Perhaps whoever adjusted it last didn't line up the flywheel "reluctor" with the tip of the pick up coil and just adjusted it to the general surface of the rotor.
Ok here is the question for the day the alt has like 3 trigger bumps the last one seams to line up with pickup coil some where around 5 deg btc.what logic does the ecm use to know when to fire ?Does it count leading edge pluss of the pick up coil or trailing edge?
What static timing does the bike have before the advance kicks in? How much do they very from one bike to the other as far as where they really fire at?
I bet some have as much as 2 deg more timing before the advance comes in then others.
I allso bet changeing the air gap can change timing some what. The lower the gap the sooner it fires if it works off the leading edge.If it works off trailing edge the later it would fire.Lets hear what yall think.
I have exactly the same concerns with the pick up coil. A 2001 came from the factory spec'd at 1.0mm+/-0.2 . Changing the gap to .08 allowed the POS Gill coil to properly "saturate". I suspect this retards the timing....with in the ECU factory timing tolerance. When I had problems in this department, I replaced the GILL coil with the Nology and left the pick up coil at 1.0 gap...the bike has been fine for over 50,000 miles since the update.
I suspect Triumphs change in gap spec is all about $$$. For a technician to swap a coil is about the same labor as readjusting the pick up. A coil costs a lot more money then a gasket, glue and a screw. Both "fix" the problem to most customers satisfaction...few if any will notice the difference of a degree or two has been dialed out...especially coming from a misfiring condition. I seriously doubt that the factory would advance the timing...this could result in higher emissions...
How the bike in this post ran AT ALL is beyond me.
I've been trying to get my head around this business of electronic advance/retard for years.
On igniter or CDI systems it seems it's done by delaying the signal received from the pick-up the appropiate amount.
The timing curves are stored on a microcontroller, something like one of those PIC16 MicroChip.
The PIC receives the signal from the pick-up and delays it by using an internal table. This means that the starting point of the ignition or the position of the reluctor is placed before TDC at the most advanced point in which you want to the ignition to work.
For the maximum advance, the PIC will introduce a zero delay to the received pick-up signal. It'll apply more and more delay to retard.
Be good if Pieman could explain this sometime though, I'm sure he knows how it's done.
you are getting real technical and i like to challange thy old brain...
after we adjusted the P.U.C it fired right up.. his bike have never been this easy to start!
and this is after sitting in my garage the whole winter.. first push = start
as Mikeinva says there is a lot of "play" on these coils.. the holes are alot bigger then the bolts that holds it in place so you can push it back and forth a bit..
how sensitive is this set up? i meen Davids bike worked with 1.7-1.9 mm!!
can his wrongly setup on the P.U.C thrashed the ignition coil?
many thoughts and many ways and means......
still its interesting discussing it! and I would love to know more about the subject
Good write-up on coils at the link below. The "ignition coil failures" paragraph more or less explains what goes wrong. It's a car coil but the principle is the same:
I have just found this on my 2002 Bonneville too !!!
Bolts weren't loose either
My bike was never a good starter and I had put it down to other things so hopefully when all back together I will have a snorting fire breathing Hot Rod LOL
I'll add that when I opened my 2005 for the first time on that side to check the pickup coil gap, it was 0.8mm or possibly less--I had to push in the 0.8mm feeler gauge.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
