Mag Wheel Tire Options - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
post #1 of 405 (permalink) Old 11-14-2010, 01:24 AM Thread Starter
Main Motorcycle: 2010 Bonnie Black MAG
BrewDudeBob's Avatar
Other Motorcycle: Dreaming of an Explorer
Extra Motorcycle: Dreaming of a KTM
First off, I tried looking in the archives for information specifically regarding tire options for the new Mag-Wheel Bonnies, and didn't find much. Also, i am new to riding and will need to buy new tires very soon as I have 9000 miles on my 2010 Black.
We all know the stock Tubeless Metzelers are the following dimensions:
Front Tire 100/70 R17
Rear Tire 130/80 R17
Looking at the image below from http://www.motorcycle-superstore.com I am a little confused by the tire width. does the "120" refer to the width of the outside bow of the tire, as the image seems to indicate? Or is it the width of the bead?
Also, how important is the Aspect Ratio when choosing a tire? For instance, on my bike, can I fit a 100/80 R17? Or will that cause problems? I ask this because the Avon AM26 Roadrider Front Tire only comes in 100/80V-17 through Motorcycle superstore. Are there any other reputable tire dealers you guys know of I can look at? Any dealers to beware of?
When I go to the Avon website, here is what they say they have:
http://www.avon-tyres.co.uk/motorbike/850-bonneville-se
850 Bonneville / SE / T100 / Sixty (2009 onwards)
Front tyre
Roadrider
Pressure front: 2.3 bar (33psi)
Front size: 110/70-17 (54V)
Rear tyre
Roadrider
Pressure rear: 2.7 bar (39psi)
Rear size: 130/80-17 65V
Anyone know where I can find the Front Tire size in the States? I will keep searching the web in the meantime.
The Avons look nice, but I am not dead-set on getting them. I am open to other suggestions and any tips I can get. I just think the Metzelers are too slick, and want something with more tread.
Thanks in advance
ΜΟΛΩΝ ΛΑΒΕ
BrewDudeBob is offline
post #2 of 405 (permalink) Old 11-14-2010, 07:00 PM Thread Starter
So, out of the 58 people who viewed this thread, nobody has a mag-wheel Bonnie that they have replaced the tires on?
ΜΟΛΩΝ ΛΑΒΕ
post #3 of 405 (permalink) Old 11-14-2010, 07:01 PM
Main Motorcycle: Thruxton
Look here:http://www.tiresunlimited.com/ALL%20..._roadrider.htm
Avon RoadRider is a very commendable tire.
carmi52 is offline
post #4 of 405 (permalink) Old 11-14-2010, 07:11 PM Thread Starter
Yes, but my conundrum is the numbers. Do I get the 100/80V17 or 110/70V17
The Metzelers are 100/70V17
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 405 (permalink) Old 11-14-2010, 08:04 PM
Main Motorcycle: 2016 Bonneville T 120 Blk
gabbydad's Avatar
I'll be looking at this info with interest as I'll be in the same position in the early spring I figure...
Psycrow likes this.
gabbydad is online now
post #6 of 405 (permalink) Old 11-14-2010, 10:15 PM
Main Motorcycle: 2009 Bonneville
BreckRat's Avatar
The stock front tire on my 2009 mag wheel is a 110/70 r17. i have about 6500 miles on mine and the front and rears are getting squared off pretty bad but there seems to be plenty of tread left. I'll be looking for tires next summer. I wouldn't mind a set of tires with some mild dirt capability or a fat front tire for looks but there doesn't seem to be many options in this rim size.
Keep us posted on what you end going with.
BreckRat is offline
post #7 of 405 (permalink) Old 11-15-2010, 08:39 AM
Main Motorcycle: 05 T100
Are you sure you haven't mis-read the sidewall of your front tyre? According to Triumph's website the cast wheeled Bonnies come with a 110/70 front tyre. This is also the recommended fitment on the Metzeler website and they don't list a 100/70 MEZ4. I'm pretty sure I've seen a 110/70 MEZ4 fitted to the bikes I've looked at. Can't say I'm overly impressed by Avon lumping the T100 and Sixty in with the Bonneville and SE so that their recommended fitment for those bikes is a 17" tyre that won't fit their 19" wheels! I would stop looking for a 100/70 x 17" and just go with the 110/70, it'll be fine. The width of the tyre is the widest part as shown by the image you posted above. The bead will be narrower - a 110 tyre is about 4.33" wide and you're fitting it to a 3" wide wheel so the bead width will be somewhat nearer to 3" (but still a bit wider).
Paul.
Herts. UK
PAAS is offline
post #8 of 405 (permalink) Old 11-15-2010, 09:26 AM Thread Starter
I hate to disagree PAAS, this is copied & pasted from the Triumph site:
http://www.triumph.co.uk/usa/2010_Bo...onneville.aspx
Front Tyre100/70 R17
Rear Tyre
130/80 R17
There is the possibility the web-site is wrong, so I will take a snapshot of the tire when I go home for lunch. It is raining today here in GA, and I drove my cage to work. It is vexing that I cannot just run down to the parking lot and take a quick look
But I am pretty sure my front tire is a 100/70 17. Cause I took a pen & paper to the garage before I started searching the web for comparable replacements.
ΜΟΛΩΝ ΛΑΒΕ
post #9 of 405 (permalink) Old 11-15-2010, 10:37 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
I think you're getting a bit too deep into the exactness of the tire size replacement. Each tire maker has specifications for their products...for example, here's the pirelli tire range w/ specifications:
http://www.us.pirelli.com/en_US/brow...LI_FULL_07.pdf
All of the makers have similar information if you search it out on their websites. Look at the specifications table and you will see that there are allowable rim width ranges for each tire size. You can run any tire that will fit on your rim safely, but you should try and keep the rolling diameter somewhat close (assuming your speedometer is accurate). For example, if you have a 100/70-17 currently, you can run a 110/60-17 and not significantly change the rolling diameter.
From the pics of the mag wheel bonnies, it appears to me that there is plenty of fender clearance to go up a tire size as well. A 110/70-17 or a 120/60-17 would probably take up some of the gap...just check to make sure whatever you buy fits on the stock rim width.
Cheers,
--Rich
beemerrich is online now
post #10 of 405 (permalink) Old 11-15-2010, 10:57 AM Thread Starter
Rich,
Thanks for the info, that is close to what I was looking for. Like I said, I am new to bikes, and this is the first time I have ever had to deal with a tire change. I have a mile-high understanding of the three size specs, but absolutely no frame of reference as to the impact of minor size changes when it comes to my bike.
I was going to buy my own tires and bring them to the dealer, but it looks as if i will have to rely on the dealer's expertise to ensure I don't get a tire that rubs, or otherwise negatively impacts my bike.
ΜΟΛΩΝ ΛΑΒΕ
Wheel and Tire Size Options blue-triumph Member's Restoration & Rebuild Projects 6 11-02-2010 12:32 AM
Front Wheel & Rear Wheel Options On America OneArmMan Cruisers - America, Speedmaster 0 08-29-2010 08:57 AM
Tire Options Heretic13 Air Cooled Twins Technical Talk 16 10-08-2009 02:05 AM
Wheel options petcock Air Cooled Twins Technical Talk 10 11-02-2007 09:33 AM
Mag Wheel Options Berta Air Cooled Twins Technical Talk 20 11-04-2006 06:12 PM
