The Oil Pressure Light Switch - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 67 (permalink) Old 12-24-2010, 02:45 PM
Main Motorcycle: 2006 T100
Other Motorcycle: 1968 Triumph T120
Originally Posted by mikeinva View Post
The pumps are driven with plastic gears from one pump to the other if 1 pump locks up both go out most of the time (tears the gears up)
Surprised to learn that plastic gears are used. Surprised they hold up as well as they do.
2006 T-100, 57k and oil tight; BC Sleepers, no snorkel,Hyde steering damper, Parabellum Scout, Western Bars, Progressive 412s, Michelins, AirHawk, Go Cruise, 19-tooth; Givi bags, K&N, Nology, Kuryakan Iso grips
Oldguy is offline
post #12 of 67 (permalink) Old 12-24-2010, 03:13 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
there tuff plastic of some kind maybe nylon
mikeinva is offline
post #13 of 67 (permalink) Old 12-25-2010, 09:47 AM
Main Motorcycle: Bonnie, what else?
Other Motorcycle: B25
Extra Motorcycle: T140
Hi Mike, thanks for info, I'm not sure if that makes me feel safer.
Cheers, Dayve
Dayve is offline
post #14 of 67 (permalink) Old 12-25-2010, 09:53 AM
mikeinva's Avatar
Cheers, Dayve
look at it this way the gears dont wear much and will only go bad if the pump locks up so you are safe
mikeinva is offline
post #15 of 67 (permalink) Old 12-25-2010, 11:40 AM
Main Motorcycle: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I kept: '69 Trident
I believe they are made from Ryton - good for 450*F continuous.
Dick
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; Hagons, PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline
post #16 of 67 (permalink) Old 11-26-2012, 12:51 PM
Main Motorcycle: 2012 Tiger 800
TX1911fan's Avatar
Forchetto to my rescue again! Washed my bike Saturday, went to ride today (Monday) and what should happen but my oil light comes on! Let's see what happens when I implement these tips.
TX1911fan is offline
post #17 of 67 (permalink) Old 11-28-2012, 03:27 PM
TX1911fan's Avatar
Ok, so I checked the boot and there was water in there. I moved the boot, let it dry out and slathered it with dielectric grease. Only problem is that the light is still on. What gives?
post #18 of 67 (permalink) Old 11-28-2012, 03:33 PM Thread Starter
Forchetto's Avatar
Only two possibilities (Assuming that there's normal oil pressure when engine is running.):
The switch contacts are stuck "ON"
There's a short to ground or chasis in the wire that runs from the lamp to the switch.
Disconnect the switch by following the wire under the rear of the tank and unplugging it. This is easier than trying to undo the little screw that holds the wire on to the switch. If the light goes out the switch is faulty. If it doesn't the wire has a short to ground.
Forchetto is offline
post #19 of 67 (permalink) Old 11-29-2012, 11:30 AM
TX1911fan's Avatar
Ok, this is getting really frustrating. Now the bike won't start at all! Turn the key, kickstand up, clutch in, bike in neutral and all I get is a click. Then wait for about 5 seconds and the fuel pump re-primes and if I push the starter I get another click. If I don't wait for the pump to prime, no click. I took a video so I'll try to upload that so you guys can help me. What is going on?
Edited to add video:
post #20 of 67 (permalink) Old 11-29-2012, 02:36 PM Thread Starter
Forchetto's Avatar
Assuming your battery terminals are tight, it's a flat battery I'm afraid...
Is this the Low Pressure Oil Light Switch??? Putts255 Tiger Workshop (archive) 4 09-20-2010 03:28 PM
Oil Pressure Switch greatescape Air Cooled Twins Technical Talk 8 09-15-2010 10:21 AM
Brake light pressure switch marx T3 Sport / Touring Forum 3 09-26-2009 05:32 PM
Rear brake light pressure switch tham Club Cafe' 6 02-22-2007 01:34 PM
oil pressure switch htown16 Classic, Vintage & Veteran 6 04-29-2006 11:49 PM
