Cheap, easy and effective Emergency start mod. - Triumph Forum: Triumph Rat Motorcycle Forums
 16Likes
post #1 of 160 (permalink) Old 03-07-2011, 03:43 PM Thread Starter
Forchetto's Avatar
Inspired by comments by member Gazedrop on post number 6 of this thread:
http://www.triumphrat.net/twins-tech...ml#post1826922
Where he managed to bypass the ECU's low-voltage inhibiting feature that prevents the engine from starting when it feels the battery is too low. He did this by removing the casing from the starter relay and operating the contacts by hand.
I set about modifying the starter relay to provide a permanent, easy to operate, emergency start button.
This mod costs absolutely nothing and it's extremely simple to carry out.
The idea is to provide the relay with a manual operating button so there's no need to remove the outer casing in case of difficulty. On these relays the casing is just clipped on and can be removed by levering with a small driver.
This exposes the relay mechanism itself and the idea is to drill a hole opposite the armature (that's the pivoted moving part that gets attracted by the electromagnetic coil), and find a suitable plastic plunger that can stick out of the casing and enables you to force the relay contacts closed.
I used a plastic stopper of the sort that close up the end of integrated circuit shipping tubes, but anything similar will do. Don't make the hole too tight, the plunger must be able to slide easily in it. Not too loose either, it would encourage water penetration. Not too short or it might fall inside the relay casing. The "mushroomed" shape on the inside prevents it from falling out, if you can't find a piece like mine, melting the end of a suitable plastic rod to widen it a bit will do.
Industrial relays often come with manual over-ride buttons on them, so this is an electrically sound mod. Nothing technically wrong with it. Here's a couple fitted with such a button:
This mod will help in the following circumstances, both on carbed and EFI models:
* If "start" button or its wiring are defective.
* If starter relay operating coil is open circuit or its supply is interrupted somehow (broken wire, bad ground, etc).
* On EFI bikes the ECU can inhibit operation of this relay because of low battery voltage. Pressing the relay button will force the engine to start.
* If the relay contacts have become stuck or welded together and the starter operates continuously regardless of the operation of the start button. This is a fairly common fault, we've had a few here. Repeatedly pressing the relay button might well "jog" the contacts apart.
* The engine can be started even if ANY of the safety interlocks fail: The clutch, sidestand or the neutral switches.
This is of course a great feature, but be warned to ensure gearbox is in neutral before pressing the switch.
The engine will start even if the sidestand is down and there's no need to pull in the clutch either.
Starting and charging wiring diagrams for EFI Bonneville in case anyone wants to study it further:
Sal Paradise and jtd like this.
Forchetto is offline
post #2 of 160 (permalink) Old 03-07-2011, 04:08 PM
Main Motorcycle: Bonneville -01 (sold)
kenneth_k's Avatar
Other Motorcycle: Scrambler -06 (hardtail)
Extra Motorcycle: looking for a new #1
going to bed with a little more knowledge....
thanks Forchetto!!
mikeinva:
I never seen so many sissy men on a bike forum. "Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment."
kenneth_k is offline
post #3 of 160 (permalink) Old 03-07-2011, 04:11 PM
triumphrat.net Vendor
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
Other Motorcycle: 2008 Bonnie Black
Cracking little mod Forchetto.
Mike (UK)
PieMan is offline
post #4 of 160 (permalink) Old 03-07-2011, 04:17 PM
mikejackmin's Avatar
That's awesome. Thank you.
mikejackmin is offline
post #5 of 160 (permalink) Old 03-07-2011, 04:57 PM
Main Motorcycle: 2006 BONNEVILLE T100
RICHW's Avatar
Other Motorcycle: 1999 TITAN PHOENIX
good thing he's on our side...
Triumph should take notes on some of these mods that Professor Forchetto has come to us with.
please keep your distance
• 26 B0NNEVILLE T1
my garage pics and specs
RICHW is offline
post #6 of 160 (permalink) Old 03-07-2011, 05:13 PM Thread Starter
Forchetto's Avatar
Originally Posted by RICHW View Post
Professor Forchetto
I was only a Doctor last week, mind you someone has given me a new title just yesterday.
Doctor cut'n'paste...
http://www.triumphrat.net/twins-tech...ml#post1826980
post #7 of 160 (permalink) Old 03-07-2011, 05:34 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
I'm thinking Doctor of Research is much more appropriate! Keep up the good work.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #8 of 160 (permalink) Old 03-07-2011, 06:34 PM
Main Motorcycle: 09 Bonneville t100
Other Motorcycle: it's gone-650 yahama
Extra Motorcycle: I wish for a Enfield
That is sweet!I like the way you give credit to the member who discovered the solution-and then take it to the next level!
I am now rummaging around trying to find just the right piece of plastic for an ---Emergency Start Button---sounds really grand!
stevemorris7 is offline
post #9 of 160 (permalink) Old 03-07-2011, 06:42 PM Thread Starter
Forchetto's Avatar
Be aware that these types of relays are very common and obtainable from most car shops for a few euros. You might well have a different brand in your bike and the armature might be facing a different way.
I was lucky and mine was facing so that the button ends up on the front face of the relay. On a different make of relay it may end up at the side or at the back.
More about these and other relays fitted to EFI Bonnies here:
http://www.triumphrat.net/twins-tech...nd-boring.html
post #10 of 160 (permalink) Old 03-07-2011, 07:22 PM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
I trust that there is no voltage on the armature side of the relay with the ignition switched off? This would probably make the bike startable just by pressing the emergency button...
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
Cheap, easy, effective fix for seat bolts Oldguy Air Cooled Twins Talk 11 10-09-2016 09:23 PM
Cheap, easy and surprisingly effective mod Forchetto Air Cooled Twins Technical Talk 46 08-15-2013 10:28 AM
Cheap Emergency Air Compressor propforward Tiger 800 - 800XC Mods & Workshop 7 03-02-2011 06:41 AM
Cheap Effective Oil Filter Protector singring Air Cooled Twins Technical Talk 5 09-21-2007 10:41 PM
