New Spec Triumph Bonneville Cam Cover Gasket - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 28 (permalink) Old 05-11-2011, 06:11 AM
Main Motorcycle: Bonneville 2010
Had a weeping camcover and brought my Bonnie in yesterday. Told the dealer I heard there was a new gasket for the Bonneville which he could confirm after checking with Triumph. But Triumph states that the new gasket is only for more recent Bonnevilles (don't know from wich engine number - not my 2010), so the dealer deduced there must be a (minor) change in the camcover... I'm getting the 'old' gasket, I'm confident this will stop the weeping.
Greetings.
BroederL is offline
post #12 of 28 (permalink) Old 05-11-2011, 06:19 AM
Forchetto's Avatar
Greetings.
Interesting. They might have made the joint face a little wider, this would help with leaks.
This is all speculation though, like lots of other things. Surely this forum has enough clout with Triumph to be able to obtain some reliable data from them.
After all this leaking business is THEIR problem, not ours. A little technical explanation from one of their technicians as to the causes and cures wouldn't come amiss.
Forchetto is offline
post #13 of 28 (permalink) Old 05-11-2011, 01:42 PM Thread Starter
Main Motorcycle: 2010 Bonnie
Other Motorcycle: Fastest xv250 in NorCal
Greetings.
My Bonneville is a 2010 base model. It had the "old" gasket when I bought the bike new, but with the new gasket (T1260904) installed, the leaks seem to have stopped just fine. If your dealer is correct that there is indeed a slight change in the cam cover for the more recent Bonnevilles, I would expect that the dealer would swap out the cam cover under warranty when they addressed the leaking cam covers, too. Regardless, good luck with your fix. Hope your dealer puts a stop to your oil weep.
HkmadeCCC is offline
post #14 of 28 (permalink) Old 05-11-2011, 02:34 PM
Main Motorcycle: '09 Bonnie Black
tbirdsp's Avatar
Other Motorcycle: '05 KLR 650
Extra Motorcycle: '07 Yamaha Majesty YP400
I talked to a technician at a nearby dealer. He said they have been using extra washers on top of the rubber ones. Didn't seem to know about any new spec washers or seals. One thing he did say that was interesting - on the powder coated covers sometimes the powder coat causes an uneven edge on the bottom of the cover. He suggested carefully sanding the powder coat off of the edge.
Mike S.
tbirdsp is offline
post #15 of 28 (permalink) Old 05-12-2011, 11:16 AM
Originally Posted by Forchetto View Post
All this is just conjecture at the moment. Data gathered as we go along.
I would imagine the dealers will get a Service bulletin or at least a web address where they can check to see if the bike they're about to service is subject to any changes.
Wouldn't it be nice if someone in the know from the factory was seconded here for a few hours each month to answer all sorts of questions, eh?.
Forums such as this do a lot for them, sales, loyalty, etc and we can't even share an out of date electronic file of a service manual that has been superceded by a new edition... Pathetic.
And yet you can go to project www.gutenberg.org and download War and Peace for free for your Kindle electronic book.
Good post Sir if only.
Plasma.
plasma is offline
post #16 of 28 (permalink) Old 05-13-2011, 02:26 PM
Main Motorcycle: European Bikes
tooblekain's Avatar
Other Motorcycle: 2006 Triumph Daytona 675
Extra Motorcycle: 2007 Triumph Bonneville
Send a message via AIM to tooblekain
Can anyone take a picture of the new cam cover gasket and seating washers?
tooblekain is offline
post #17 of 28 (permalink) Old 11-13-2012, 06:08 PM
Main Motorcycle: 2010 Mag Bonneville
lam@ratf's Avatar
Location: in the '16 OTA w/ the crappiest weather in decades
Other Motorcycle: 2013 Suzuki TU250XL3
Thanks for that. It now looks as if both components responsible for the tiresome leaks reported from the cam cover have been updated and presumably improved.
These are the items to look out for if you are plagued by leaks:
The Sealing washer T1260337 rather than the old T1260309.
The Cam cover gasket T1260904 rather than the old T1260900
This needs to be a closed sticky at the top of every cam leak thread. Took me 40 minutes to track down and confirm theses numbers.
Thanks Forchetto
Physics always wins
. . . . so get that helmet cam!
2013 Suzuki TU250XL3 - mods in progress / 2010 Triumph Bonneville - miles adding up
2009 Suzuki TU250XK9 - KBC Sep 2013 / 2001 Honda Rebel - KBC Mar 2010
lam@ratf is offline
post #18 of 28 (permalink) Old 11-13-2012, 06:18 PM
Forchetto's Avatar
I don't have the new gasket to compare but I have both sets of washers. Not much help though, the new ones are slightly larger and appear to be made of a different material:
post #19 of 28 (permalink) Old 11-13-2012, 06:41 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
The gasket has never been the trouble any way its the washers.
mikeinva is offline
post #20 of 28 (permalink) Old 11-13-2012, 07:02 PM
Main Motorcycle: 1087 Triumph
Bonnie1000th's Avatar
The true
The old style cam cover, cam cover gasket and cam cover seals are use up to engine number 456551 for the entire classic model lineup.(2001-2009).
The new cam cover, cam cover gasket and cam cover seals goes from engine number 456552 for the entire classic model line up( 2009 to present).
Bonnie1000th is offline
Cam Cover gasket killian101 Air Cooled Twins Technical Talk 23 05-13-2010 12:12 PM
D600 cam cover gasket nick325i Triumph SuperSports 2 03-08-2007 11:20 PM
Triumph Bonneville T140 (US Spec 1978) salsa-king Classic, Vintage & Veteran 5 05-14-2006 08:57 AM
