Ignition pick-up coil / Crank position sensor (nerdy AND boring) - Page 13 - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #121 of 193 (permalink) Old 12-13-2012, 12:16 PM
Main Motorcycle: 2005 Bonneville Black
Other Motorcycle: 65 Velocette Venom in bit
Resolved
Fitted new ignition pick up coil gapped to .8 and all is well.
Points to note.
The steel guide for the wiring is like a razor and repostioning the cable to gain slack damaged my outer sheath. Made good with self amalgamating tape, hope it stays put! Well worth deburring if possible.
I used Kawasaki liquid gasket on the rubber to alloy joints and it was fiendishly expensive and messy as it is very runny. But no leaks!
Bike started first time this morning, best ever sub zero start, I am putting that down to the Nology coil.
Recomended torque for the pickup coil screws was about a twentieth of what it took to shift them. maybe they use araldite as thread lock, answers on a post card? I gave them an extra tweak anyway because The torque wrench clicked at just past nipped and I don't trust the things especialy where anything liquid is used on a thread.
Velocette is offline
post #122 of 193 (permalink) Old 02-16-2013, 07:42 AM
Main Motorcycle: Triumph Speedmaster
information speedmaster
Forgetto Hello, (sorry for my English), I'm from Spain and I have a Speedmaster carburetion 2006, a few months ago, I came fallon a piston. sometimes you do well and others not, I led the workshop, we have checked the coils and are well, we have changed the spark plugs and still ingual, the mechanic told me that failure is the CDI. But I saw on your site that can be pick-up. From Spain have told me that you understand much about the subject.
Can you help me?
thanks
soriketes is offline
post #123 of 193 (permalink) Old 02-17-2013, 05:49 PM Thread Starter
Forchetto's Avatar
Have they tried measuring the sensor resistance before they blame the problem on the igniter or CDI box?. It's an expensive item to change without being sure.
Han comprobado la resistencia del sensor antes de condenar el modulo CDI de encendido?. Es una pieza demasiado cara para condenarla antes de eliminar el sensor.
Forchetto is online now
post #124 of 193 (permalink) Old 02-18-2013, 11:45 AM
sensor resistance you mean pick-up, as you explain in the beginning?
if you please to explain it, I'd tell my mechanic
regards
post #125 of 193 (permalink) Old 05-08-2013, 01:45 PM
Administrator
Legend
Main Motorcycle: Tiger 955i
Haggis's Avatar
Other Motorcycle: Sprint RS
Extra Motorcycle: Honda XL250
IMPORTANT NOTE ON RESISTANCE VALUE
But note that on later bikes, after VIN number 437493 they've changed the specification and part number of the pick-up coil. Old number was T1290131, new one is T1296505.
There are some mechanical changes as well, but the new resistance value is of the order of 217 Ohms rather than the 600 Ohms of the old one.
I added this info from Forchetto from another thread
Haggis is offline
post #126 of 193 (permalink) Old 05-13-2013, 03:29 PM
Main Motorcycle: thruxton efi
arthurmo's Avatar
Other Motorcycle: BMW650 cs
Thanks Forchetto for posting these topics you've saved me a lot of time and money.My thrux wouldn't start and we've managed with tune ecu and a good mechanic to narrow it down to this.
You get a cheers too Haggis for the part numbers!
arthurmo is offline
post #127 of 193 (permalink) Old 07-28-2013, 09:15 PM
Main Motorcycle: 2006 Bonnie 790/Carb
TowerGuy's Avatar
Thanks Forchetto very interesting and helpful
TowerGuy
TowerGuy is offline
post #128 of 193 (permalink) Old 09-02-2013, 01:42 PM
Newbie
Main Motorcycle: 03 Speedmaster
Forchetto, I want to thank you for your great info...I have a quick question for you.
I made the LED tester for the pick up coil as you described, and it worked. However the light was extremely weak...in your opinion, is that a symptom of something or to be expected?
WorGaz is offline
post #129 of 193 (permalink) Old 09-02-2013, 11:15 PM Thread Starter
Forchetto's Avatar
Normal, I think. There's very little energy generated by that coil, after all the ECU only needs a small signal.
post #130 of 193 (permalink) Old 10-14-2013, 10:13 AM
Newbie
Main Motorcycle: 07 Triumph Truxton
Other Motorcycle: 74 CB 750
Extra Motorcycle: 1970 Triumph t120R
Forchetto,
Amazing research, I recently started having simmilar issues with bike shutting off. Checked for spark and nothing, let her sit for 15 to 20 minutes and started back up. I have changed the coil, tested pick coil and its around 520 cold. I have not checked gap, but would you recommend changing unit since I will need to get in there anyways? also what would be next if issue continues the CDI?
cafecbn is offline
Ignition Sensor (Coil Pick-up) Repair Legend JJ Hinckley Classic Triples 2 07-22-2010 09:38 AM
New pick-up coil, ignition coil, & ignitor. No Dice... Flyhalf_Keith Air Cooled Twins Technical Talk 22 04-18-2010 03:19 PM
Ignition pick-up sensor j98sprint Maintenance & Workshop Talk 4 02-21-2006 01:42 AM
crank position sensor Seeker Trophy 7 12-05-2004 07:20 PM
