Output shaft seal - fitting tips - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 03-16-2011, 06:55 PM Thread Starter
Main Motorcycle: Scrambler 900
thirteendevils's Avatar
After noticing a small oil leak coming from the drive sprocket area i isolated it to a leaky output shaft seal (part#PFKL1215354). I ordered a new one from Lings here in the UK and went about making a right mess fitting it by trying to tap it in with a hammer and drift, as the seal is a very tight fit.
So, two more seals were ordered this time (in case i damaged another one!) this time i engaged my brain and used the following method to fit the seal with no problems -
-Lightly smear oil around the outside edge of the seal.
-Slide the seal over the output shaft and LIGHTLY press it in about 1-2mm using your fingers making sure it is absolutely in even all the way round.
-Now the clever bit, take the old seal and the spare one and slide them both onto the output shaft flat side first.
-Next take your sprocket and slide it onto the spline on top of all 3 seals.
-Take the locknut and turn it onto the sprocket and SLOWLY start to tighten the whole lot up. If all is going well you should be able to see the new seal slide into place as you tighten the locknut.
-When the new seal is flush remove the locknut and the 2 seals that were acting as a press and bingo a perfectly fitted new seal!!!
Hope that this is of some use to people even if it might appear obvious to the more experienced mechanics out there.
I searched for ages on tips on fitting driveshaft seals and information was a bit thin so i thought i'd share this method
thirteendevils is offline
post #2 of 7 (permalink) Old 03-16-2011, 10:06 PM
Main Motorcycle: 2010 Speedmaster
Hyates's Avatar
Yes, this is the stuff that newbies like me need. Thanks for sharing!
H.
2010 Speedmaster Black w/ New England White. AI Removed. TTP Breathe, TTP O2 Sensor Kit, TTP Tune 2, DNA Air Filter, Trident Exhaust (toned down w/ Acousta-fil and custom unvented earplugs).
Hyates is offline
post #3 of 7 (permalink) Old 03-17-2011, 12:45 PM
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Other Motorcycle: '68 Benelli 350'
Extra Motorcycle: '60 Morini Tresette 175
Handy tip, good stuff!!!
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
ozbon is offline
post #4 of 7 (permalink) Old 03-17-2011, 12:56 PM
Good post,thank you.
Plasma.
plasma is offline
post #5 of 7 (permalink) Old 03-17-2011, 09:39 PM
Main Motorcycle: 2007 Thruxton Bonneville
Nickwiz's Avatar
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
Very usefull.
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind......Dr Seuss
Nickwiz is offline
post #6 of 7 (permalink) Old 03-18-2011, 08:19 AM
Motorcyclist
Supernova
Main Motorcycle: 2013 Tiger 800XC
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Extra Motorcycle: G12DL, ZX1100, KLX400
Yes this is very good. Nice, gentle even pressure for fitting seals and bearings is always best when you can do it. I'm going to reference this in the tech sticky. Great tip.
Before he did it, I'd have said it couldn't be done.
propforward is online now
post #7 of 7 (permalink) Old 12-14-2011, 05:54 PM
Main Motorcycle: 2006 triumph bonneville
how do you get the shaft cover off to replace the seal? i already loosened all of the bolts and it seems to be stuck on there. any tips?
jharrel is offline
Output shaft seal leaking. Rat Scabies The Rocket Science Forum 2 07-08-2010 06:52 PM
Output Shaft Seal swassermann Triumph SuperSports 1 01-11-2009 09:21 AM
Main Output Shaft Oil Seal Replacement DEcosse Maintenance & Workshop Talk 1 04-05-2007 05:20 AM
Leaking oil seal on output shaft... TThruxton Club Cafe' 4 10-25-2005 04:08 PM
Output shaft oil seal leak. FIXED! Bryan Air Cooled Twins Talk 12 10-22-2005 05:30 AM
