exhaust on over run/ deceleration. Would hate for that unique sound to go away. Just saying....My T100 didn't pop even w the AI intact, after changing exhaust and remapping, arrow 2into 2 map...tomp
tomp is offline
post #9 of 14 (permalink) Old 06-09-2011, 07:03 AM
Black Dog's Avatar
I know the dynamics of exhaust gas flow are complex, and I am no expert, but the Bonnie has always popped on the over-run. To some extent it is a feature of open exhausts. Always had TORs, and the popping was the same before and after airbox gutting and bigger jets. But my XT exhaust rusted through at the header and became porous, and (I assume) was letting air in close to the exhaust valve. The sound that made was quite different from a burbling and popping - it was more like proper bangs like a backfire when I shut the throttle. I associate that kind of sound with an air leak - the gentle popping of the Bonnie is just a cool sound.
post #10 of 14 (permalink) Old 06-09-2011, 07:47 AM
Main Motorcycle: 2006 T100
Other Motorcycle: 1968 Triumph T120
125 jets are surely too big with TORS and no other modifications.
2006 T-100, 57k and oil tight; BC Sleepers, no snorkel,Hyde steering damper, Parabellum Scout, Western Bars, Progressive 412s, Michelins, AirHawk, Go Cruise, 19-tooth; Givi bags, K&N, Nology, Kuryakan Iso grips
Oldguy is offline
Popping from the exhaust Motolink Air Cooled Twins Technical Talk 5 11-29-2009 03:37 AM
Exhaust popping LargeWhite Hinckley Classic Triples 26 01-23-2009 08:21 PM
Will shim stop popping on decel FastFreddieCAN Air Cooled Twins Technical Talk 4 03-30-2008 09:50 PM
Exhaust popping Nzbiker Air Cooled Twins Technical Talk 18 02-28-2007 02:48 AM
exhaust popping. bgaz Air Cooled Twins Technical Talk 6 07-26-2006 08:57 PM
