6 pot Caliper Master cylinder Upgrade !!! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 25 (permalink) Old 06-03-2011, 05:45 AM Thread Starter
Main Motorcycle: THRUXTON
CHRIS211083's Avatar
Hi all ive got a Pretech 6 pot Caliper on my 2004 Thruxton.
I wasn't very happy with the feel and the way that the Standard master cylinder operated the brake. There was also the annoying bleeding that took too long as well. So I started looking for the cheap upgrade. The general consensus was that a RGV250 Master Cylinder or a Triumph Speed triple one would both give you the desired feel and pressure. The RGV250 master cylinder was the cheaper so i bought one for £15, the speed triple ones come in around £70. However there is a difference between the two, the RGV is a 5/8 master cylinder(15.8mm) were as the speed triple is a 14mm master cylinder bore.
Fitting was simple as the RGV master and the Thruxton master are almost the same. I aslo fitted a master cylinder rebuild kit before fitting. The two things that cropped up when fitting the new master was that the banjo bolt was not the same thread as the standard one. Luckily i have a spare one in the shed that fitted, second was that the inlet from the reservoir was pointing the wrong way. All a did for this was move the master cylinder reservoir.
I have to admit it bled very easily and gives a much stronger lever, unfortunately it is at this point after a long ride that i have deceded that even though it is better than the original i think the Speed triple would have been the better option. The standard Thruxton master is an 11mm bore and in my opinion doesn't pump enough or give the right feel. However the speed triple master at 14 would be the perfect compromise. In the future i will be changing to the speed triple master as the RGV (16mm) is too large and doesn't give much feel and will give you fore arm pump when riding fast for long periods.
Hope all are well thanks for reading.
Chris.
Thruxton 04, TPUSA 865 Perf Kit, FCR39's,Custom Shark silencers, Maxton fully adjustables, Carrozzeria Wheels with 88.6RWHP!!!!
BOOKIN'ME AIN'T GONNA SLOW ME DOWN,OFFICER.....
CHRIS211083 is offline
post #2 of 25 (permalink) Old 06-03-2011, 10:44 AM
Main Motorcycle: 04 Thruxton
Aarik's Avatar
Nice Mod Chris and thanks for the write up with pics - I saw one of these on a thruxton the other day and it definately caught my eye.
I've just done EBC pads and am happy with the improvement but this would be my next step if I wanted to ratchet up the braking power even more.
How much did you shell out for the caliper?
04 Thruxton - Black. Wade Cam, Port & Polish, AI Chop. Madaz Pipes - Ceramic Coated. Ikon 7614 & Progressive Springs. EBC Pads. Custom FRK & Lights. CRG Hindsights.
Aarik is offline
post #3 of 25 (permalink) Old 06-03-2011, 04:15 PM Thread Starter
The Pretech 6 pot was from here:
http://www.triumphtwinpower.com/pret...ot-caliper.php
There are other very good products on the site.
Chris.
post #4 of 25 (permalink) Old 06-03-2011, 04:18 PM
Slinky's Avatar
Other Motorcycle: Down to my last 1
You could also consider a 12mm or 1/2" master cylinder, they are cheap and plentiful being fitted to a lot of single disc bikes like the ER500, CB500 etc.
I would imagine there is not much feel with a 5/8" master cylinder- it must be rock solid.
'98 Thunderbird
Slinky is offline
post #5 of 25 (permalink) Old 06-03-2011, 04:48 PM Thread Starter
Its not too bad actually but i think the 14 would be the real deal. Also remember that the Thruxton pre 2008 has small diameter handle bars. So many don't fit.
Chris.
post #6 of 25 (permalink) Old 06-03-2011, 11:49 PM
Main Motorcycle: 2008 Thrux
NorthernThrux's Avatar
Other Motorcycle: 2010 Speed Triple
I have the speed triple master on a 2008 thrux with 7/8 clip ons and a Pretech 6 pot caliper. It's awesome. Lots of feel but you can lock the brake if you try, so lots of grip.
2008 Thrux. 1087 TPUSA motor. SOLD
2010 Speed Triple. SOLD
NorthernThrux is offline
post #7 of 25 (permalink) Old 06-04-2011, 06:12 AM Thread Starter
Hi NorthernThrux, i have seen one of your threads before. However it was the price that made me go for the RGV master. Wish id just bought the speed triple one in the first place now. However don't get me wrong the RGV master is still better than stock and boy did it bleed easier. Still part of the reason behind this thread was to make sure people don't do what i did and buy the lesser master cylinder.
Chris.
post #8 of 25 (permalink) Old 06-04-2011, 06:33 AM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
The inlet from the master cylinder can be rotated, at least the one on my thruxton could. from memory it just needed finger pressure to move it.
07 thrux,breathe,Dna airfilter,airbox X restrictor,135 mains,tp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,3" rise clipons,corbin seat, tt350 taillight,alloy indicators.shorai battery,Changes daily
plodalong is offline
post #9 of 25 (permalink) Old 06-04-2011, 09:55 AM
Main Motorcycle: 2004 Thruxton
Thruxster50's Avatar
Hey Chris, This is interesting as I have fitted a 4 pot Beringer and apart from the pain in the ass bleeding issue I am dissapointed with the performance, not wanting to blame the Beringer or Braking wave rotor combo I feel this could be the answer, stock 2004 Thruky clipons so which Speed Triple master should I be looking for, chrz....T50...
Thruxster50 is offline
post #10 of 25 (permalink) Old 06-04-2011, 10:06 AM
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
Extra Motorcycle: 16 Thruxton R
Thruxster, Have a look at a thread that I started a few weeks ago. I have a beringer 4 pot caliper on my 2004 Thruxton and wasn't happy with the performance so I tried the speedy m/c. I have since abandoned the speedy m/c as there is too litle lever travel (ie too much displacement for the caliper) resulting in a wooden feel. I have since gone back to the OEM m/c. I am now tempted to try the Brembo m/c.
Chris, shoot me a PM if you are interested in my speedy m/c
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
master cylinder upgrade Daytripper666 Daytona Deliberations 5 11-15-2010 03:41 PM
Master cylinder upgrade DLR Maintenance & Workshop Talk 7 08-14-2010 03:27 PM
Brake caliper and master cylinder upgrade mvoutour Speed Triple Forum 13 03-02-2009 12:14 PM
Radial Master Cylinder Upgrade? dhawker Sprint Forum 6 05-30-2008 07:18 PM
Sky King Master Cylinder Upgrade... FuryFour Triumph SuperSports 15 09-10-2006 12:16 PM
