New Spec Triumph Bonneville Cam Cover Gasket - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 28 (permalink) Old 11-14-2012, 05:45 AM
Main Motorcycle: Bonnie T100 of course
Other Motorcycle: I wish
Extra Motorcycle: Yes please
Originally Posted by Bonnie1000th View Post
The old style cam cover, cam cover gasket and cam cover seals are use up to engine number 456551 for the entire classic model lineup.(2001-2009).
The new cam cover, cam cover gasket and cam cover seals goes from engine number 456552 for the entire classic model line up( 2009 to present).
It seems they've changed the bolts in addition to the Cam cover, seals & gasket:-
http://www.worldoftriumph.com/triump...lock_03=610610
Bonneville & SE EFI > Eng No 456551
SPARES KIT CAM COVER BLACK Triumph Motorcycle Part Number T1260912
BOLT, SHLD, TX, M6X24.95, SLV Triumph Motorcycle Part Number: T3332052
SEAL,CAM COVER Triumph Motorcycle Part Number: T1260309
SEAL.CAM COVER Triumph Motorcycle Part Number: T1260900
Bonneville & SE EFI Eng No 456552 >
COVER CAM CRKL BLACK LINISHED Triumph Motorcycle Part Number T1261923
BOLT, SHLD, TX, M6X24.95, SLV Triumph Motorcycle Part Number: T3332051
SEAL CAM COVER SCREW Triumph Motorcycle Part Number T1260337
SEAL CAM COVER Triumph Motorcycle Part Number T1263333
Interestingly, being ignorant of the cam cover and bolt changes, I've used the new gasket & seals on my 2008 T100 without any problem whatsoever so the changes to those items must be very subtle.
Aussie_T100 is offline
post #22 of 28 (permalink) Old 05-23-2014, 04:47 PM
Main Motorcycle: 2005 Triumph Thruxton
Other Motorcycle: 1987 Honda Super Magna
Originally Posted by Forchetto View Post
Thanks for that. It now looks as if both components responsible for the tiresome leaks reported from the cam cover have been updated and presumably improved.
These are the items to look out for if you are plagued by leaks:
The Sealing washer T1260337 rather than the old T1260309.
The Cam cover gasket T1260904 rather than the old T1260900
I have a 2005 Thruxton with Carbs. Two different Triumph dealers could NOT get their head around these new part numbers. They said that these part numbers listed are part of a kit that goes with chromed valve covers... ??
So I come to the great ones here at Triumphrat... will these two new part numbers work for my 2005 Thruxton ?
Thanks.
bferrari is offline
post #23 of 28 (permalink) Old 05-23-2014, 11:50 PM
Main Motorcycle: '05 triumph Bonneville T1
Swbonnie's Avatar
I had a weepy cam cover, so I ordered a new one from Hermys. Also bought new washers, installed and torqued to specs, good to go. Not sure if it is the old or the new, but it doesn't leak anymore. This was about 3 months ago.
'05 Bonneville T-100 custom w/23,000 + miles
NH M bars, MAS seat/cowl, Nark, Ricor fr/rr suspension, D9 flat gauge panel, D&D exhaust, new paint, 138 mains,40 pilots, no shims, 2 turns. 63.38 hp/53.28 torque.
Swbonnie is offline
post #24 of 28 (permalink) Old 05-24-2014, 01:22 AM
Main Motorcycle: 2012 T100
Originally Posted by bferrari View Post
I have a 2005 Thruxton with Carbs. Two different Triumph dealers could NOT get their head around these new part numbers. They said that these part numbers listed are part of a kit that goes with chromed valve covers... ??.
And I have a chrome valve cover that did come with a new gasket already on the cover and a little bag with 4 new screws and seals.
No separate parts listing though.
paul e is online now
post #25 of 28 (permalink) Old 05-25-2014, 05:02 PM
We'll FYI, I used the listed newer parts numbers as listed near the beginning of this thread and did this to my 2005 thruxton. Works great no weepage. I torqued the four cover bolts to 12 NM which is the middle of what the Haynes manual lists at 10 NM and the new updated value if 14 NM I heard about here.
Also used the British Customs AI Delete kit at the same time.
Both things were pretty simple for me who barely turns a screwdriver. I don't know what we did before YouTube. I like Delboys Garage series, pretty down to earth knowledge he passes on with an English flair. I chuckle every time he says "spanner" ...
bferrari is offline
post #26 of 28 (permalink) Old 05-25-2014, 05:09 PM
Forchetto's Avatar
Thanks for confirmation that the updated parts work on the older models.
Forchetto is offline
post #27 of 28 (permalink) Old 05-26-2014, 12:53 AM
Main Motorcycle: 2006 Bonnie T-100
Other Motorcycle: 2007 Triumph Tiger 1050
This is killing me. :-) I literally went to my loathesome area Triumph dealer yesterday to procure a valve cover gasket, and now this thread shows up and I simply cannot make heads or tails of whether or not I have the right bloody gasket.
My scenario is this: I have a 2007 T-100 w/ the chrome valve cover on it (put on by the last owner). The dealer gave me a #900 gasket without knowing that I had the chrome valve cover. Should I infer from what I've read here that I should now go back to them and request a #904 gasket to compliment this valve cover?
Your collective insights, as always, are appreciated.
Sent from Motorcycle.com Free App
2006 T-100 - NARK, Procom, EmGo Rev. Cones, CBR600F3 Fork Conversion, ZRX KYB Shocks, Beringer 6-pot
2007 Tiger 1050 - K&N Airbox Mod, Two Bros. Race Exhaust, 20545 TuneECU
werm42 is offline
post #28 of 28 (permalink) Old 05-26-2014, 01:04 AM
Forchetto's Avatar
If you're wary of fitting the newer parts on your older bike just ask for the old part numbers:
Sealing washer T1260309
Cam cover gasket T1260900
Cam Cover gasket killian101 Air Cooled Twins Technical Talk 23 05-13-2010 01:12 PM
D600 cam cover gasket nick325i Triumph SuperSports 2 03-09-2007 12:20 AM
Triumph Bonneville T140 (US Spec 1978) salsa-king Classic, Vintage & Veteran 5 05-14-2006 09:57 AM
