Ridiculously easy AI disabling - Page 15 - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #141 of 438 (permalink) Old 12-28-2012, 04:55 AM
Forchetto's Avatar
Originally Posted by 4all2pin View Post
Hey Forchetto
What about this 1, Muffler Silencer Air Flow Speed Control
http://www.ebay.com.au/itm/140772867...84.m1497.l2649
That might work, and it's not just a filter as it has an adjustable airflow facility that could be set to retain a small air flow to ventilate the system and avoid that condensation problem.
Forchetto is offline
post #142 of 438 (permalink) Old 12-28-2012, 10:01 AM
Main Motorcycle: Bonneville
geoffmcmanus's Avatar
Other Motorcycle: Burgman 400
Just bought this on Ebay http://www.ebay.co.uk/itm/3805339230...84.m1439.l2649 with the intention of cutting off the brass fitting and inserting the "Sintered Bronze" element into the AI tube. I am however concerned that cutting the element may compromise its structural integrity and it could fragment where it was cut and the particals fall back into the clean side of the air box and migrate into the induction with disastrous results. Any thoughts.
Geoff.
geoffmcmanus is offline
post #143 of 438 (permalink) Old 12-29-2012, 01:49 AM
Main Motorcycle: 2011 Bonneville Elizabeth
dam1's Avatar
Other Motorcycle: wish i could !!!
yes take AI off and don't look back.
dam1 is offline
post #144 of 438 (permalink) Old 12-29-2012, 08:30 PM
Main Motorcycle: 2007 America Black
Chub Rock's Avatar
Other Motorcycle: Saving for a T-Bird Storm
Today was a great day! A member reached out to me to trade a brand new BC kit for my carbed America for a luggage rack I had laying around. Sweet! I ordered the AI removal kit, so as soon as it warms up here in MN (currently 7°F with windchill -7°F) I will knock it out. And so it begins...
Chub Rock is offline
post #145 of 438 (permalink) Old 01-05-2013, 01:11 PM
After much deliberation I inhibited the AI buy using the bottom 1/2 inch of a "Blood Collection Tube". I used this as other methods that I had considered somewhat worried me due to the air tapping being "Downstream" of the air filter. I cut of the bottom 1/2 inch of the tube, flushed out the Anticoagulant (Lithium Heparin) and pierced a small hole in the domed bottom. Fitted in the horizontal section of the feed tube and secured with an upstream and downstream tie wrap. Did 200 miles today, smooth transition from a closed throttle, no popping on the overrun and no sign of pipe bluing.
Geoff.
post #146 of 438 (permalink) Old 01-09-2013, 02:24 PM
Guys i've been reading this full thread with interest. I do intend to try this out but i was wondering if the following would work. It seems the trick is now to block the airflow but leave enough to stop condensation. How much do you need to block the airflow by? Could you get enough of an effect by using a number of cable ties to nip a section of the pipe closed just enough to reduce the air flow. Im thinking three or more ties over say an inch of pipe just to constrict the pipe enough to get the positive effects while leaving enough internal diameter left to allow condensation to drain.
-way- is offline
post #147 of 438 (permalink) Old 01-09-2013, 03:23 PM
Forchetto's Avatar
If you can get hold of those temporary hose clamps they can be used to adjust just how much flow there's left on the air supply hose.
There are several types, one of these BERGEN clamps would do it, although the cable tie way is simple and cheap and would probably work fine:
http://www.esellit.com/bergen-tools-...14-p-2340.html
post #148 of 438 (permalink) Old 01-09-2013, 04:05 PM
Those clamps would also take some hiding. I was thinking with the cable ties I wouldn't even need to pop the hose out of the air box. Just put the cable ties around the pipe before it passes through the side cover. It would be interesting to see how little restriction is required to reap the rewards.
-way- is offline
post #149 of 438 (permalink) Old 01-20-2013, 02:19 PM
Main Motorcycle: Bonneville SE 2012
I just ordered some of
these these
Have been waiting a week for them to arrive so I may drive to the hardware store and pick up a cheap alternative. I got my preds about two weeks ago. At first the pops were a welcomed surprise after the stock pipes but I engine break frequently and it can be extremely nerve wrecking when trying to slow down for a traffic light or a sudden car lane change.
filc is offline
post #150 of 438 (permalink) Old 01-30-2013, 11:15 AM
Meh. I didn't realize this until now but these were coming from China and I blindly chose ground shipping. I was wondering what was up when after two weeks they still had not yet arrived.
Anyhow I am impatient and it seems like a solution should be cheap enough. The blood vial idea is a good one but those are not easily had and ordering them online means buying in bulk. Anyone else have any good ideas that can be had from a hardware store? Something that lets just a little air through? I'm thinking of hitting up the hardware store on the way home today.
filc is offline
Easy AI disabling Forchetto Air Cooled Twins Technical Talk 34 04-02-2014 01:13 PM
AI disabling, not removal? perfectbonnie Air Cooled Twins Technical Talk 4 01-18-2011 06:42 AM
Disabling the oxygen sensor q2quest ECM and FI Tuning - Help, Tips & Tricks 8 09-16-2010 02:55 AM
disabling alarm? bgjb2005 Triumph SuperSports 5 01-02-2009 10:30 PM
Is a new tune required after disabling the SAI? JTXR Sprint Forum 1 09-17-2007 06:03 PM
